https://en.wikipedia.org/wiki/Bristol_Brabazon
The Bristol Type 167 Brabazon was a large propeller-driven airliner which was designed by the Bristol Aeroplane Company to fly transatlantic routes between the United Kingdom and the United States. The type was named Brabazon after the Brabazon Committee and its chairman, Lord Brabazon of Tara, who had developed the specification for which the airliner had been designed. While Bristol had studied the prospects of developing very large aircraft as bomber aircraft prior to and during the Second World War, it was the release of a report compiled by the Brabazon Committee which had led to the company to adapting its larger bomber proposal into a prospective large civil airliner to meet the Type I specification for a very large airliner for the long distance transatlantic route. Initially designated as the Type 167, the proposed aircraft was furnished with a huge 25 ft (8 m)-diameter fuselage containing full upper and lower decks on which passengers would be seated in luxurious conditions; it was powered by an arrangement of eight Bristol Centaurus radial engines which drove a total of eight paired contra-rotating propellers set on four forward-facing nacelles. Bristol decided to submit the Type 167 proposal to meet Air Ministry Specification 2/44; following a brief evaluation period, a contract to built a pair of prototypes was awarded to Bristol. At the time of its construction, the Brabazon was amongst of the largest aircraft in the world to have ever been built, being sized roughly between the much later Airbus A300 and Boeing 767 airliners. Despite its vast size, the Brabazon was designed to carry a total of only 100 passengers, each one being allocated their own spacious area about the size of the entire interior of a small car. On 4 September 1949, the first prototype conducted its maiden flight. In addition to participating in a flight test programme in support to intended production aircraft, the prototype made high-profile public flying displays at the 1950 Farnborough Airshow, Heathrow Airport, and the 1951 Paris Air Show. However, the Brabazon was unable to attract any firm commitments for the type due a widespread feeling amongst airlines that the airliner was too large and expensive to be practical and applicable to their existing operations. Being unable to attract any orders, the aircraft became regarded as a commercial failure. On 17 July 1953, Duncan Sandys, the Minister of Supply, announced that the Brabazon had been cancelled due to a lack of military or civil orders for the type. In the end, only the single prototype was flown; it was broken up in 1953 for scrap, along with the uncompleted turboprop-powered Brabazon I Mk.II. Role Airliner Manufacturer Bristol Aeroplane Company First flight 4 September 1949 Retired 1953 Status Only example scrapped in 1953 Number built 1 Although considered a failure and a white elephant, the record of the Brabazon is not entirely unfavourable. At least half of the large sums spent on the project had been expended upon the construction of infrastructure, including £6 million for new large hangars and an extended runway at Filton. These improvements meant that Bristol was in an excellent position to continue production of other designs; the assembly hall was soon being used for building another transatlantic aircraft, the Britannia. In addition, many of the techniques which had developed during the Brabazon project were applicable to any aircraft and thus could be reused, not just airliners. Bristol had also been awarded the contract for the Type III aircraft, for which they delivered as the Britannia. By making use of the advances made during the development of the Brabazon, Bristol were able to design the Britannia to possess the best payload fraction of any aircraft up to that time, and it held that record for a number of years. Although the Britannia was delayed after problems with the separate Type IV, the jet-powered de Havilland Comet, it went on to be a workhorse for many airlines into the 1970s. Specifications (Mark I) General characteristics Crew: 6–12 Capacity: 100 passengers Length: 177 ft (54.0 m) Wingspan: 230 ft (70 m) Height: 50 ft (15 m) Wing area: 5,317 ft² (494.0 m²) Airfoil: Root T.P.4 (mod) Tip T.P.5 Empty weight: 145,100 lb (65,820 kg) Max. takeoff weight: 290,000 lb (130,000 kg) Fuel capacity 13,650 Imp gal (61,971 L) Powerplant: 8 × Bristol Centaurus radial engines, 2,650 hp (1,860 kW) each Propellers: paired contra-rotating Rotol, three wooden blades Propeller diameter: 16 ft (4.9 m) Performance Maximum speed: 300 mph (260 kn, 480 km/h) at 25,000 ft Cruise speed: 250 mph (220 kn, 400 km/h) at 25,000 ft Range: 5,500 mi (4,800 nmi, 8,900 km) at 250 mph and 25,000 ft Service ceiling: 25,000 ft (7,600 m) at full weight Rate of climb: 750 ft/min (3.8 m/s) at sea level Max. wing loading: 54 lb/ft² (270 kg/m²) Minimum power/mass: 0.073 hp/lb (120 W/kg) * |
| Thread Tools | |
| Display Modes | |
| UK2 VX206 Bristol Brabazon.jpg | Joseph Testagrose | Aviation Photos | 1 | September 27th 14 04:50 PM |
| UK2 VX206 Bristol Brabazon to G-AGPW 4.jpg | Joseph Testagrose | Aviation Photos | 0 | September 27th 14 02:59 PM |
| UK2 VX206 Bristol Brabazon to G-AGPW 2.jpg | Joseph Testagrose | Aviation Photos | 0 | September 26th 14 02:10 PM |
| UK2 VX206 Bristol Brabazon to G-AGPW 3.jpg | Joseph Testagrose | Aviation Photos | 0 | September 26th 14 02:10 PM |
| UK2 VX206 Bristol Brabazon to G-AGPW.jpg | Joseph Testagrose | Aviation Photos | 0 | September 10th 12 02:10 PM |
