Diesel engines- forced induction, power-weight
Old December 6th 03, 06:32 PM
Jay
Default Diesel engines- forced induction, power-weight
From what I understand, the low power to weight ratio of diesel
engines has been the main limiting factor for their adoption into
small planes (and passenger cars for that matter). The reason for the
high weight as it was explained to me was that the high compression
used for an auto-ignition type engine required strong, and thus heavy
castings to withstand the pressures.
So these days you see diesels fitted with forced induction systems,
which apparently makes them more peppy (e.g. the 90hp VW 1.9L TDI).
But doesn't this more powerful charge being introduced by the forced
induction system, just require again, a heavier engine to withstand
the more powerful explosion? Or to put in in converse, if the same
engine could have withstood the more powerful charge, couldn't they
have built it lighter in the first place and used a conventional
induction system? For now lets ignore the altitude power
normalization aspect for aircraft operation.
Old December 6th 03, 07:24 PM
Ed Wischmeyer
Check out the RPMs at which the various diesel engines develop their
power (I don't have any numbers in front of me, so I'll let you do the
web search). That's part of the answer.
Ed Wischmeyer
Old December 7th 03, 12:38 AM
Ernest Christley
Having spent years behind the big wheels, power to weight is probably on
the bottom of my list for not having a diesel in a small vehicle of any
type.
Your burning kerosene there, so the pistons have to take their time to
give those long carbon chains time to burn down. The engines I sat on
top of usually ran between 1800 and 2100 RPM, were slow to rev up, and
shook like a crack whore. Anything that shook like that would tear an
airplane apart, and would be very uncomfortable in a passenger car.
http://www.ernest.isa-geek.org/
"Ignorance is mankinds normal state,
alleviated by information and experience."
Veeduber
Old December 7th 03, 06:30 AM
Dan Brown
Ernest Christley wrote in news:TLtAb.79227
type.
We're getting way off-topic for this group, but if you're at all
interested, test-drive a VW (Golf, Jetta, Bettle) TDI some time. Not
rockets by any means, but they're reasonably peppy. At idle, you can tell
it's a diesel, but when it's moving, it's quieter than the gas engine (due
to lower revs). I'd think it's a bad candidate for aircraft use because of
power/weight, but it's great for a car (which is why I drive one).
Old December 7th 03, 10:23 AM
R. Hubbell
Times have changed and materials science has taken some huge leaps. Modern
diesels are cleaner and quieter then just 10 years ago.
I didn't think forced induction was anything new to diesel engines.
It definitely makes them peppier and more efficient.
Again, materials have advanced greatly and the parts can be made lighter
and stronger.
What do you mean by conventional induction system?
Don't ignore that, that's one of the best features.
R. Hubbell
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 04:07 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Home Built 3 September 13th 03 01:44 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 06:12 AM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
