Douglas fir vs sitka spruce
Old September 19th 17, 07:11 PM posted to rec.aviation.homebuilt
Default Douglas fir vs sitka spruce
On Monday, February 13, 1995 at 11:58:24 AM UTC-5, Stephen Eldredge wrote:
In article (Kurt da' Squirt) writes:
(Kurt da' Squirt)
Subject: Douglas fir vs sitka spruce
Date: 13 Feb 1995 01:47:49 -0700
Keywords: wood
I have been thinking a bit about wood planes. And have often
heard that douglas fir can be used in place of spruce in certain areas of
a plane in order to reduce costs. Just what areas?
Spars?
fuselage?
According to the FAR's if fir is up to spec it can be used in any area that
spruce is used.
Wing ribs?
From what I remember, (if that is right) douglas fir of the same
dimentions, is heavier, and slightly stornger than spruce.
Fir is about 25% heavier and about 21% stronger than Sitka Spruce.
I am just wondering in which areas of construction douglas fir could be
used, whithout violating some reasonable conventions of safety. And also
just how much you would save in money and gain in weight, if you used as
much douglas fir as would be resonable. Its just that spruce seems so
Cost savings varies, but if you can find a good deal on fir it can save you
up to 80%.
Gordon Nichol
Steve Eldredge
Some years ago, I built a Corben Jr. Ace. Open cockpit, fabric covered sport plane from 1929. I read everything the EAA had on wood and wood substitutions. In the end, I found my local lumber yard had some terrific Doug Fir in long lengths with tight, straight running grain.
I used it for the spars, I ripped it into the 1/4" x 1/4" strips I needed to build the ribs and everything else where Sitka was called for.
The FAA inspector told me it was way better than almost all the Sitka he's seeing these days.
Go ahead and use it.
Brian
Michigan
Old September 20th 17, 03:47 AM posted to rec.aviation.homebuilt
In article
(Kurt da' Squirt)
Keywords: wood
Spars?
fuselage?
spruce is used.
Wing ribs?
up to 80%.
Gordon Nichol
Steve Eldredge
Brian
Michigan
Just make sure it meets all the other requirements - good close
straight grain etc.
T-34 (3) @ Spruce Creek - Navy(3) Spruce Creek 2010 (Custom).jpg Glen in Orlando Aviation Photos 0 April 30th 10 11:14 AM
P-51 (2) Spruce Creek - E Pluribus Unum Spruce Creek (Custom).jpg Glen in Orlando Aviation Photos 0 April 30th 10 11:08 AM
P-51 @ Spruce Creek - P51 E Pluribus Unum Spruce Creek (Custom).jpg Glen in Orlando Aviation Photos 0 April 30th 10 11:07 AM
sitka spruce al pernell Home Built 43 February 25th 04 11:02 PM
Doug Fir vs: Sitka Spruce Lou Parker Home Built 40 November 10th 03 05:36 PM
