ADSB visibility with non certified GPS
Old September 24th 17, 11:35 PM posted to rec.aviation.soaring
Darryl Ramm
Default ADSB visibility with non certified GPS
Oops left off thing...
TIS-B broadcasts information for SSR targets, it requires
1. Your aircraft has a transponder
2. Your aircraft is within SSR coverage
3. The TIS-B client aircraft has ADS-B In
4. The TIS-B client aircraft has ADS-B Out that is correctly configured to describe it's ADS-B In capabilities.
5. The TIS-B client aircraft is within ADS-B ground service coverage.
On Sunday, September 24, 2017 at 3:32:38 PM UTC-7, Darryl Ramm wrote:
On Sunday, September 24, 2017 at 11:59:19 AM UTC-7, WaltWX wrote:
On Thursday, September 21, 2017 at 7:31:32 PM UTC-7, Darryl Ramm wrote:
Walt, I think you are misunderstanding what Trig wrote. A TN72 GPS Source will be seen by everybody. That is why anybody doing ADS-B Out in an experimental glider with a TT22 should be equipping with at least a TN72 (or TN70, TN70 required for certified gliders).
Darryl,
Everybody need to stop saying "ADS-B Out" and say 109ES Out or UAT Out where it matters. I try to only say ADS-B where the link layer does not matter. Saying "ADS-B" where you need to be clear about 1090ES or UAT is as useful as saying "TSO" without being clear if we are talking about TSO-C145 or TSO-C199, and can cause much confusion.
OK, I'm clear now that a TN72 GPS Source from a Trig T22 will make me officially visible to all ADS-B in equipped aircraft.
Well all aircraft with 1090ES In, or via ADS-R if they have UAT In (and it's properly set up with some type of ADS-B Out etc.) and in range of ADS-B ground stations.
I am still trying to figure out why I would want to equip with any kind of ADS-B out in my T22 equipped glider:
1) It would be great (but not necessary) to be seen by all ADS-B equipped aircraft. But, with ADS-R (rebroadcast) won't those other aircraft see me anyway since I'm equipped with a Mode-S Trig transponder? I suppose at low altitude where ADS-R is not available, direct receipt of my ADS-B out would be an advantage.
ADS-R no, you are confusing ADS-R and TIS-B.
TIS-B position reports are SSR based and should be expected to be less accurate than either ADS-B direct or ADS-R.
There are many places where gliders and gliders, or towplanes or GA aircraft that might have 1090ES In will be together that won't have TIS-B service coverage. Think of lots of GA airports that glider operations may tow out of or gliders may land at. And many busy airports I can think of where you lose SSR coverage as you decent to pattern height, they concern me as pilots may stop seeing TIS-B targets and be lulled into assurance the target is not longer a threat. Ditto for aircraft without properly configured ADS-B Out that are piggybacking on nearby aircraft to cause TIS-B (and ADS-R) message broadcasts, things going quiet on the traffic displays does no mean there is no traffic.
2) It sounds like with the TN72 GPS source, I will not be compliant if wanting to enter Class B, C, and a few other little used airspace. My question is this... If equipped with a TN72 GPS source, do you think that ATC will allow temporary access to Class B and C... such a for passing through their airspace? That was ONE reason for equipping with a transponder in the past. I have no intention of OPERATING in Class B and C so as to use full ATC services. Also, do you think that controllers for restricted airspace MIGHT allow transiting that airspace without fully compliant ADS-B out?
Don't know, talk to your local ATC folks.
If ATC uniformly will disallow temporary transiting of Class B, C and restricted airspace unless equipping with a fully compliant GPS source (i.e. TN70), then there is VERY LITTLE REASON TO EQUIP WITH A TN72.
Again I talk to your local ATC folks. I would not want to ask any national authorities about uniform ATC treatment if any special situation. Work out things locally and use that to guide what you do.
I see small potential justification for equipping with a TN72:
A) visibility to all ADS-B official aircraft directly without rebroadcast (ADS-R) which means they can see me in the pattern a low altitude.
But you still won't be seen by aircraft in those situations. that only have UAT In. You *need* ADS-R ground service coverage for that.
B) Potenially, a TN72 will also give me an alternative to a Satellite tracker if Flight Aware or Aerion makes tracking of ADS-B aircraft less expensive than the current vendors (Spot and Garmin Inreach).
The current Garmin InReach tracker is relatively low cost and already more capable (esp. two way messaging and reliable operation on the ground (as long as you have line of sight of satellites) than what ADS-B will be able to do. Having ADS-B Out is further information, that might be be very useful in a SAR situation. I would certainly include that in discussions with club members, FBOs, written down as part of your emergency information/plan that you have (everybody has one right?) make sure it is noted on your NOAA ELT/PLB registration, SPOT or InReach tracker registration, etc. But I'd not be upgrading to 1090ES Out for SAR reasons--I'd buy a Garmin InReach first if I did not already have one.
And the FAA/SAR organizations today can get to ADS-B flight traces, so if an ADS-B out equipped glider should go missing it's important to make sure SAR groups are aware that it was so equipped.
comments...
Walt Rogers WX
You may also want to have 109ES Out to provide better long-term visibility via PowerFLARM when buddy flying.
Many aircraft are going to equip with ADS-B Out by 2020. I'm anecdotally seeing a lot of GA aircraft equip with ADS-B In, with most new potable and fixed systems being dual-link receive. Given all that if you fly near busy GA aircraft areas I expect equipping with ADS-B Out to be interesting to consider, fast jets and airliners can see you today via TCAS, in all airspace at all times. 1090ES Out starts also providing that "all airspace and all time" capability to GA aircraft as they equip with (1090ES or dual-link) ADS-B In.
  #32
Old September 25th 17, 04:30 PM posted to rec.aviation.soaring
On Friday, September 22, 2017 at 4:21:56 PM UTC-4, John Carlyle wrote:
Oh, Darryl - think like a lawyer? Can't - I'm a physicist, legal thinking "does not compute".
- yeah, after all these years I still cannot make any sense of the wording "any aircraft that was not originally certificated with an electrical system, or that has not subsequently been certified with such a system installed". Had it said "nor" instead of "or", perhaps? (I do have a degree in physics.)
  #33
Old September 27th 17, 06:24 PM posted to rec.aviation.soaring
son_of_flubber
I asked Trig support this question:
"Will a TT21 + TN72 transmit a non-zero quality indicator?"
Here is their reply:
"The TT21 is fully certified to the latest ADS-B Out cert TSO C166b – so it can output all the required data. It is true that if you wish to meet ADS-B Out compliance FAR 91.227, you should have a higher power TT22. However, there is no way for the radar to tell if you’re using a TT21 or TT22. Inspection of your aircraft would be the only way to tell. As such I believe a number of experimental pilots have opted to ignore the requirement , but of course I cannot recommend this as it would be in violation of FAR 91.227 – the requirements for 2020 compliance.
The TN72 offers both a SIL =1 output, and also a SIL = 3 output. So this means that you can meet the FAA compliance check using your TN72 plus TT21. https://adsbperformance.faa.gov/PAPRRequest.aspx
If you so choose, you can opt to have your TT21 upgraded to a TT22. For more information on this please contact our US service centre below;
Trig Avionics Technical Support
9400 East 34th Street North
Wichita
KS 67226
United States
Tel: Toll Free 800 821 1212
Tel: +1 316 630 0101
Email:
Web:
www.mcico.com
The response to my inquiry with is:
"The cost to update the TT21 to the TT22 is $950.00. Turn around time is 3-4 days in house."
  #34
Old September 28th 17, 02:44 AM posted to rec.aviation.soaring
kinsell
Interesting that the information sent out from a 1090ES device doesn't
include enough to identify the model number. But of course an avionics
shop or A&P might spot the problem.
Wichita
KS 67226
United States
Email:
Web:
www.mcico.com
  #35
Old September 28th 17, 05:12 PM posted to rec.aviation.soaring
jfitch
Wichita
KS 67226
United States
Email:
Web:
www.mcico.com
That is some very useful information right there. Two questions:
Does the receiver (FAA) have any way to tell more information about the GPS source? If it is transmitting an SIL of 3 (required for carriage requirements), other than physical inspection can a receiver discriminate between a 70 and a 72?
What does Powerflarm do with a glider having both ADSB out and Flarm? Does it deambiguize?
  #36
Old September 28th 17, 05:51 PM posted to rec.aviation.soaring
Ramy[_2_]
Now that the TN72 is available and relatively low cost, is there a reason for those of us with TT21/TT22 in experimental gliders to wait till 2020 to install the TN72 vs installing now to become more visible to more aircrafts?
I am curious to hear from folks who already done that.
Ramy
  #37
Old September 28th 17, 06:33 PM posted to rec.aviation.soaring
Darryl Ramm
Wichita
KS 67226
United States
Email:
Web:
www.mcico.com
There is no GPS Source vendor ID. No Mode-S transponder or UAT Out vendor ID, no serial numbers, no encryption signature, etc. allowed for in the design of ADS-B. The lack of signature is a much more serious shortcoming IMNSHO that any of the others. ADS-B Out systems do transmit SIL, NIC and NAC GPS quality parameters and interestingly CC (capability code) that describe if the aircraft has 1090ES In and/or UAT In.
Yes it deduplicates them, based in aircraft ICAO address. Presumably PowerFLARM gives priority to the FLARM signal but somebody like Dave would have to confirm that.
I believe FLARM also deduplicates Mode S PCAS alerts based on ICAO ID. It can't do that to Mode C PCAS alerts because there is no ICAO address broadcast on Mode C.
  #38
Old September 28th 17, 06:48 PM posted to rec.aviation.soaring
Darryl Ramm
None at all. And there is nothing magic about 2020 that should affect your decision here. Please get started and go do it. We are talking the incremental costs of a few long aerotows.
(since I know you fly near SFO Class B at times) keep in mind doing that will not give you access to those areas where the glider exemption does not remove ADS-B Out requirements after 2020 (Class B and C and related, read the regs for details). For that you would need a TN70 based install.
Ramy
  #39
Old September 28th 17, 07:20 PM posted to rec.aviation.soaring
Tom BravoMike
How does this offer fit into our discussion? For experimental gliders, and from the price point of view?
http://grtavionics.com/home/ads-b-so...ionix-echouat/
  #40
Old September 28th 17, 07:35 PM posted to rec.aviation.soaring
jfitch
"The TT21 is fully certified to the latest ADS-B Out cert TSO C166b – so it can output all the required data. It is true that if you wish to meet ADS-B Out compliance FAR 91.227, you should have a higher power TT22. However, there is no way for the radar to tell if you’re using a TT21 or TT22. Inspection of your aircraft would be the only way to tell.. As such I believe a number of experimental pilots have opted to ignore the requirement , but of course I cannot recommend this as it would be in violation of FAR 91.227 – the requirements for 2020 compliance.
Wichita
KS 67226
United States
Email:
Web:
www.mcico.com
So hypothetically, an install of a TT21/TN72 in a certified glider is undetectable as such without a physical ground inspection? It looks to the receiver identical to a TT22/TN70 installation? (Ignoring here the regulatory consequences of such an inspection).
Stratus / Foreflight ADSB 6X Soaring 5 December 17th 13 09:34 AM
ADSB is only the start... Martin Gregorie[_5_] Soaring 0 October 1st 09 01:27 PM
Santa and ADSB Mal Soaring 0 December 15th 06 07:42 PM
Non-certified parts for a certified plane? Dico Owning 10 August 22nd 06 03:11 AM
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 05:36 PM
