Discus B instrument panel template
Old December 7th 12, 01:16 PM posted to rec.aviation.soaring
Default Discus B instrument panel template
Ladies and gents,
If anyone happens to have a .pdf .jpg .dxf or pretty much .anything format of a Discus B panel (or Ventus B/C) it would be most appreciated. Email to Charlie Juliet Lima Seven Six @me.com or the email in my username. Thank you!
Casey.
Old December 7th 12, 01:46 PM posted to rec.aviation.soaring
Dave Nadler
On Friday, December 7, 2012 8:16:16 AM UTC-5, wrote:
Ladies and gents,
Casey.
Yo Casey - If you're redoing the panel and this thing still
has the old sheet-aluminum panel, do replace it with flanged
fiberglass panel for your safety...
See ya, Dave
Old December 7th 12, 02:45 PM posted to rec.aviation.soaring
John Galloway[_1_]
Not sure if you are referring to a lifting panel or not but here
are a couple of links, the first for lifting panel diagrams and the
second for a replacement non-lifting panel.
http://www.mandhsoaring.com/Panels/Panel_CS.pdf
http://svsponline.co.uk/Instrument-Panel-Blanks.html
John Galloway
Ladies and gents,
anything
appreciated.
in my username.
Thank you!
Casey.
See ya, Dave
Old December 9th 12, 03:41 PM posted to rec.aviation.soaring
Thank you Dave, John and those who responded offline. Mission accomplished.
Old October 19th 17, 02:20 PM posted to rec.aviation.soaring
Tom J Designs
Hi
I know is old post, but where can I buy fibreglass or carbon panel for discus b please?
Made one with 3mm aluminium sheet to replace old one which was alloy plate too.
Thanks
Tom
Old October 19th 17, 04:52 PM posted to rec.aviation.soaring
M and H soaring if you are in the USA.
Old October 20th 17, 03:02 PM posted to rec.aviation.soaring
Severn Valley Sailplanes made mine and CNC cut (instrument cutouts & mounting holes) to the specs I sent. Fast, friendly, reasonably priced and shipped to the USA.
CJ
Old October 20th 17, 08:15 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
On Fri, 20 Oct 2017 16:35:28 +0000, David Salmon wrote:
Unfortunately SVS has shut down.
Their shop closed on 1st Oct (temporarily it says) but the rest of the
site seems to be up and running.
Do you know if/when the shop is going to return? Bit of a bugger if it
doesn't because they've always been my first stop if I need stuff for my
glider.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old October 20th 17, 09:23 PM posted to rec.aviation.soaring
Glen Douglas
Martin Carolan posted on uras some time ago, that shop had been for sale
with no takers and has closed for good
G
glider.
org |
PowerFlarm Portable - Fit in Discus 2A on panel top? [email protected] Soaring 1 May 11th 12 11:14 PM
Blank Discus - Ventus Instrument panel for sale james bakeman Soaring 2 September 24th 11 07:30 PM
Discus A Tilt-Up Panel Chuck Schroeder Soaring 1 February 18th 07 04:23 PM
3 1/8" instrument template [email protected] Home Built 4 April 15th 06 02:26 AM
Panel for Discus A Serge Serfaty Soaring 0 July 20th 04 05:31 AM
