Switching tow rings
Old October 31st 17, 12:28 PM posted to rec.aviation.soaring
Default Switching tow rings
At Blairstown Airport we loose about two minutes each time switch between Tost and Schweizer tow rings. I'm wondering what is being done at other busy operations, there must be a faster way. Help!
Old October 31st 17, 12:41 PM posted to rec.aviation.soaring
Hartley Falbaum[_2_]
I make the ropes for the Cordele contest. We have towplanes with Tost hooks, and towplanes with Schweitzers.
I put both rings on the rope end.
If you are talking about glider end, we have not tried that, but it should work.
Hartley
Old October 31st 17, 12:44 PM posted to rec.aviation.soaring
We use ropes with Schweizer rings on both ends, then have a about 4' rope with small rings on one end and a rope loop on the other. It just loops between the tow rope and glider.
Old October 31st 17, 04:14 PM posted to rec.aviation.soaring
JS[_5_]
On Tuesday, October 31, 2017 at 5:44:05 AM UTC-7, Charlie M. (UH & 002 owner/pilot) wrote:
Believe that's what makes it slow. Try ropes with both types of rings on the glider end, as Hartley does at the towplane end.
But this means that normal wear will be on both and a break will lose both ring types.
Old October 31st 17, 04:38 PM posted to rec.aviation.soaring
If the glider needs the smaller ring, it's a 30second swap, if that.
Pilot is supposed to have the adaptor by the glider when he is getting ready to launch.
Old October 31st 17, 04:46 PM posted to rec.aviation.soaring
Ron Gleason
The extra Schweizer ring will bang on the fuselage and possibly cause gelcoat or other damage. In my experience weak links with a single ring are quick to switch out using a simple girth hitch https://www.netknots.com/rope_knots/girth-hitch
YMMV
Ron Gleason
Old October 31st 17, 05:06 PM posted to rec.aviation.soaring
The incorrect hooking up of a small Tost ring on a Schweizer tow hook is a known hazard of this practice.
UH
Old October 31st 17, 06:30 PM posted to rec.aviation.soaring
Having both types of rings on the same tow rope (glider end) can, as the previous post noted, cause damage to the fuselage. In addition, the Tost rings can interfere with the operation of a Schweizer release. Not recommended.
Old October 31st 17, 06:52 PM posted to rec.aviation.soaring
Yep, nicer way to explain what we use. Wrap the loop on the end of the adaptor rope through the big ring, then pass the rest through and pull snug.
The length of the adaptor rope keeps the big ring off the fuselage, also makes it easier to find in the grass when not in use.
Tost Rings Scott Calvert[_3_] Soaring 5 November 11th 14 10:17 AM
TE Probe O-rings vontresc Soaring 1 May 7th 10 12:56 AM
Dual tow rings brianDG303[_2_] Soaring 0 November 28th 09 01:06 AM
Dual tow rings brianDG303[_2_] Soaring 1 November 27th 09 10:15 PM
Libelles & Tost Rings nowhere Soaring 9 July 21st 04 05:08 PM
