Std. 2 Jantar - CG Tost hook?
Old November 26th 17, 01:03 AM posted to rec.aviation.soaring
Default Std. 2 Jantar - CG Tost hook?
The manual mentions that a CG hook can be mounted on the landing gear. Does anyone have instructions from the factory on that process?
Thanks
Phil
Old November 26th 17, 03:00 AM posted to rec.aviation.soaring
Frank Whiteley
Thanks
Phil
Can't comment on that approach. I had a share of a Jantar Std 2 in the UK several years ago. It would back release at about 700agl during a winch launch. The BGA senior inspector rotated the hook 2-3 holes. After that it went to the top of the launch.
Frank Whiteley
Old November 26th 17, 04:06 AM posted to rec.aviation.soaring
That’s an interesting approach to the problem. I mounted a Tost hook on the landing gear of my HP18 and that worked great. Since this is a certified aircraft I’ll have to check with our AME. I anticipate that the factory will have the mounting info given it was an option. Thanks for input.
Phil
Old November 26th 17, 08:18 AM posted to rec.aviation.soaring
Justin Couch
Thanks
Phil
It is basically a mount already welded into the gear and two bolts through it. The cable is a separate item off the main pulley below the instrument panel. Inside the seat pan area, you need a large rounded cutout to allow it to swing up with the undercarriage. Typically there is a FRP piece that is bonded into the fuselage to cover the hole. All the Jantars I have seen had this built in from the factory, but it may have been optional if yours never came with the CG hook. I should be able to find the right TOST part number. Do already have a hook and just need to know all the fittings?
Also, I recommend you join up the Jantar group over on Yahoo as there's a lot of drawings and useful paperwork there.
Old November 28th 17, 07:39 AM posted to rec.aviation.soaring
Eric Munk
It’s a G72 according to the TCDS from EASA, but a G73 or G88 is also
technically speaking compatible. I am rebuilding one that has a CoG release
so if you need pics send an email...
gear.
Do=
Thanks=20
Phil
through
p=
it=
is=
ha=
ne=
num=
ber. Do already have a hook and just need to know all the fittings?=20
l=
Old November 28th 17, 09:11 AM posted to rec.aviation.soaring
David Salmon[_3_]
releas
gear.
Do=
Thanks=20
Phil
through
instrument
p=
it=
is=
ha=
ne=
num=
a
l=
My syndicate partner has just confirmed that they fitted a c of g hook to
their Std Jantar, by buying a new u/c frame with a hook on it. That of
course was from the original manufacturers 40 years ago.
Dave
Looking to buy Tost hook [email protected] Soaring 2 March 4th 17 01:02 PM
Tost tow hook STC for C-182 ? [email protected] Soaring 6 September 27th 16 01:13 AM
Jantar standard SZD-41A C.G. hook Žiga Munda Soaring 3 November 24th 15 02:00 AM
Cessna 185 with a Tost hook? Nimbob Soaring 1 September 29th 09 12:43 PM
Tost hook on Cessns 180 Paul Soaring 6 October 18th 04 10:32 PM
