Relieving in flight
Old December 21st 17, 02:56 AM posted to rec.aviation.soaring
Default Relieving in flight
Ok guys, this has probably been covered in older posts but what are you all using regarding urinary relief on long flights? Ive used gallon ziplock bags in the past but whats your experience with cathaters. What brand and how are they.
Old December 21st 17, 03:16 AM posted to rec.aviation.soaring
MNLou
In my LAK17a, I use Coloplast Conveen Optima condom catheters connected to tubing (via two one way valves) and a 4 liter collection bag behind my seat.. I keep the bag in a waterproof outer bag "just in case)" You need to empty and rinse the bag every flight (obviously).
There are long and short versions of the condom catheters. I find the shorts hold just fine and are much easier to remove.
I'm pretty happy with that set up. It is a bit more convenient to have the tube run outside your glider via an external hole (as it did in my PW-5) but you do end up with a dirty glider and getting urine corrosion on any parts it hits / gets sucked up into.
Lou
Old December 21st 17, 03:21 AM posted to rec.aviation.soaring
I like the "overboard" option. There's a few guys I would have liked to "pee" on thermalling below me lol.
Old December 21st 17, 03:25 AM posted to rec.aviation.soaring
son_of_flubber
The external catheters use an adhesive. Selective manscaping pays off at the end of the day.
Old December 21st 17, 03:29 AM posted to rec.aviation.soaring
Gees, I dont know if I like that "adhesive" idea.
Old December 21st 17, 04:01 AM posted to rec.aviation.soaring
JS[_5_]
I wouldn't want to use anything but an external catheter plumbed to the outside world, preferably in a system that the urine does not contact the glider. Seems best to install a conduit to push a tube attached to the catheter through, extending it beyond the laminar flow.
Using a "hand-held device" while driving a car is considered bad. It should be at least as bad while flying?
The adhesive is far less sticky than a "band aid".
Old December 21st 17, 04:33 AM posted to rec.aviation.soaring
Tim Taylor
Several options available in addition to the adhesive condom catheters.
1. Inflatable condom catheters. Reusable and non-adhesive.
2. Zip lock bags with adsorbant pads. These work well if you are not needing to urinate on all flights, but want something in case you need one.
Old December 21st 17, 05:57 AM posted to rec.aviation.soaring
Non adhesive conveens with a little velcro tie wrap. Dont laugh - Ive been using that for over 30 years with no inflight mishaps - and I re-use the conveens many times. Rinse, hang to dry, dust inside and out with a very small amount of talc and roll up over a tube sized to give just a little stretch. A box of 30 lasts about a decade (I'm on my third). Too much information??
Old December 21st 17, 09:32 AM posted to rec.aviation.soaring
Paul Ruskin[_2_]
How far out do you need to go for the urine to miss the glider?
Transfix external catheters, with an external tube (from the BGA website for the Brits) work well for me.
Paul
Old December 21st 17, 01:08 PM posted to rec.aviation.soaring
I have the adhesive catheter/overboard system. It works great. The tube exits the fuselage bottom a bit off center. I just put a little rudder in to yaw the ship when necessary. This seems to keep the stream of the bottom. Pour some water through at the end of the day to keep things clean. One consideration is the temperature. You don't want the tube clogged with a frozen block of urine. My solution is a second length of tubing with a quick disconnect. When finished dumping ballast I disconnect the catheter, connect the second tube and blow air through and then re-connect the catheter. I've heard of a t-connector being used for the same purpose. As mentioned in another thread, there seem to be two types of catheters - those that won't stay on and those that won't come off. The second is better. There is a liquid called Detachol that releases the adhesive pretty much instantly. Goo Gone might do the same thing but Detachol is made specifically for this purpose. Check the archives, this topic has been discussed thoroughly in other threads.
IGC Flight Recorders using Flarm firmware - New DLL file forvalidating IGC flight data files Ian Strachan Soaring 0 July 20th 14 07:28 PM
New 18m Class ship - First Flight - The JS1 starts proving flight phase [email protected] Soaring 2 December 14th 06 02:06 AM
NEW FLIGHT SCHOOL - Best in Flight Aviation Academy - Morristown,New Jersey Dave Vioreanu Piloting 0 April 22nd 05 02:55 AM
NEW FLIGHT SCHOOL - Best in Flight Aviation Academy - Morristown, New Jersey Guy Elden Jr Piloting 0 April 21st 05 04:37 PM
Does anybody know a link to a real picture of the X-43 in flight sans Pegasus or better yet a video clip of the flight? Scott Ferrin Military Aviation 0 April 3rd 04 08:47 PM
