On Sunday, January 14, 2018 at 5:33:15 AM UTC-5, Dave Nadler wrote:
On Sunday, January 14, 2018 at 8:32:19 AM UTC+13, Tony wrote: My experience in the Electro in Uvalde and Kansas is that motor temp becomes an issue well before battery and controller temp. Depends on the machine. Antares has better motor cooling, but batteries start to get hot and require early shutdown at Uvalde for example (I typically shut down 800-1000 ft). Perhaps cooling for enclosed FES motor isn't as good? See ya, Dave Pylon mounted motor will obviously cool much more easily than enclosed motor cooled through a small hole. Each concept has it's trade offs. UH |
I wonder if one of these Sun Flyer trainers might work out? I like the engine of the 4 seater and the wing area of the 2 seater.
http://sunflyer.com/specifications/ Sure looks similar to the Dynamic Rotax powered towplane. |
On Thursday, January 18, 2018 at 9:25:57 AM UTC-5, Eric Greenwell wrote:
wrote on 1/17/2018 9:53 AM: I wonder if one of these Sun Flyer trainers might work out? I like the engine of the 4 seater and the wing area of the 2 seater. http://sunflyer.com/specifications/ I estimate they would have nearly the same climb rate with a 1000 lb sailplane, so the much lower cost of the two seater would make it more attractive to most operations. A "towplane version" might have a bigger battery pack for extra duration without recharging, since it wouldn't need to carry baggage while towing. And it ought to be easy to find towpilots - very zoomy, trike gear and no worries about shock cooling the cylinders! -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 - "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm http://soaringsafety.org/prevention/...anes-2014A.pdf Could one recover some of the energy by using the motor as a generator on the way down - akin to regenerative braking on hybrid cars? Uli 'AS' |
![]() Pylon mounted motor will obviously cool much more easily than enclosed motor cooled through a small hole. Each concept has it's trade offs. UH Pylon mounting is the way to go. The FES self-launchers are VERY tricky to launch on a grass field because the prop tip is just a few inches off the ground. I have watched a friend blow up his prop on a grass field with just small bumps in it. I like the new Polish GP series. The electric motor extends and retracts in just 4 seconds! Too bad there is a 2 year wait. The batteries are adequete now and will get better. There is a huge worldwide effort now to improve them. |
On Tuesday, January 9, 2018 at 6:30:12 PM UTC-5, Nick Kennedy wrote:
Is this the future? No more shock cooling here! https://newatlas.com/siemens-airbus-...-glider/48806/ Energy regeneration idea raises an engineering problem: how do you optimise the total energy used? A well designed prop for traction ( 80-90% power transfer) will be pretty poor as a wind turbine . A PhD to be won for designing a prop which maximises the energy transfer. This includes glider in the equation. JMF |
360 HP Electric Extra Sets Climb Record | Larry Dighera | Piloting | 0 | December 9th 16 10:08 PM |
Siemens' 110 lb world-record electric aircraft motor produce 348 hp at 2,500 RPM | Larry Dighera | Piloting | 29 | December 2nd 15 08:29 PM |
electric speed record (141kts) with a cricri | Philippe[_4_] | Home Built | 0 | September 13th 10 07:31 AM |
