Looping a standard cirrus
Old January 22nd 18, 03:10 AM posted to rec.aviation.soaring
Default Looping a standard cirrus
Again,
ALL gliders are certified to a standard to withstand specified loads.
The standard cirrus is made before JAR 22 standards were published but for most gliders in the last twenty years, they are certified in the JAR 22 Utility standard.
The load limits at Va are +5.3G and -2.65G
JAR 22.3 states that gliders in the Utility category are cleared for spins, lazy eights, chandelles, stall turns, and positive loops.
A properly flown positive loop uses only +3.5Gs.
The plane is not the problem.
The problem is the pilot who does not know how to fly a loop and does not know how to gain control of the aircraft if a manuver fails so that the aircraft is not subjected to loads beyond +5.3G and -2.65G. Also, these are loads that are without twisting loads. A snap roll is out of the question.
  #32
Old January 22nd 18, 12:05 PM posted to rec.aviation.soaring
On Monday, January 15, 2018 at 7:57:46 PM UTC-5, wrote:
Who has done a loop in a standard cirrus? Any comments or hints. Currently getting some acro training with the goal of looping my cirrus.
I owned a Standard Cirrus back in the early 80's and she would loop just fine. Don't pull too hard you will hear a nasty noise from the spoilers flapping.
Standard Cirrus Walt Connelly Soaring 10 December 31st 11 04:03 PM
Standard Cirrus Walt Connelly Soaring 23 March 20th 11 03:14 AM
Standard Cirrus C-Hook Randy[_2_] Soaring 26 September 26th 08 10:24 PM
Standard Cirrus Don Burns Soaring 0 January 10th 07 05:24 AM
F/S - Standard Cirrus 75 Bob Soaring 0 October 4th 04 12:23 AM
