best location for boom mike
Old January 31st 18, 12:51 AM posted to rec.aviation.soaring
Matt Herron Jr.
Default best location for boom mike
Any thoughts on what the best location is for a boom mike in an ASW27? Currently the mount point is right behind my right shoulder, and when I bend it up, the gooseneck is pinched between my arm and the cockpit edge. not comfortable.
Also, do folks like one speaker or two?
This might be a religious question, but do you prefer a boom mike or headset, and why? I have really only used a headset to date.
Thanks,
Matt
Old January 31st 18, 01:13 AM posted to rec.aviation.soaring
Thanks,
Matt
On ASW-27 I used to fly with did not have a boom mike, he just had a small panel mounted mic, it was about 12mm across or less (dime sized). Got rid of all the stupid boom business that adds weight and cramps up the cockpit. I'd consider this a good option, it worked well, he just had to project his voice and no problems.
Old January 31st 18, 02:14 AM posted to rec.aviation.soaring
George Haeh
I have the boom pass under my upper arm. People have no trouble hearing
me.
Old January 31st 18, 02:22 AM posted to rec.aviation.soaring
I installed a mike in the panel of my '27 and love it. I just speak as in a two seater and I come in loud and clear. Works great standing next to the glider with canopy open as well. The URL I have for segelflug.de no longer works, but I have the seller's email address if you contact me directly.
As for speakers, i have 3. Radio and secondary vario in the right speaker compartment. Primary vario speaker is in the left speaker compartment.
5Z
Old January 31st 18, 06:33 AM posted to rec.aviation.soaring
JS[_5_]
5Z
Mine has the boom mic mounted backwards, so it doesn't interfere with your shoulder or arm.
Using one speaker for radio and a DPDT switch to assign one of the two varios to the other speaker. Works well.
Old January 31st 18, 01:55 PM posted to rec.aviation.soaring
Matt:
My 27 came with a boom mike, but rather than replacing it (yes it was very uncomfortable to turn my head right when trying to speak into the mike), I just installed plugs for a headset (and switches to select boom mike or headset) and used the only the mike on the headset...
Best regards
Enrique
KO
Rewiring boom mike for ASW27 [email protected] Soaring 13 December 7th 14 12:50 AM
Rogue's Gallery Update - Mike R's Helio & Mike G's Saratoga Jay Honeck Home Built 1 December 3rd 04 09:16 PM
Rogue's Gallery Update - Mike R's Helio & Mike G's Saratoga Jay Honeck Owning 0 December 3rd 04 08:25 PM
Icom Boom Mike Kevin Neave Soaring 2 September 25th 03 09:39 AM
Boom-mike cannula Jay Products 3 September 19th 03 03:10 PM
