Powered up an old Cambridge GPS Nav today and the LCD Display gives me the warning to check the LCD Cable.
Having done this, made a new cable etc, I have still got no solution to the problem. Any suggestions other than the rubbish bin? ![]() Cheers |
On Thursday, February 15, 2018 at 7:48:25 AM UTC-5, Ross wrote:
Powered up an old Cambridge GPS Nav today and the LCD Display gives me the warning to check the LCD Cable. Having done this, made a new cable etc, I have still got no solution to the problem. Any suggestions other than the rubbish bin? ![]() Cheers Commonly one of the sockets has a problem. Look closely at both. Also do the "stupid" check of making sure the cable has the connectors oriented right. Look at the diagram in the manual carefully and compare. Good luck UH |
Take the "Windows" approach. Try plugging and unplugging the connector more than a few times. Might be some light corrosion on contacts. Make sure the cable is made correctly. If you have the hardware, try the same logger and cable with a different display. If that doesn't work, post the whole thing to me when you get another batch of radios for me to buy.
Steve Leonard |
....And shoot some contact cleaner in the sockets and on the pins before
Steve's plug/unplug exercise. On 2/15/2018 6:38 AM, Steve Leonard wrote: Take the "Windows" approach. Try plugging and unplugging the connector more than a few times. Might be some light corrosion on contacts. Make sure the cable is made correctly. If you have the hardware, try the same logger and cable with a different display. If that doesn't work, post the whole thing to me when you get another batch of radios for me to buy. Steve Leonard -- Dan, 5J |
Problem kinda solved. Thanks for the tips.
When powering the LCD up I need to hold the GO button. Works fine. If I don't do this it requires a cable check. No idea why but I can live with it the way it is. |
| WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario | ufmechanic | Soaring | 0 | March 24th 09 06:31 PM |
| Cambridge 302 & PDA -- Value of adding Cambridge 303? | V1 | Soaring | 5 | July 31st 07 04:51 AM |
| Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 | Nathan Whelchel | Soaring | 4 | July 6th 04 12:22 AM |
| FS Cambridge CAV-II | WDM | Soaring | 2 | March 27th 04 02:55 AM |
| Cambridge "V" | JJ Sinclair | Soaring | 0 | March 11th 04 03:01 PM |
