FSG71M question
Old February 27th 18, 02:10 AM posted to rec.aviation.soaring
AS
Default FSG71M question
Does someone know how to change the memory battery of a FSG71M radio? There seems to be an upper and lower cover on it, each held on by four (4) screws. Is the battery hiding under one of those?
Also, what battery type is it? Is it a type that is freely available or is it a super-special one?
Thanks,
Uli
Old February 27th 18, 03:41 AM posted to rec.aviation.soaring
Roy B.
Uli:
If you search for the post "Dittel radio servicing" you will see entries from several guys who did it.
ROY
Old February 27th 18, 01:59 PM posted to rec.aviation.soaring
AS
On Monday, February 26, 2018 at 9:41:44 PM UTC-5, Roy B. wrote:
Uli:
ROY
Thanks, Roy!
Contact info '3U' - Dittel FSG71M Morten Bach Soaring 1 February 24th 13 08:30 PM
Memory battery for Dittle FSG71M Ray Gimmey Soaring 14 December 29th 06 01:13 PM
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 07:39 PM
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good Excelsior Home Built 0 April 22nd 05 02:11 AM
Question about Question 4488 Paul@Rasdoc.com Instrument Flight Rules 3 October 27th 03 02:26 AM
