Public ADS-B Performance Report Request
Old March 6th 18, 11:21 PM posted to rec.aviation.soaring
son_of_flubber
Default Public ADS-B Performance Report Request
If you have installed ADS-B out or TABS, you will be interested in this
https://adsbperformance.faa.gov/PAPRRequest.aspx
Old March 7th 18, 12:59 AM posted to rec.aviation.soaring
Craig Funston[_3_]
Thanks Flub,
It was on my list to track that down.
Cheers,
Craig
7Q
Old March 7th 18, 01:08 AM posted to rec.aviation.soaring
Dan Marotta
Got a report yesterday on my new ADS-B Out/In in our Skywagon. Perfect
performance!
Thanks Flub,
Cheers,
Craig
7Q
Dan, 5J
Old March 7th 18, 01:11 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
No Trig TT21? Isn’t that a valid TABS device?
Andy
Old March 7th 18, 01:22 AM posted to rec.aviation.soaring
Darryl Ramm
I highly recommend folks run these reports for their gliders with ADS-B Out installs, both 2020 Compliant and TABS installs.
But if if you glider has a SIL=1 TABS install the report will flag multiple GPS source integrity errors, that is normal. NIC, NACp, SIL, SDA will be flagged/marked red. For TABS make sure SIL and SDA show up as an average of 1.0 in the Integrity and Accuracy table
If your glider has a SIL=3 2020 Compliant install it should not be flagged for anything.
Make sure the install SIL level is appropriate for your glider, you cannot use a TN72 with SIL=3 in a certified glider. And yes it will get discovered easily by the FAA (no ADS-B Out '337 on file for that aircraft).
The ADS-B performance report is a useful report to check everything is OK, aircraft type is glider, ICAO ID is correct, N-number is correct etc. If you are doing a TABS install in any type of glider, or a 2020 Compliant install in an experimental glider there is no formal notice/verification action to the FAA required.
For a 2020 Compliant ADS-B Out install in a type certified glider (with a TN70+TT22 not a TN72 GPS Source, and not a TT21 transponder) your A&P IA needs to submit a '337 for the ADS-B Out install, based on the existing Peregrine/TT22 STC (available for free via Trig dealers). That certified aircraft install would normally include a formal verification flight (not required for any other installs mentioned above). A&P IA who want to navigate the details can start with FAA Policy N 8900.362. Yes it says it's expired, no it's not and is still in effect. This is what guides every FSDO with ADS-B Out installs. Glider owners should probably find a glider A&P IA who knows what they are doing here or willing to learn vs. trying to contact a FSDO themselves to ask questions.
https://www.faa.gov/regulations_poli...mentID/1029526
Old March 7th 18, 01:29 AM posted to rec.aviation.soaring
Darryl Ramm
Andy
These reports were not designed for TABS devices, they are for 2020 CompliantADS-B Out devices which the TT21 is *not*.
But if you have a TT21 and doing a check yourself on your TABS system I just say it's a TT22 and then in the comments section say its really a TT21 configured for TABS/TCO-C199 and that this install is not seeking to comply with 14 CFR 21.225/227.
Even if its a TT22 but configured for TABS in a type certified glider I would also make a note that this is a TABS/TCO-C199 and is not seeking to comply with 14 CFR 21.225/227.
These reports will likely eventually noticed by FSDO staff and they might not understand TABS, if they do reach out to you use that as a chance to educate them/point them at TSO-C199. Or just point them at me, I'm happy to help.
Old March 7th 18, 02:01 AM posted to rec.aviation.soaring
Darryl Ramm
Andy
Old March 7th 18, 02:02 AM posted to rec.aviation.soaring
Darryl Ramm
Andy
Grr I meant 91.225/227 not 21.blah.
Old March 7th 18, 04:14 AM posted to rec.aviation.soaring
JS[_5_]
Andy
220, 221... Whatever it takes.
Old March 7th 18, 03:03 PM posted to rec.aviation.soaring
Dan Marotta
Who are you Darryl?
We've gotten a lot of good advice and information from you, and that's
much appreciated.Â* So is this a hobby for you or are you with the FAA,
an avionics supplier, consultant on the program, etc.? Your knowledge on
the subject seems vast.
Best,
Dan, 5J
NTSB crash report, autopsy report- Stevie Ray Vaughan Mark. Piloting 5 March 22nd 20 10:17 PM
America Wills Justice as Freedom for Our Stays The Rightardstates 'No Public Option! No Public Option!' Daryl Naval Aviation 0 May 14th 12 04:40 AM
Accident Report on Blue Angel #6 crash now released to the public Pensacola Beachcomber Aviation Photos 0 January 15th 08 07:42 PM
Public Announcement [email protected] Products 8 September 21st 06 04:43 AM
Complex / High Performance / Low Performance R.T. Owning 22 July 6th 04 08:04 AM
