Dittel FSG 2T Problem
Old March 8th 18, 03:21 PM posted to rec.aviation.soaring
Roy B.
Default Dittel FSG 2T Problem
I have 2 different Dittel FSG 2T radios with the same problem: The multifunction control on the front lower right (it is both a rotary knob and a push button) has become loose and hypersensitive. The radio changes frequency with the slightest touch. Anybody else have this problem? Or a solution for it?
Roy
Old March 8th 18, 05:54 PM posted to rec.aviation.soaring
Ross[_3_]
Hi Roy,
Unfortunately you are not alone and it is a common problem to this otherwise fantastic radio.
Basically the fix is to replace the rotary knob
Anton Lang in Germany do this, however the cost will be about €200 for it.
Dittel FSG 60M John Culp Soaring 5 May 17th 17 10:06 AM
Dittel Box Jim[_18_] Soaring 0 June 9th 15 05:15 PM
Dittel FSG 50 Karl Kunz[_2_] Soaring 6 June 25th 12 12:21 AM
Dittel FSG 50 in Dittel base station [email protected] Soaring 2 February 18th 09 09:15 AM
Dittel FSG 50 in Dittel base station, Perfect for crews and FBO [email protected] Soaring 1 February 18th 09 09:15 AM
