First glider to buy 10-20k euro's
Old March 16th 18, 12:18 PM posted to rec.aviation.soaring
Default First glider to buy 10-20k euro's
Hi Senna,
not sure how good your German is, but I wrote a test about the LS1-f: https://www.segelflug.de/tests/LS1/index.html. Google translate might help, too.
If you have the chance, fly an LS4. The LS1-f is very similar - it has a bit higher control forces and an even better feel of the thermals.
As any glider of its vintage, an LS1-f has its flaws. Besides the usual items (gelcoat, cracks, paperwork). You should check the following items in particular:
- transition between vertical tail and fuselage boom: the bulkheads are a bit weak and tend to break or get loose. This is a quite common problem with the F. Check for cracks in the gelcoat. When rigged, twist the fuselage boom by slightly pushing the top of the vertical tail to the side. If it has a "soft" feel, there might be an issue. Preferrably take an LS1-f that has been repaired in this area. Unfortunately, the repair requires quite some work to do.
- if it sits low on the ground, the springs of the gear are worn and need to be replaced. This is an unexpensive fix (~120€ for the parts + 1 day of work)
- some F have the undercarriage modified to LS4 standard, containing a gas spring in the pushrod. This may wear, causing the gear to collapse. If you can, take someone who knows LS4 from your club. She or he should take a closer look at the whole gear assembly.
- as with many other gliders, the lift pins tend to wear over the years. During 3000h livetime extension, they often have to be replaced. Repair needs to be done in a professional workshop.
- check the play of the lift pins and how many washers are used to reduce it. It is okay to use up to 0.5mm of washers in total on all lift pins.
- check the canopy lifting mechanism for excessive play. Repairs may need some welding.
- levers of the main wing pins should be fastened. They are kept in place through rivets or screws which may loosen over time. It's an easy thing to repair.
- the forward attachment point of the horizontal stabilizer is done with a rod end. This has to be glued in place
- check how old the l'Hotellier connectors are. In EASA-land, they have to be replaced after max. 3000h (which actually is not a bad thing to do). A complete set of connectors is about 1600€
Best regards,
Christoph
Old March 16th 18, 12:28 PM posted to rec.aviation.soaring
I do not have so much experience with the Libelles, but things I remember:
- As with all Glasflügels: Check if the connection between the main pins and the wing spar stubs is okay (http://streifly.de/TM201-31.pdf). Repair needs a professional workshop
- check the ailerons for excessive play. That's a quite common issue with the Libelles. In many cases, a fix requires sending the aileron drives to Streifeneder
- check for play in the lift pins. This cannot be removed with washers as with the F, but the pins will have to be replaced
- check the air brake drive for free movement
- check the elevator drive for play and any hidden cracks
- check if all the AD have been taken care of
Best,
Christoph
Old March 16th 18, 12:36 PM posted to rec.aviation.soaring
Tango Whisky
Le vendredi 16 mars 2018 11:40:19 UTC+1, Senna Van den Bosch a écritÂ*:
I do have a few hours in the Pegase but they are slightly out of budget at about 5-10k more than I would like to spend.
On www.planeur.net there are 2 Pégase listed for sale, both about 15k.
Old March 16th 18, 01:39 PM posted to rec.aviation.soaring
Tango Whisky
Le vendredi 16 mars 2018 13:36:10 UTC+1, Tango Whisky a écritÂ*:
Just to add: I think that getting spare parts from SN Centrair could be a bit tricky. They are no longer into making sailplanes, so their attitude to customer service in this part of the market may be lacking.
Old March 16th 18, 03:02 PM posted to rec.aviation.soaring
Tom BravoMike
After having spoken to a few DG/Libelle/Cirrus owners I am really considering the Libelle. What would be the points to look out for when buying one, in your opinion?
In the Wikipedia article:
https://en.wikipedia.org/wiki/Glasflügel_H-201
it says:"they are quite sensitive to sideslipping and have relatively ineffective air brakes that make short landings tricky for inexperienced pilots".. I wonder what 'sensitive to sideslipping' means in this case.
Old March 16th 18, 03:29 PM posted to rec.aviation.soaring
Senna Van den Bosch
Op vrijdag 16 maart 2018 16:02:13 UTC+1 schreef Tom BravoMike:
it says:"they are quite sensitive to sideslipping and have relatively ineffective air brakes that make short landings tricky for inexperienced pilots". I wonder what 'sensitive to sideslipping' means in this case.
From what I've heard is that performance decreases very fast when you slip it. So you must fly it pretty accurate with the string in the middle.
Old March 16th 18, 03:31 PM posted to rec.aviation.soaring
Due to the shape, the fuselage should be well aligned with the flow to prevent seperations. But from my experience with this glider, it is not really a big issue. What I found more noteable was the inefficency of the rudder and the ailerons, in particular at low airspeeds. When entering a strong thermal, you sometimes need to speed up to get her into the turn. That is clearly not necessary with the LS1-f. But many people like Libelles, too. It certainly looks nice. So to each his own.
The airbrakes of a Std. Libelle are indeed not very effective. But this is something you get used to. It is the same with ASW19 and Std. Cirrus, unless they were modified with a second panel. There are approved modifications for these two models, but not for the Libelle. Some early Std. Libelles had top- and bottom airbrakes which should work better. All LS1 have quite powerful airbrakes, they work even better compared to the double-panel brakes of an ASW19.
Old March 16th 18, 04:11 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Pass. Mine has no bad habits when slipping and tends to come out of the
slip at the same speed as it went in, assuming that was the trimmed
speed. It does comes down fast in a full-blooded slip thanks all the drag
generated by pushing that razorback tail boom sideways. This compensates
nicely for the relatively weak airbrakes - but even Libelle brakes scrub
off height quite nicely if you push the nose down.
About the only thing a pilot needs to watch is that a fully held-off, two
point landing is a little trickier than in, say a Pegase, Discus or
Junior because the brakes aren't doing a whole lot after you've flaired.
So, if you're a little quick to lift the nose to the two point attitude
the glider will balloon. A lot of pilots put Libelles down on their main
wheel for this reason, but unless you're asleep behind the stick its easy
enough to correct for the balloon without making a hard landing.
That said, I usually do two pointers with mine because I like the feeling
of both wheels touching the ground simultaneously and staying down. But
it did need a bit of practise at first.
Martin | martin at
Gregorie | gregorie dot org
Old March 16th 18, 04:14 PM posted to rec.aviation.soaring
middle.
True enough, but the same applies to all gliders. You'll soon learn to
fly a Libelle with the string straight because it that: its no harder to
fly straight than any other glider, and it does like the string to be
pointing out slightly in a thermal turn.
Martin | martin at
Old March 16th 18, 04:23 PM posted to rec.aviation.soaring
On Fri, 16 Mar 2018 08:31:34 -0700, christoph.barniske wrote:
Some early
Mine is one of these. I've also flown a B series in the distant past and
don't think there's much handling difference between mine with top and
bottom surface brakes and the B-series with single surface ones.
Note that most Std. Libelles are B-series, with foam in the wing skins,
water bags, top-surface brakes and a revised tailplane. The first B-
series was probably s/n 182, but the change-over was gradual, starting
from s/n 85.
Martin | martin at
How to Buy a Glider Afordably, or Euro vs ContraFund [email protected] Soaring 22 December 1st 05 09:01 PM
How to Buy a Glider Afordably, or Euro vs ContraFund keithw Soaring 0 December 1st 05 04:07 AM
Euro vs Contrafund Update, or How to Buy a Glider Affordably [email protected] Soaring 6 July 7th 05 05:07 AM
Euro vs Contrafund, or how to buy a glider (affordably) [email protected] Soaring 2 March 27th 05 07:46 AM
Euro-fighter? Bryan Military Aviation 2 October 29th 03 04:01 PM
