cockpit exit assist for older pilots
Old March 16th 18, 11:20 AM posted to rec.aviation.soaring
Default cockpit exit assist for older pilots
If you have a good Dive Shop in the area and go in and explain what you are trying to do they might be about to modify a BC (buoyancy compensator) that you could sit on and then inflate to lift up. They certainly will have bottles of different sizes, small ones used to emergency air could be your air source. May be a bit of a stretch, but if you have a good shop could be worth the conversation time spent.
Kevin
92
  #42
Old March 17th 18, 02:18 AM posted to rec.aviation.soaring
Scott Williams
Kevin
92
what about a lawn tractor inner tube with the valve core removed and a can of tire inflator (without any sealer) might cost less than $50 and be small and portable.
  #43
Old March 18th 18, 01:43 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
wrote on 3/11/2018 8:32 PM:
Not sure if the comment was serious or gently humorous but strength training does make a big difference. The ASW 24 I've owned for 26 years has the deep cockpit characteristic of later (safety) Schleicher designs and it's somewhat more effort to hoist myself up now. If I didn't work out at the gym several times a week or focus on maintaining my weight through diet and running, it would be a real challenge to exit gracefully, especially wearing my parachute, as I always do. OK, maybe it's not so graceful , but I can still do it at age 66. And strength training is one reason why.
Especially pushups and tricep dips on chairs - still getting out of my ASH 26 E at
75, and still doing it without removing the parachute, as I want to be strong
enough to bail out. Maintaining a good weight, diet, and other exercise is good,
too, and makes those long flights safer and more enjoyable.
- "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm
http://soaringsafety.org/prevention/...anes-2014A.pdf
  #44
Old March 19th 18, 03:19 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Bikram yoga
OLDER PILOTS PERFORM BETTER, STUDY FINDS Larry Dighera Piloting 16 March 21st 07 02:11 AM
How do you exit a F-22 cockpit? John Dallman Naval Aviation 1 May 28th 06 02:51 PM
How do you exit a F-22 cockpit? Mike Naval Aviation 11 May 25th 06 08:01 PM
Older Pilots and Safety Bob Johnson Soaring 5 May 21st 04 01:08 AM
Glass Cockpit in Older Planes Charles Talleyrand Owning 2 May 20th 04 01:20 AM
