For Sale M&H KF-011 Oxygen Bottle
Old March 20th 18, 08:08 PM posted to rec.aviation.soaring
Bryce Sammeter
Default For Sale M&H KF-011 Oxygen Bottle
For Sale, M&H lightweight KF-011 Kevlar fiber wrapped oxygen bottle. Came as a spare with glider purchase. Manufactured 9/2011 and looks brand new and appears to possibly be unused. Installed CGA-540 valve with pressure gauge.. Appears to need hydro. Will ship for free in U.S., Discounted shipping abroad. Retails for $665 new from M&H, Asking $390 O.B.O
Old March 20th 18, 09:40 PM posted to rec.aviation.soaring
M&H or MH?
I believe M&H does repairs (Elmira, NY), MH is Mountain High and does O2 systems.
Old March 20th 18, 11:02 PM posted to rec.aviation.soaring
Bryce Sammeter
MH
Old March 22nd 18, 06:48 AM posted to rec.aviation.soaring
glidergeek
Dimensions?
Old March 22nd 18, 09:21 AM posted to rec.aviation.soaring
David Sherrill
On Thursday, March 22, 2018 at 2:48:28 AM UTC-4, Glidergeek wrote:
Dimensions?
http://www.mhoxygen.com/index.php/cylinders/kevlar
or
http://www.mhoxygen.com/index.php/co...s/download/118
Description (F): KF-011, For built-in soaring aircraft & EDS portable applications
Diameter: 9.3cm. (3.62 inch)
Length: 48.5cm. (19.1 inch) (without valve) add 2" for valve
Avg. Weight: 1.0 kg. (2.4 lbs)
Max. Volume: 311 liters (11 cu. ft.) @ 128 bar (1850 psig.)
THREADS: 3/4-16 UNF (SAE-8)
Old March 22nd 18, 02:22 PM posted to rec.aviation.soaring
Bryce Sammeter
Dave, you beat me to it. Thanks.
Old March 22nd 18, 03:29 PM posted to rec.aviation.soaring
glidergeek
Thanks guys, i've got a DG 600 with an oddball size hole for the O2 bottle.. I put a 13 cu" aluminum bottle in the hole and I have to wrap it, in my case I use a bit of felt seems like it's about an inch and a half too small for the hole. Sounds like this bottle is even smaller diameter.
Old March 23rd 18, 12:42 PM posted to rec.aviation.soaring
OHM Ω http://aviation.derosaweb.net
Couple of things;
Measuring O2 bottles. I had a devil of a time finding one to fit my ASW-27.. Someone would say it had a diameter of X which should have fit only to find it did not as measuring a cylinder's (sleeve's) diameter is tricky without a outside (inside) caliper. I finally determined that the best way to accurately know if someone's bottle would fit my sleeve was to give them my required circumference.
Ill fitting bottles in oversized sleeves. A friend had this issue and used some large diameter plastic plumbing tubing from the hardware store. Took a few goes to get the right size. For this to work depends on the type of bottle clamp you have. The type that grabs the bottle's neck works for this solution. The one that clamps the bottle's body does not. I prefer the neck type found in my old DG as more secure but I have the body type in my ASW. ;-(
My $0.02.
- John OHM Ω
Old March 23rd 18, 03:21 PM posted to rec.aviation.soaring
Dan Marotta
If your ship is licensed as an experimental, you could fabricate (or
have it done) a steel stop, bent into an "L" shape with a semicircular
cut at the top sized to the external dimension of the neck of the
bottle.Â* This could be bolted down with the bracket holding the bottle
in place.Â* Just thinking...
On 3/23/2018 6:42 AM, OHM Ω http://aviation.derosaweb.net wrote:
Couple of things;
Measuring O2 bottles. I had a devil of a time finding one to fit my ASW-27. Someone would say it had a diameter of X which should have fit only to find it did not as measuring a cylinder's (sleeve's) diameter is tricky without a outside (inside) caliper. I finally determined that the best way to accurately know if someone's bottle would fit my sleeve was to give them my required circumference.
My $0.02.
- John OHM Ω
Dan, 5J
Old March 29th 18, 06:31 PM posted to rec.aviation.soaring
Kelvyn Flavall
Is the oxygen bottle still available?
Oxygen bottle for ASW 27 and ASG 29 [email protected] Soaring 8 April 18th 16 04:08 PM
Oxygen Bottle Roger Fowler[_2_] Soaring 2 November 19th 11 09:17 PM
WTB: Oxygen bottle Jason Kramb Soaring 5 February 2nd 11 03:33 AM
oxygen bottle No Name Piloting 2 May 23rd 07 07:09 AM
DG-400 Oxygen Bottle Problems [email protected] Soaring 23 September 8th 05 10:43 PM
