#141
![]() "Bernardz" wrote in message news:MPG.1b64d7dd88d46ca0989ae3@news... In article 40fa0ce6$0$1289$5a62ac22@per-qv1-newsreader- A fighter is much smaller, more mobile and generally faster then a bomber. Finding a bomber and recognizing it was hard enough in WW2 how successful were fighters in finding and identifying interceptors at night? By the end of the war they were extremely succesful.One tactic widely used was for the intruders to fly around the NF base. As the airctaft came in to land or took off the Mosquito would swoop in for the kill. By the winter of 1944/45 there were mor intruders flying than German night fighters and they were considerably faster. By the time you loaded down an Me-110 or JU-88 with its heavy guns, radar and antennae it was rather slow and didnt handle at all well. Keith |
#142
![]() "WalterM140" wrote in message ... The USA had zero combat experiencewith the B-17 in 1941 and sold the B-17 on the basis of the self defending bomber. It failed in 1941 and again when the USAAF tried it in 1943. Yeah. Well we expect our political leaders to keep us out of war [excepting the present blithering idiot in the White House] . But you're implying that the US should have been bailing you out a long time before 1941, I am thinking. Nope I'm simply pointing out that by 1941 the RAF had 2 years of experience in air warfare and the US had none. The Americans were ultimately able to make daylight precision bombing pay off, although not the way they intended, that is true. Indeed. Keith |
#143
![]() "WalterM140" wrote in message ... The Brits ignored American advice on how to use the B-17. Admittedly, the B-17C was not ready for the big leagues. Could that be why they ignored the advice? Perhaps. I'll suggest that there was -no way- given the British experience in WWI that they were going to the heavy daylight bomber route in WWI. And I don't blame them a bit for that. You are as usual wrong I think after all that 'Henry V'/'over the top' stuff in WWI, the Brits were bound and determined to try a litte brain power the second time through. B-17's were not going to help them that much in that particular endeavor. The British bad experience with daylight bombing was a result of trying it in 1940 and taking 80% losses against the Luftwaffe. Keith |
#144
![]() "WalterM140" wrote in message ... You are incorrect. The RAF operated B-17's in action in daylight long before the USA even entered the war. The results were heavy losses and poor results. The Brits didn't use enough B-17's ever, to say they had heavy losses. And the Brits flew them at very high altitudes, and often as single attackers. The B-17 wasnt available in numbers in 1941. By September less than 40 B-17C's had been produced and half of these were in service with the RAF as the Fortress I. Mass production of the aircraft began with the B-17E in late 1941. That single aircraft ended up over targets was a result of the extremely poor reliability of the aircraft, it was not uncommon for half the dispatched aircraft to have to return to base. Indeed the USAAC described the B-17C as being unsuitable for combat use. Except for elite units, British bombing accuracy throughout the war was poor. Yadda Yadda Yadda Keith |
#145
Geoffrey Sinclair wrote:
The P-38 was the least effective of the USAAF fighters over Germany, thanks to a combination of factors. Once the USAAF could deploy escorts in numbers to the required targets then yes the Luftwaffe day fighter force was in trouble. The engineering to provide the escorts in numbers took most of 1943. Then the long range escorts appeared. I would like to point out that the "least effective fighter" may not be taking an overall view. Most of the problems with P-38 operations were the result of early doctrine and poor training of aircrew in multi-engine operations. They suffered through comparatively high loss rates in early operations where their writ was not to pursue the enemy, but to provide close escort, much as the Luftwaffe fighter force was in the Battle of Britain. Being unable to pursue an enemy limits your kill potential, but they DID cause a significant drop in bomber losses. In 1945, P-38s which were still flying escort missions under the later doctrine (and in equal or superior numbers to the defenders) had about the same results as their brethren in -47s and -51s. The P-38 also proved highly successful with 9AF on low level interdiction sorties. Adding in its ability to be adapted to do almost anything (how many P-51s were ever fitted with a Norden bombsight or pathfinder blind bombing radar system?) and the P-38 was highly successful in Europe. It's reputation suffered from engine problems (which were absolutely unknown in the MTO, PTO, or even Alaskan theaters, and were quite possibly due to fuel problems which admittedly affected the turbosupercharged Allisons more than the Merlins) and from the inevitable process of being the aircraft tasked with proving that your current doctrine isn't working the way it should. A poster noted that the use of P-38s in the photo-recon role (F-4 and F-5) limited the number of armed fighter types available, but strategically a squadron of long range high speed photographers (particularly in the Pacific) was almost certainly more valuable than another squadron of fighters - unless they are your escort for the day, of course. Mike a (perhaps overly enthusiastic) fan of the P-38 and most things Lockheed 55th Electronic Combat Group EC-130H Compass Call*; "In Jam, No One Can Hear You Scream" |
#146
bendel boy wrote:
Going from memory, Galland said the reverse - that the P-38 was seen as easy meat, and that it reinforced the lessons of the Bf 110. Even with drop tanks it didn't have the eventual range of the P-51, and, as found in the Pacific war area, it didn't have the agility to dogfight - it had to rely on 'dive & climb' tactics. Against the Bf 109 that may not have been as profitable. The P-38 was the first long range fighter the US produced, and had comparable or longer range than the P-51 throughout the entire war. As a quick exercise, look up the first Allied fighter escort mission to appear over Berlin... Also look up the airfield locations, and you'll note that a -38 had to fly quite a bit farther to fly a round trip to Berlin than a -51 did. As far as "dogfighting," no allied aircraft had the agility to "dogfight" (in this case, engage in a fight in which turning ability is a primary factor in performance) consistently with early war Japanese aircraft, nor did they need to. As early as December of 1941, AVG P-40s in China successfully employed climb and dive tactics, in an aircraft which markedly inferior to the P-38 in that regard. The first British Spitfires to attempt to engage in a WWI-style turning fight with the Japanese discovered that their aircraft didn't come out well in such a contest, and also adopted tactics which suited their aircraft better. Note that the aircraft with the better performance (climb and speed) can dictate the type of fight- the slower climbing "dogfighter" gets to be on the receiving end of high speed diving passes... Mike Williamson |
#147
All the B-26 units in Italy were eventually phased out, as they had been in
the Pacific, so that eventually B-26s only operated in the ETO. I know one US MTO B-26 Group was briefly converted to B-25s before relocating to the states for transition to the A-26 and the PTO, but I thought the other 2? (3?) remained in the theater. You're correct. I was thinking only of operations in Italy. The 319th was the group that converted to B-25s before transitioning to A-26s. It left Italy at the beginning of 1945. After that there were only three medium groups in Italy, the 310th, 321st and 340th, all flying B-25s. Chris Mark |
#148
ubject: Night bombers interception....
From: "Keith Willshaw" hat single aircraft ended up over targets was a result of the extremely poor reliability of the aircraft, it was not uncommon for half the dispatched aircraft to have to return to base. Indeed the USAAC described the B-17C as being unsuitable for combat use. Why do you think we gave them to the Brits? Same reason we gave P-39's to the Russians. Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
#149
I think we need to be careful getting too detailed with loss rates as
indicating anything significant about aircraft types because there are so many unknown variables, everything from accuracy of squadron records to how many dud rounds an anti-aircraft battery fired on one day compared to another. The safe conclusions are merely that low-level missions will cause losses to soar, whatever the aircraft type, and that single-engine performance is important in reducing losses. Both the B-25 and B-26 were good airplanes with slightly different attributes. Chris Mark |
#150
erroneous, that the choice of the stream
stragegy was not the best decision at times when a loose gaggle and varying run-in headings and altitudes between the 2-4 airgraft groupings would have been more effective. The goal of the stream tactic was to overload the German night defences. These were not very efficient, for initially the German ground control needed two radars to bring about an interception (one to track the fighter, one to track the bomber) and by concentrating the bombers in a dense stream, the number of bombers that could be intercepted by a system of limited capacity fell. Later on, German tactics were much looser and more effective, but the concentration of the stream probably helped to concentrate the ECM efforts that had to be applied to keep the German controllers in the desired state of confusion. -- Emmanuel Gustin Emmanuel dot Gustin @t skynet dot be Flying Guns Books and Site: http://users.skynet.be/Emmanuel.Gustin/ In my flying days the tactic was to vary the run-in headings for exactly the same reason, to keep the gunners guessing in where to aim. Forces the gunners to go to more barrage firing. Radar aimed guns were another mater but not that difficult to defeat with jamming systems. The danger of a midair is always present with that tactic but in practice wasn't an issue. Only problem was rejoining after coming off the target. |
regaining night currency but not alone | Teacherjh | Instrument Flight Rules | 11 | May 28th 04 02:08 PM |
Did the Germans have the Norden bombsight? | Cub Driver | Military Aviation | 106 | May 12th 04 07:18 AM |
Why was the Fokker D VII A Good Plane? | Matthew G. Saroff | Military Aviation | 111 | May 4th 04 05:34 PM |
Night of the bombers - the most daring special mission of Finnishbombers in WW2 | Jukka O. Kauppinen | Military Aviation | 4 | March 22nd 04 11:19 PM |
Why did Britain win the BoB? | Grantland | Military Aviation | 79 | October 15th 03 03:34 PM |
