First Flight For Electric Sun Flyer 2
Old April 15th 18, 02:16 PM posted to rec.aviation.piloting
Larry Dighera
Default First Flight For Electric Sun Flyer 2
https://www.avweb.com/eletter/archiv...4011-full.html
First Flight For Sun Flyer 2
Mary Grady
The prototype Sun Flyer 2 two-seat electric-powered airplane has flown
successfully for the first time, Bye Aerospace announced on Wednesday.
“We are excited about the future and the potential the Sun Flyer
family of aircraft has to revolutionize general aviation,” said CEO
George Bye, in a news release. The Sun Flyer 2 flew on Tuesday from
Centennial Airport, near Denver, Colorado. The testing will continue
to explore the airplane’s speed, altitude and endurance capabilities,
the company said.
The Sun Flyer has been in development since 2014. The company intends
to certify it under the FAA’s recently revamped Part 23 rules,
according to their website. As of March, the company had 105 deposits
for the Sun Flyer 2 and 16 deposits for the four-seat Sun Flyer 4,
according to its website. Bye said the Sun Flyer 2 will operate at a
cost of about $3 per hour, and is significantly quieter than
piston-powered aircraft of a similar size.
http://sunflyer.com/
Video: https://youtu.be/NCzv2rqpSOQ
https://youtu.be/glRV4HBM2k4
The Sun Flyer, which is to be FAR 23 certified, is powered by an
electric propulsion system. Six lithium ion batteries run the electric
propulsion system, which directly drives the composite propeller.
Engine performance is controlled by an electronic control unit which
ensures optimal use of the energy stored in the batteries. The
electric design features reduced cooling drag compared to a
conventionally powered aircraft and nose frontal area is reduced due
to a smaller motor size and cooling intake required. Propeller
efficiency is improved due to the utilization of additional blade area
when contrasted to an internal combustion engine aircraft. The
aircraft is made from composite material, primarily carbon fibre. The
cockpit employs an iPad used for cockpit instrumentation display
including motor, battery and aircraft systems. The aircraft connects
to Redbird Flight Simulatoins Sidekick system, which wirelessly tracks
the Sun Flyer's engine, flight time, physical location and altitude in
real-time when in flight.
2-Seater Specifications
$14.00Total Operating Cost Per Hour (Compared to $88.31/hour for a
Cessna 172)
Seats 2
46" Cabin Width
38' Wing Span
129 Sq Ft Wing Area
18.5 Glide Ratio
440 Lbs Crew
1,900 lbs Gross Weight
80 kW Propulsion
1,150 FPM Best Rate of Climb
55-120 Knots Normal Speeds
3.5 Hour Flight Endurance
$289,000
4-Seater Specifications
$19.80Total Operating Cost Per Hour (Compared to $122/hour for a
Cessna 182)
Seats 4
46" Cabin Width
38' Wing Span
120 Sq Ft Wing Area
18.7 Glide Ratio
800 lbs Crew & Passengers
2,700 lbs Gross Weight
105 kW Propulsion
1,250 fpm Best Rate of Climb
55-130 Knots Normal Speeds
4 Hour Flight Endurance
$389,000
Other Features
Easy to fly & operate
Next-gen Instrument Panel
Avidyne Avionics
Ventilated
Great Visibility
Long Operating Life
Ballistic Parachute Recovery System
One 45 lb motor with only one moving part
Electric self-piloted Airbus VTOL aircraft completes first full-scale test flight Larry Dighera Piloting 1 February 5th 18 02:44 PM
SoLong Solar-Electric UAV 48 hour flight Larry Dighera Piloting 6 September 25th 16 08:01 PM
Electric Trainer: $5 An Hour Flight Larry Dighera Piloting 9 November 5th 14 08:09 PM
Electric flight is coming Mark Piloting 16 July 6th 11 01:48 PM
Arcus E (electric) first flight ! Dave Nadler Soaring 5 September 22nd 10 01:13 PM
