"Signal jamming a factor in future wars, general says"
Old July 19th 04, 02:20 PM
Nele VII
jc wrote in message ...
Chad Irby wrote:
snip
Unless you spend a lot more money on them, they're also very vulnerable
to the newer EMP weapons.
In WWII the real secret weapon (proximity fuses) could only be used over
water until mid 44,in the UK with the V1 and not over enemy territory intil
the start of 45. The reason was fear of of copying a dud shell as the
allies had more to lose.
Actually, proximity fuses did not have the "self-destruct" mechanism,
therefore they would explode when hit the ground. Hence the limitation.
What is the better target for EMP weapons a GPS jammer or the NY stock
exchange?
The "piles of cheap low-power jammers" idea is nice, as long as you
don't have to keep using them.
At a rough guess the cost for a 1W jammer using cellphone components would
be ~$5, just keep sending them up with balloons (add $1).
Well, it is a bit under-estimated. I don't know much about how GPS works
(electronically), but I know it has commercial and military channels/
frequencies and commercial and military encoding. For civilian use, optimum
accuracy is receiving three GPS signals from three satellites (somebody
correct me if I am wrong, but I read it somewhere for more expensive GPS
devices for use, let's say in aviation) for elevation and position. As you
travel, the sattelites "switch" (just like GSM) control. Is it a same
frequency/coding? I don't know, but it is sure as hell that if you manage to
jam one channel, there are other two sats. Jam the other two signals, there
is one. In the meantime, your GPS receiver "struggles" to get signals from
the other two. And we are talking about civilian device.
What method are you going to use-noise or deceptive jamming? Read the
history of updates of "AN-ALQ" devices-or just one! Noise? In that case, you
are a flashbulb, and you will be attacked with alternate weapon on jamming
station. The band is narrow AFAIK, so if your opponent knows what to
"listen", you're toast.
Deceptive jamming. Well, it is not analogue signal anymore but digital and
probably encoded signal-actually, it IS encoded even for the civ use in the
matter of digital design-and probably scrambled in mil use. Thus, you have
to "doctor" the signal. Actually, signals -three satellites, remeber? You
can go to make this simmilar to tripled digital FBW system on, let's say,
F-16. Well, if you have failure on one channel then other two will feed the
aircraft with flying info, or in this instance, the weapon itself. Two of
them gone, you have one channel and two duds and you think that the flying
computer thinks that all three are duds? Wrong. Even your modem has
sufficient let-me-check-if-this-is-wright capabilities (CRC, CS) so it is
possible to imagine that FBW computer might have something simmilar. And
your jamming signal has to feed the encoded and encripted digital channel
switchig-multiple sattelite signals with false data, and it is desirable to
feed them with something meaningful to drive the weapon away, not to
owerflow it with garbage. And it's been a long time since F-16 digital FBW
was designed (I actually don't know is it possible to fly it on one channel,
but I would require it that it would! ))).
Oh, the output power. In the Battle of Britain, there was a German bombing
device called X-Gerat. Basically, you had three signals for guidance, based
on the Lorentz blind-landing system (Morse dots-too left of course,
dashes-too right of course, single tone-on course), and the offset signal to
mark the bomb dropping. Once discovered, it was jammed by the Brits by
sending "dashes". Well, it sometimes worked (and it seems it worked well!)
but there were cases that the crew was able to depict the jamming-slight but
ear-noticeable change of modulation or change of volume and to offset it.
Or back to Your cell phone-it can "sense" the distance from the GSM
station-actually, my Motorola CD920/930 has a hidden option that, when
activated can measure and display the DISTANCE from the GSM broadcast
(albait in very weird units )). Sattelites have very low output power and
if you send a "heroic" signal which is by magnitude stronger then satellite
signal, the system might think "this is too powerful", or "this is too
close" and simpy switch to something else. Remember, expirienced LW pilots
were able to depict the false signals. And code-breaking is not a trivial
thing; put a password to a MS-Word-file that is, let's say 5 characters long
and try to crack it with some program designed to do it, let's say Advanced
Office Password Recovery. Yeah, it will eventually break it, but count how
long it will take!
Also, You have A GPS and GLONASS (a Soviet GPS); while GLONASS is reportedly
in a bad shape, as far as I can remember India (I am really not sure!) uses
BOTH systems which might suggest that it is not in such bad shape after all.
While I am not aware of Russian GPS bombing/missile systems in use, some of
their (export?) weapon systems use both.
I agree that we are talking about the weapon (figter, bomber, cruise missile
or JDAM) that might not have all the "offset" capabilities that I have
mentioned here; I might not even be correct in numerous things. Actually,
you will need a (really, really) good sample either of the good portion of
the knowledge how -military- part of the system works or the system itself.
And once you develop a system, it will certainly not be of the cell-phone
size but rather of an underwing or wingtip pod size, weight and cost.
Nele
NULLA ROSA SINE SPINA
Old July 19th 04, 09:27 PM
Paul J. Adam
In message , Al Dykes
writes
Paul J. Adam wrote:
Let's split the difference and say it got lost somewhere along the way.
(Otherwise, why would CCM against GPS jammers be a profitable business,
if the system was inherently resistant?)
Some creative Russian printed up some ACME GPS Jamming System
brochures and took SH for some of his money ?
Elements of that. Basic GPS systems, civilian and some military, are
very easily sent berserk by low jamming powers. Less basic systems are
more resistant, increasing (for rising input cost) to very jam-proof
systems that are extremely difficult to lock out.
GPS jamming is a real problem. It has real solutions and it's not a
surprise. (And it's harder to do than the doomsayers would claim, just
as it's more of a problem than some like to admit)
He thinks too much: such men are dangerous.
Julius Caesar I:2
Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk
Old July 20th 04, 04:00 AM
Eunometic
"Paul J. Adam" wrote in message ...
writes
The higher end systems would appear to have highly directional 'phased
array' antena that can exclude the jaming signal by locking onto the
satelite directly based on both satelite signal and known maps of
satelite position. A jammer must thus be as high as possible
(preferably in line with between the satelite ) to get energy into the
sidelobes of the antena.
Low cost solid state acceleromters and inertial guidence systems will
give many munitions a inertial guidence system that will takeover as
soon as effective jamming is detected which is likely to be only near
the target. There are indeed wind corrected bombs that cost perhaps
double that of a GPS bomb but loose only a little in accuracy. On top
of that simple infrared imaging systems based on the same sensors now
used in highend cars add even more accuracy than GPS is capable of.
At best jammer will only be able to degrade the accuracy slightly
while forcing up the price of the munition slighly or even increasing
it by forcing the bomber to add a simple terminal homing system.
Old July 20th 04, 08:22 AM
Yuri Tregubov
GPS jammers (noise generators) are the standard tools nowadays.
Obviously, the weak satellite signal could be shutdown quite easily.
It's not a top notch, cool technology anymore, just usual (and
probably boring) stuff.
See, http://www.noisecom.com/content/Prod.../GPS7500_5.pdf
Russian regards,
Yuri
Old July 20th 04, 10:25 AM
Chad Irby
Not so obviously.
The directionality of RF, along with the inverse-square law, make it
*much* harder to jam a source that's effectively "behind" the incoming
munitions than you'd think. The jammers have to be quite high powered,
and are therefore pretty easy to find and disable (along with the
problem of keeping the jammers powered for days or weeks at a time).
See,
You might note, for example, that the testing device above is used to
determine if *internal* RF noise interferes with GPS function (if a cell
phone or car mounted GPS is degraded by RF in the same vehicle).
It takes a lot of power to do anything to a GPS signal at anything like
a reasonable range.
cirby at cfl.rr.com
Remember: Objects in rearview mirror may be hallucinations.
Slam on brakes accordingly.
Old July 20th 04, 07:08 PM
Laurence Doering
You need to receive signals from four satellites to obtain a 3-D
position. Most GPS receivers can make do with three satellites, but
when they do they give only a 2-D position, and assume your elevation
is constant.
Modern consumer GPS receivers can receive and use signals from up
to twelve GPS satellites simultaneously. With the current GPS
constellation, it's not unusual to have ten satellites above the
horizon and useable. Most receivers will use the additional
satellite signals (above the four needed for 3-D position) to
determine your position more accurately.
As you travel, the sattelites "switch" (just like GSM) control.
Actually, the satellites are most likely traveling faster
than you are. Their orbital period is just under 12 hours, so
you'd have to be moving more than 2000 mph to stay directly
underneath one. The GPS receiver computes which satellites are
above the horizon, and listens for their signals. As satellites
rise and set, the receiver updates the group of satellites it's
listening for.
Deception jamming might be possible if you have a civilian receiver,
but you'd need to crack the encrypted signal to spoof a military
receiver.
There are a number of introductory descriptions of how the GPS system
works on the web -- for example, check out
http://www.aero.org/publications/GPSPRIMER/
ljd
Old July 20th 04, 11:24 PM
jc
snip
you are a flashbulb, and you will be attacked with alternate weapon on
jamming station. The band is narrow AFAIK, so if your opponent knows what
to "listen", you're toast.
receiver.
Probably the best (cheap) method would be noise with digital transmissions
(as per psuedo random code no need to crack the encryption) on the correct
frequencies. 1W dosn't sound much but with the low recieved power of the
GPS signal it dosn't take much to overwhelm or confuse it.
The cellphone industry has ensured VERY low cost components eg power output
transistors/amplifiers for a few cents. No need for elaborate environmental
enclosures just attach balloon and battery stick a ziplok bag over the
electronics and release. To avoid ECCM attacks change location immeadiately
to another school, hospital etc although a vehicle outside the Chinese
embassy for a release point is a possible.
The cost of hitting the balloons once they are released makes them a rather
assymetric weapon.
regards
jc
LEGAL - I don't believe what I wrote and neither should you. Sobriety and/or
sanity of the author is not guaranteed
EMAIL - and are not valid email
addresses. news2x at perentie is valid for a while.
Old July 21st 04, 01:37 AM
Chad Irby
transmissions (as per psuedo random code no need to crack the
encryption) on the correct frequencies. 1W dosn't sound much but with
the low recieved power of the GPS signal it dosn't take much to
output transistors/amplifiers for a few cents. No need for elaborate
environmental enclosures just attach balloon and battery stick a
ziplok bag over the electronics and release. To avoid ECCM attacks
change location immeadiately to another school, hospital etc although
a vehicle outside the Chinese embassy for a release point is a
possible.
rather assymetric weapon.
You're forgetting something.
Power.
For a 1 watt output, you're going to need a battery or other power
supply that can supply at least twice that for a significant period of
time. If you're going for a balloon launch, to get to significant
altitude, you're going to need a couple of hours of capacity, at
*least*. Increased weight equal increased balloon size, by the way.
With increased tankage for your lifting gas, and massively increased
transportation costs.
Not to mention, of course, that you're transmitting that 1 watt
omnidirectionally, which means that you're only going to cover a couple
of square miles with one jammer, at *best*. If you're going for a pure
white noise "drown them out" system, plan on a *hundred* watts or more
(to beat the directional antennas used on most modern weapons systems).
If you're going for digital spoofing, use lower power levels, but spend
a lot of money on electronically-steerable transmitters and high-end
hardware to make the signal work past the dozen or so GPS sats in view
at any one time.
Suddenly, the "$5 balloon-borne jammer" is a "$500 balloon-borne jammer
that only lasts a few hours."
cirby at cfl.rr.com
Old July 21st 04, 07:58 AM
Yuri Tregubov
Don't know is it true or not, but have read that hobbyist level
nonsophisticated 1W jammer shuts down GPS devices in an area of
hundred kilometres.
The ECM warfare is very well developed field, so it's not a problem to
jam a weak signal at all. Of course, the GPS could be done more or
less jam proof, but it costs a lot of money and hence not practical
for wide use.
There's no difference in jamming radar/comm/GPS, all of them are the
"RF devices", use the same basic principles and communication media.
Russian regards,
Yuri
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 02:39 AM
Pentagon admits Environment source for future wars Aerophotos Military Aviation 5 February 23rd 04 01:33 PM
