Notable Power Flarm saves - Is it 'worth it'?
Old May 6th 18, 03:05 PM posted to rec.aviation.soaring
Darryl Ramm
Default Notable Power Flarm saves - Is it 'worth it'?
On Sunday, May 6, 2018 at 6:25:25 AM UTC-7, wrote:
My message for a long time has been: If you fly near areas of dense airliners, fast jets and military traffic, just get a transponder, Mode S or used Mode C does not matter... get what you can afford.
This seems logical, but I heard another corner case where might not be so..
I sat in a presentation from our local Approach Control folks. They noted that with the new ADSB ground stations they had better visibility than from their existing radar plus ModeC. Specifically, low and far out. This like it might permit them to route controlled traffic in new places where gliders are, but where a Mode C transponder on the glider might not help.
You need to do a bit more thinking about the flaws in your logic here.
A transponder provides visibility to TCAS and IFF systems in airliners, fast jets and (some) military traffic...
If ATC was about to do this, and direct traffic towards areas where gliders are it is more reason to want to have a transponder.
If in this scenario you also wanted ADS-B out, then a Mode S transponder is the way to go. I hope you spoke up and talked about gliders in the area and what they are or are not equipped with. I'd have possibly also pointed out the Chicago 737-glider NMAC last year as an example....
  #52
Old May 6th 18, 04:12 PM posted to rec.aviation.soaring
Craig Reinholt
Unfortunately, what the Approach Control folks failed to mention that their software removes targets of anything less than 70 mph ground speed. This is to remove the clutter from highway traffic. It also removes most gliders unless we have electronic identification measures. YMMV with each approach personnel. PDX was pretty clueless about gliders and their senior controller didn't know what the 1202 transponder frequency identified. They have since programed 1202 to print "glider" on their screen.
Craig
  #53
Old May 6th 18, 04:26 PM posted to rec.aviation.soaring
Ron Gleason
Craig
Salt Lake City Approach and Center has implemented the same, GLDR appears on the screen when a 1202 squawk code is received.
The Utah Soaring Association has a great relationship with SLC ATC and Center for general glider flying and during events at Nephi and Logan. I highly recommend you contact the ATC and sit down with, explain where and when you fly and educate them. They want to be informed and eliminate surprises.
Ron Gleason
  #54
Old May 6th 18, 04:42 PM posted to rec.aviation.soaring
Darryl Ramm
Craig
And to be very clear on what Craig is saying, he is talking about primary radar doppler discriminators filtering slow moving aircraft so they are not seen on ATC primary radar, this is *not* SSR (Secondary Surveillance Radar) that detects transponders. If your glider has a transponder it will be seen by ATC via SSR any time it is within SSR coverage, independent of airspeed.
I have to say this because I know there is still confusion out there, including hearing people get this completely backwards and claim that this filtering is an issue with transponders, it's not... its a reason why you want a transponder.
  #55
Old May 7th 18, 03:38 PM posted to rec.aviation.soaring
Craig Reinholt
Craig
Aaak! Sorry for not being clear on my post. What Darryl said!
Power Flarm with ADS-B out? Dave Benjamin Soaring 24 May 19th 17 02:11 AM
Power Flarm Problems Charlie Flagg Soaring 18 August 27th 16 05:11 PM
Power Flarm [email protected] Soaring 3 May 25th 14 11:03 PM
Power flarm [email protected] Soaring 10 March 24th 14 02:31 AM
Power FLARM power Andy[_1_] Soaring 9 June 6th 12 12:38 AM
