#21
Im getting full charges from the recommended Repco charger.
On Friday, May 11, 2018 at 12:37:03 PM UTC-7, wrote:
Not to start another chapter in "Battery Wars" but I have a simple question about "drop in" LiFePO4 battery replacements for SLA batteries in gliders. For years, I've used an SLA battery with the same footprint as the common glider size of 7Ah to 9Ah--i.e., 5.95" x 2.56"--except a little taller--i.e., 4.61" high vs. 3.86" (specs are from the PowerSonic line but other brands are similar). It's an easy swap in my ASW 24, only requiring a different hold-down strap. There's about 20% more internal volume, which seems to equate to at least 20% more claimed capacity. I've used enough of these that I know they do perform longer than the conventional-size SLA batteries most pilots use. However, I can't find a LiFePO4 equivalent for it. Does such a thing exist? All I've seen discussed here or available online seem to be the "traditional" size. I've been told that this is because there's already excess space inside the enclosure, that it's not packed to the gills with mat/chemicals as SLAs are, and that the extra 3/4" wouldn't allow adding additional cells. And besides, I don't need it anyway (I'm running PowerFLARM, radio, CNv vario, and PNA; no transponder yet). Then I see that some LiFePO4 batteries are rated slightly higher for the same enclosure size. Even the K2 battery touted in adverts as "10 Ah" seems to be 9.6 Ah in the specs. And that's ignoring loads, discharge rates, temperatures, etc. Given the price differential and the necessity for a new charger (although not according to the K2 site), and especially in light of the recent stories of LiFePO4 batteries crapping out long before their promised lifespans, maybe I should just continue to buy a new SLA battery every year or two and wait for this fad to pass. ![]() As I said, a simple question. Chip Bearden If it's working for you and if there are no readily available replacements just keep using the SLA/AGM battery you already use. Personally I like the K2 batteries and the one in my ship is starting it's fifth year of service but it's not magic, just a good battery that fits my needs well. In the case of my glider it solved a space, weight and capacity requirement but it seems that the SLA/AGM is doing everything you need it to do. |
Money isn't everything. However your lifetime allotment of cussing is a precious thing, not to be wasted on SLA batteries.
SF The request was for a simple answer, so here ya go. I could have made it simpler, but I'm saving my allotment for windy contest days which I have grown to hate with a passion usually reserved for people driving slowly in the left lane. |
#24
I got my simple answer about the apparently non-existent larger size LiFePO4 battery.
Regarding the ensuing discussion, I didn't go the LiFePO4 route a few years ago even though the sentiment at the time seemed to "it's a no brainer; just do it." The current sentiment seems to be a bit more nuanced, which is good to know. Thx, all, for the candid inputs. Chip Bearden |
#25
I have a friend that built several, 4 two for him and two for me 13.2 volt 11AH lifepo4 that used round cells and a bms circuit. for about $50 each that was the same size as the standard 12volt 7ah agm. They went with my Ventus but was a great system. Now I have to talk him into building a few more for my 27
![]() CH |
#26
#27
On Wednesday, May 16, 2018 at 4:16:35 PM UTC-7, kinsell wrote:
On 05/15/2018 01:35 PM, wrote: I got my simple answer about the apparently non-existent larger size LiFePO4 battery. Regarding the ensuing discussion, I didn't go the LiFePO4 route a few years ago even though the sentiment at the time seemed to "it's a no brainer; just do it." The current sentiment seems to be a bit more nuanced, which is good to know. Thx, all, for the candid inputs. Chip Bearden Right, some people are discovering that comparing preposterously optimistic data sheet numbers of lithium batteries against actual performance of SLA's isn't a valid comparison. Not everybody of course. Some valid comparisons on this page; http://www.craggyaero.com/lifepo_battery.htm Richard www.craggyaero.com |
#28
My observations were purely subjective:Â* With SLA batteries, I would run
out of power in 3-5 hours.Â* With LiFePO4 batteries, my volt meter still showed good voltage after 5 hours.Â* No hard numbers, I know, but I got the performance that I required. On 5/16/2018 5:16 PM, kinsell wrote: On 05/15/2018 01:35 PM, wrote: I got my simple answer about the apparently non-existent larger size LiFePO4 battery. Regarding the ensuing discussion, I didn't go the LiFePO4 route a few years ago even though the sentiment at the time seemed to "it's a no brainer; just do it." The current sentiment seems to be a bit more nuanced, which is good to know. Thx, all, for the candid inputs. Chip Bearden Right, some people are discovering that comparing preposterously optimistic data sheet numbers of lithium batteries against actual performance of SLA's isn't a valid comparison.Â* Not everybody of course. -- Dan, 5J |
#29
I want to concur with Dan.
I fly out of Minden and we cruise between 15,000 and 17,999. It is COLD at that altitude. My lead batteries would lose voltage as the temp dropped. After three hours at altitude they were lucky to put out 11 volts. Of course, when the batteries warmed up alter landing they had full voltage. The LiFePO4 batteries do not seem to affected by cold soak. They work the whole flight at full voltage. |
#30
I never paid attention to the voltage vs temperature thing, but my
engineering training says that you are correct, Dr. Guy.Â* As to the full voltage thing with the Li batteries, yes, they hold full voltage...Â* Until they don't, and then they simply turn off, they don't run at reduced power output as the SLAs do. With the SLA batteries, I always used two batteries on a typical flight in the Rockies, usually switching at around 3 hours.Â* With the LiFePO4, I would easily run 5 hours and never have to switch, though, since I had a separate tail battery, I kept a fully charged battery there.Â* And, as I've said before on this group, after watching the batteries carefully while charging on the concrete floor of my garage, I took the big step after a year of leaving them installed in the glider with the proper charger attached and plugged in.Â* Never a problem.Â* Your results may vary. On 5/17/2018 6:29 AM, wrote: I want to concur with Dan. I fly out of Minden and we cruise between 15,000 and 17,999. It is COLD at that altitude. My lead batteries would lose voltage as the temp dropped. After three hours at altitude they were lucky to put out 11 volts. Of course, when the batteries warmed up alter landing they had full voltage. The LiFePO4 batteries do not seem to affected by cold soak. They work the whole flight at full voltage. -- Dan, 5J |
LifePO4 batteries for motorgliders - are we there yet? | Chris | Soaring | 13 | January 9th 16 03:43 PM |
LiFePO4 Batteries on sale. | [email protected] | Soaring | 20 | December 9th 15 05:34 PM |
K2 vs. StarkPower LiFePo4 batteries | Fox Two[_2_] | Soaring | 36 | April 16th 15 05:14 PM |
LiFePO4 Batteries | vontresc | Soaring | 56 | June 27th 14 07:25 PM |
LiFePO4 batteries | JS | Soaring | 26 | October 15th 12 02:51 PM |
