Digital altimeters
Old June 2nd 18, 10:13 PM posted to rec.aviation.soaring
Default Digital altimeters
Tried of the 57mm Winter altimeter being too inaccurate even after being re-calibrated. Being EXPERIMENTAL, going to look into digital.
Going to look at MGL Vega ASV-1 first as it displays altitude and airspeed. http://www.mglavionics.com/html/vega_color_singles.html
Anyone had experience with this specific make/model?
Old June 3rd 18, 05:22 AM posted to rec.aviation.soaring
2G
Even though you are experimental, your airworthiness certificate may be linked to a particular set of basic instruments. Best to check it out before you remove the Winter.
I have used an MGL engine monitoring instrument and thought their quality and documentation was above average. The new instruments have much improved readability.
Tom
Old June 3rd 18, 06:26 AM posted to rec.aviation.soaring
Ross[_3_]
Why not simply go to Air Avionics?
It is a fully TSO altimeter.
https://www.air-avionics.com/
Enjoy
Old June 3rd 18, 07:05 AM posted to rec.aviation.soaring
2G
Enjoy
The ACD-57 is about twice the price of the MGL and lacks an ASI.
Tom
Old June 3rd 18, 09:08 AM
Skypilot Skypilot is offline
Member
First recorded activity by AviationBanter: Feb 2012
I just bought a SZD55 with a digital altimeter and a LX9000. First thing I did was put a new Winter 57mm altimeter in it. Main reason was insurance payout is you break it outlanding, second reason was it looks awful and is hard to read.
Just my thoughts.
Enjoy
Tom
Old June 3rd 18, 02:13 PM posted to rec.aviation.soaring
Its hard to find specific guidance for instruments in experimental gliders within the maze of FAA regulations, but as a practical matter, I found my Winter compact altimeter calibration was inadequate for safely flying close to restricted airspace, even after factory recalibration, so I took it out and use my CAI and LX altimeters, which have excellent calibration.
Old June 3rd 18, 03:28 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Enjoy
http://www.craggyaero.com/acd_altimeter.htm
I have one in my Glider and I have them in stock.
Richard
www.craggyaero.com
Old June 3rd 18, 03:36 PM posted to rec.aviation.soaring
jfitch
Richard, these are ETSO approved, does that make them FAA TSO'd as well? For use in a certified glider.
Enjoy
Richard
www.craggyaero.com
Old June 3rd 18, 03:50 PM posted to rec.aviation.soaring
Enjoy
Richard
www.craggyaero.com
The ACD comes with a similar EASA document to that which comes with a Winter Altimeter. So my answer is ??????
AIR Control Display is a fully ETSO certified primary altimeter. It is an easy to read altimeter with really large numbers and perfect reliability, especially in high vibration environments like helicopters, old powered aircraft, or self launching motorgliders.
Regulation geeks will have to answer this one.
Richard.
www.craggyaero
Old June 3rd 18, 05:01 PM posted to rec.aviation.soaring
JS[_5_]
I use a calibrated Winter 57mm altimeter and regularly fly near or in Restricted airspace. The ALT display in the TT22 is a more important thing there..
Setting altimeters with no radio Mxsmanic Piloting 178 November 15th 06 08:35 PM
Any 2.25 in, sensitive altimeters (3 pointer)? rpellicciotti Home Built 2 July 14th 06 04:57 AM
Thunderbirds and Altimeters Dudley Henriques Military Aviation 17 February 1st 04 06:00 PM
Thunderbirds and Altimeters Dudley Henriques Naval Aviation 9 January 29th 04 05:48 PM
wristwatch altimeters [email protected] Aviation Marketplace 2 December 6th 03 01:22 AM
