Cobra trailer stuck closed
Old June 14th 18, 05:56 PM posted to rec.aviation.soaring
Steve Koerner
Default Cobra trailer stuck closed
On Thursday, June 14, 2018 at 4:03:27 AM UTC-7, AS wrote:
Thanks for the update, Auxvache! Glad you didn't have to resort to plan 'B'.
.... and the strut stayed compressed.
Steve - insert the sound the little birdie makes, when it comes out of the clock, here! ;-)
Uli
'AS'
Umm Uli, are you tripling down on your theory that gas leaked across the piston to cause the original problem even though it has been clearly demonstrated to you that such could not possibly be the case since gas springs have an intentional leak across their piston to establish the damping rate?
By far, the normal way for a gas spring to fail is simply for the nitrogen to leak out the stem seal. This apparently wasn't a normal failure since the OP says the tube is distorted. With mechanical stuff there's always an infinity of ways things can break. Yet knowing how stuff works is almost always helpful. It does allow you to scratch off dumb suggestions from people who allege credentials but don't really know what they're talking about. I hope I'm not hurting your feelings again.
  #42
Old June 14th 18, 07:18 PM posted to rec.aviation.soaring
Bob Kuykendall
Just curious, did you note whether the orientation was thin rod up or thin rod down?
--Bob K.
  #43
Old June 14th 18, 07:21 PM posted to rec.aviation.soaring
Bob Kuykendall
On Monday, June 11, 2018 at 9:50:11 PM UTC-7, Steve Koerner wrote:
I'm sorry you were insulted by me.
Passive voice FTW!
  #44
Old June 14th 18, 08:15 PM posted to rec.aviation.soaring
Steve, in the catalogue of the same firm (Dictator) you mention, there is at least one gas spring type that works thanks to the difference between outside air pressure and inside nitrogen pressure. Granted, it is a pulling spring, while all others are the pushing kind that work as you describe it. It simply means there are different systems possible.
One of my club's trailers also had a strange gas spring failure once, luckily on an outside system: the spring gradually refused to open completely, after some time it opened only 8 inches or so. It felt as if it was blocked by some mechanical lock. But it still could be compressed for the remaining stem length, so it wasn't a blocked leak hole nor loss of nitrogen pressure. Any ideas on what went wrong?
Wanted to Buy : Ka-6CR Closed trailer Tango Juliet Soaring 0 January 5th 15 01:31 AM
2013 Cobra trailer price list needed for TA trailer sale [email protected] Soaring 0 June 22nd 13 02:42 PM
Looking for closed trailer for ASK-21 or Grob-103 kirk.stant Soaring 0 September 23rd 12 06:26 PM
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! flyingmr2 Soaring 4 November 16th 10 02:11 AM
WANTED (USA): Blanik L-23 Trailer (Open or Closed) CLewis95 Soaring 0 November 14th 08 09:23 PM
