THE LONG AWAITED BREAK THROUGH IN BATTERY TECHNOLOGY HAS BEEN FOUND
Old June 15th 18, 08:29 PM posted to rec.aviation.soaring
Default THE LONG AWAITED BREAK THROUGH IN BATTERY TECHNOLOGY HAS BEEN FOUND
So, you want a flux capacitor?
No, I want the "Mister Fusion" in BTTF 2.
Old June 15th 18, 09:51 PM posted to rec.aviation.soaring
jfitch
On Friday, June 15, 2018 at 4:34:04 AM UTC-7, Martin Gregorie wrote:
On Fri, 15 Jun 2018 01:31:47 -0700, jpg797 wrote:
To me the big story about electrical energy storage advancement is that
despite numerous claims of a revolution just round the corner it has
been stubbornly incremental in reality.
You're spot on about promises of new battery technology, usually made
about results from an initial small scale laboratory demonstration, that,
after a glowing announcement in New Scientist, mysteriously vanishes,
never to be heard from again. It would be really wonderful if at least
one of these efforts resulted in something more substantial than a PhD
thesis and, at least sometimes, a newly fledged PhD graduate. But, I'm
not holding my breath for this wondrous event because known electro-
chemical properties put limitations on future capacity increases.
Martin | martin at
Gregorie | gregorie dot org
For aircraft power, energy density is king. Even the company's own press release does not claim to be competitive with LiPo batteries (as used in the FES and Antares), they say the may eventually "approach" that.
The dirty secret of all electric vehicle power is that you've got to get the power somewhere. At our glider port, if more than 1 or 2 electrics plugged in overnight it would bring the electric service to it's knees. We barely have power to recharge the golf carts. As an energy source, gasoline is still hard to beat.
Old June 15th 18, 10:23 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Default THE LONG AWAITED BREAK THROUGH IN BATTERY TECHNOLOGY HAS BEENFOUND
On Fri, 15 Jun 2018 11:54:26 -0700, Steve Koerner wrote:
On Friday, June 15, 2018 at 10:39:26 AM UTC-7,
On Friday, June 15, 2018 at 12:18:30 PM UTC-4, Steve Koerner wrote:
Go ask your electrical utility for a price quote on that sort of
connection...
Well Moshe, when the supercapacitors become workable in cars, why
wouldn't they also become workable for buffering at the filling
station? Megawatt connections won't be the issue.
You'd need a heck of a lot of those supercapacitors. The reason they
are being talked about in cars is to provide acceleration or
regeneration for a few seconds, a small amount of energy relative to
what's stored in the main battery. Sort of like a now-old-hat "hybrid"
car uses the battery for short-term acceleration and regeneration while
the gasoline tank stores most of the energy. The supercaps have a much
lower energy storage density, and much higher price per energy unit,
relative to batteries. Also, at a "filling station" you'd want to
allow one car to fill-er-up after the other, not much time for
buffering. So you'd still need megawatts of supply. That's actually
perhaps economically feasible at a dedicated filling station, but not
at home.
Makes sense. I've not looked at numbers. It's fun to read the tidbits
in Gliding International about carbon nanotube materials and super dense
battery technology -- even if it's mostly fictional and none of it will
come to light. Numbers just spoil the fun. I'd rather continue to
contemplate supercapacitors that will be tiny and cheap and hold
enormous energy.
A very quick bit of playing with numbers (service station with 18
chargers, assuming that each recharge was the equivalent of a tankful of
petrol, 60 litres, and charging averages one full charge sold per charger
each hour over a 10 hour day) looked like an equivalent electric charge
point would need a continuous power input of around 0.1 MW.
Assumptions:
- 60 litres is a full tank: that's roughly what my Focus takes.
- The standard energy content of a litre petrol is 10 KWh.
- The number of pumps matches my local supermarket.
- The average fill rate of one tankful per pump per hour is a guess
based on how full the service station is at various times combined
with a guestimate that the average stop for a full tank of gas is
10-12 minutes.
Martin | martin at
Old June 16th 18, 12:20 AM posted to rec.aviation.soaring
Dave Nadler
On Friday, June 15, 2018 at 9:42:35 AM UTC-6, Charlie Quebec wrote:
...even if only 20 seconds of high power to accelerate for self launch.
Nope, supercaps absolutely not helpful.
You need enough power for a safe climb rate for several minutes.
And that much power already provides more than adequate acceleration.
Forget the supercaps for this application!
BTW, some electronics I designed flying in produced gliders uses supercaps ;-)
Old June 16th 18, 01:16 AM posted to rec.aviation.soaring
Charlie Quebec
A FES motor would provide sufficient climb rate, and an initial boost would be helpful.
As I pointed out, it is already more powerful than a TOP motor.
Old June 16th 18, 02:54 AM posted to rec.aviation.soaring
connection...
at home.
enormous energy.
Assumptions:
10-12 minutes.
Martin | martin at
Martin: check your numbers. 60 liter * 10 KWH/l * 18 pumps * 10 hours = 108,000 KWH, or about 10,000 KWH per hour, i.e., 10 megawatts (if supplied over those same 10 hours). And one tankful per pump per hour is very slow for a gasoline filling station, although fairly fast for battery charging with current non-vaporware batteries. The actual filling of a tank takes about 1/18 of an hour, so that flow rate of fuel into your tank is 10 megawatts! Yes, it's hard to beat fossil fuels in energy density.
Old June 16th 18, 03:19 AM posted to rec.aviation.soaring
lynn
On Thursday, June 14, 2018 at 7:31:22 PM UTC-7, wrote:
There is a small company based outside Marseilles, who will by mid 2019 be mass producing a new type of battery, the advantages of which will blow your mind apart. The French company believe their products offers massive advantages to Electric Vehicles – i.e. self-launching motorgliders.
By combining the unique strengths of lithium batteries with an all new crazy-fast charging and carbon ultra-capacitors, the combination results in massive weight savings of more than a third of current power supplies. Recharge times can be measured in seconds. (Like half the time it takes to fill your tank with fuel). To this add the life span of this new power storage - it will accept up to a million charge cycles.
This is a story that “will blow your mind” and it appears in complete detail in the July issue of Gliding International.
You can buy of renew your subscription at our web site -
www.glidinginternational.com
I think what is needed for faster electric car charging at a "gas" station is to have all cars to have standardized, easily pull-out, slide-in battery packs. One would only need to drive up to a refueling bay, a machine would open a hatch, and exchange the battery pack. Battery pack would be provided by nationwide refuel centers. The cost would reflect the cost to charge plus eventual replacement. Refill time would be equivalent to a gas fill up. Car dealership would provide a free fill up like they usually do now. Initial car price would, of course, include the price for a new battery pack. No electric cord required or long wait while on a cross country trip. This has nothing to do with FES designs, but just thought it would be a neat idea..
Old June 16th 18, 04:20 AM posted to rec.aviation.soaring
There is a small company based outside Marseilles, who will by mid 2019 be mass producing a new type of battery, the advantages of which will blow your mind apart. The French company believe their products offers massive advantages to Electric Vehicles – i.e. self-launching motorgliders..
One start up that actually attempted to do this was called "Better Place". Unfortunately, it failed spectacularly. Great idea though.
https://en.wikipedia.org/wiki/Better_Place_(company)
David
Old June 16th 18, 02:03 PM posted to rec.aviation.soaring
connection...
they are being talked about in cars is to provide acceleration or
"hybrid"
while the gasoline tank stores most of the energy. The supercaps
have a much lower energy storage density, and much higher price per
energy unit, relative to batteries. Also, at a "filling station"
you'd want to allow one car to fill-er-up after the other, not much
time for buffering. So you'd still need megawatts of supply.
That's actually perhaps economically feasible at a dedicated filling
station, but not at home.
tidbits in Gliding International about carbon nanotube materials and
super dense battery technology -- even if it's mostly fictional and
none of it will come to light. Numbers just spoil the fun. I'd
rather continue to contemplate supercapacitors that will be tiny and
cheap and hold enormous energy.
of petrol, 60 litres, and charging averages one full charge sold per
charger each hour over a 10 hour day) looked like an equivalent
electric charge point would need a continuous power input of around 0.1
MW.
Assumptions:
10-12 minutes.
Martin | martin at Gregorie | gregorie dot org
Yep. I forgot to convert KWh to MWh. I was having a slow day.
station,
Sure. Based on my usual timing, a fill seems to take around 10 min if you
include queuing at the til - pay at the pump has only just appeared at my
usual service station and I haven't yet got my head around how long it
takes now. But, it would seem unlikely that a pump could deal with more
than 20 cars an hour, but average over a whole day the throughput has to
be less when you consider that for much of the time maybe only 25% of the
pumps are in use.
Agreed.
The actual
energy density.
Yes, exactly so. Another point is that building the generation capacity
to replace the refineries producing petrol and diesel and adding the
cabling to get that power to the charging stations is going to take quite
a lot of time and money. That process will be slow and expensive enough
here in a physically small country, so I wonder how long and expensive it
will be in a place as big as the USA. Have the people planning your
carbonless future thought about that? I don't think ours have.
Martin | martin at
Old June 16th 18, 06:57 PM posted to rec.aviation.soaring
jfitch
connection...
"hybrid"
MW.
Assumptions:
10-12 minutes.
station,
pumps are in use.
Agreed.
The actual
energy density.
Martin | martin at
I've watched them build the Tesla charging station near my home. The power service looks like a small power substation. I think they only have 10 charging stations, supposed to be able to get a Tesla to something like 80% in 30 minutes.
Tesla also proposed, and began to build, battery swap stations for their cars. I'm not sure it was every made operational. The Tesla batteries are underneath and apparently quickly swappable - not slide out, but put on a lift and R&R with some special equipment. One problem you will run into is the battery pack you get might have 5000 cycles on it, vs. yours with only 500..
Another problem with mass conversion to electric cars: the public believes the electricity comes out of trees or something. In fact in most of the US, fossil fuels (coal or diesel) are used to generate the power. Many of these plants are turbines, and are not as thermally efficient as a modern car engine. Hydro power is pretty much fully developed (as much as the public will stand anyway) and there hasn't been a nuclear plant built in decades. Solar may be an answer, but it requires energy storage systems that are not currently in place. Fusion IS the answer, but someone has yet to crack that nut.
Boeing HorizonX Invests in Advanced Battery Technology: unmatched energy density and reliability Larry Dighera Piloting 0 January 29th 18 05:14 PM
Found in a long-forgotten folder Byker Aviation Photos 0 March 20th 16 12:03 AM
Possible Breakthrough in Battery Technology Matt[_3_] Soaring 3 March 1st 12 08:35 PM
AOPA Expo, meeting JayB, getting stuck in Lancaster on the way home,fulfilling the commercial certificate long solo x-c...long Jack Allison Piloting 6 November 19th 06 02:31 AM
TEST PILOTS ACCOUNT OF INFLITE BREAK UP (SR 71) (LONG) caleb Owning 1 January 30th 06 05:01 AM
