On Sunday, November 12, 2017 at 10:20:27 AM UTC-5, wrote:
I've spent some time reading the FAA's response to the SSA in regards to the IS-28B2 found here, http://www.ssa.org/files/member/FAA%...7%20-%20Signed[2543].pdf I'm curious how it applies to the 3,000 hour service life extension for say a Schleicher ASW-15 sailplane. I have the same question about a DG-200. Is a service life extension required in the US? |
On Thursday, June 21, 2018 at 3:17:56 PM UTC-4, Chris Snyder wrote:
On Sunday, November 12, 2017 at 10:20:27 AM UTC-5, wrote: I've spent some time reading the FAA's response to the SSA in regards to the IS-28B2 found here, http://www.ssa.org/files/member/FAA%...7%20-%20Signed[2543].pdf I'm curious how it applies to the 3,000 hour service life extension for say a Schleicher ASW-15 sailplane. I have the same question about a DG-200. Is a service life extension required in the US? The Lark was life limited. It did not have a provision for service life extension. The FAA provided a way to extend life by condition, as I recall. The other manufacturers do have that provision so owners have to comply with the inspection specified to ensure continued airworthiness. UH |
![]() The Lark was life limited. It did not have a provision for service life extension. The FAA provided a way to extend life by condition, as I recall. The other manufacturers do have that provision so owners have to comply with the inspection specified to ensure continued airworthiness. UH Thank you for the confirmation. If anyone has gone through the 3000h inspection process for a DG, I'd appreciate any information you can share. Chris |
On Thursday, June 21, 2018 at 8:37:48 PM UTC-4, wrote:
On Thursday, June 21, 2018 at 3:17:56 PM UTC-4, Chris Snyder wrote: On Sunday, November 12, 2017 at 10:20:27 AM UTC-5, wrote: I've spent some time reading the FAA's response to the SSA in regards to the IS-28B2 found here, http://www.ssa.org/files/member/FAA%...7%20-%20Signed[2543].pdf I'm curious how it applies to the 3,000 hour service life extension for say a Schleicher ASW-15 sailplane. I have the same question about a DG-200. Is a service life extension required in the US? The Lark was life limited. It did not have a provision for service life extension. The FAA provided a way to extend life by condition, as I recall. The other manufacturers do have that provision so owners have to comply with the inspection specified to ensure continued airworthiness. UH For accuracy, as opposed to my recollection with respect to the Lark see: http://www.ssa.org/files/member/FAA%...7%20-%20Signed[2543].pdf UH |
On Friday, June 22, 2018 at 4:44:43 AM UTC-7, Chris Snyder wrote:
The Lark was life limited. It did not have a provision for service life extension. The FAA provided a way to extend life by condition, as I recall.. The other manufacturers do have that provision so owners have to comply with the inspection specified to ensure continued airworthiness. UH Thank you for the confirmation. If anyone has gone through the 3000h inspection process for a DG, I'd appreciate any information you can share. Chris Hi Chris, We did a 3000hr inspection on a DG100G with the assistance of Rex at Williams Soaring. It took about a day to go through everything. Nothing really too difficult or special, just checking and comparing things to their specifications. The hassle of course is paying the service fee and then buying the inspection form. But beyond that, it's just like doing an extensive annual where you're doing some measurement of play in control circuits or throw of ailerons. Morgan |
Wow, you dont do all control throws at every annual, its mandatory here in Oz.
On Sunday, 24 June 2018 04:18:48 UTC+3, Charlie Quebec wrote:
Wow, you dont do all control throws at every annual, its mandatory here in Oz. I did once to a factory new Discus 2 (first annual). Aileron throw was way out of spec. After that measuring these did not seem so important anymore... |
On Sat, 23 Jun 2018 18:18:46 -0700, Charlie Quebec wrote:
Wow, you dont do all control throws at every annual, its mandatory here in Oz. Same in the UK. -- Martin | martin at Gregorie | gregorie dot org |
Transponder Inspection Not Required? | Chip Bearden | Soaring | 14 | May 8th 08 07:38 PM |
Mandatory inspection of Schleicher wooden gliders. | W.J. \(Bill\) Dean \(U.K.\). | Soaring | 2 | June 7th 05 10:15 PM |
Service Manual - 50 hour inspection | O. Sami Saydjari | Owning | 1 | April 8th 04 03:17 PM |
100 Hour Inspection Question | FryGuy | General Aviation | 59 | November 19th 03 04:01 AM |
100 Hour Inspection Question | FryGuy | Piloting | 58 | November 19th 03 04:01 AM |
