Ventus 3F - Fatal
Old July 24th 18, 08:29 PM posted to rec.aviation.soaring
Blue Whale
Default Ventus 3F - Fatal
OK, I'm an idiot, don't "PowerFLARM units also include an IGC approved GPS flight recorder?"
  #52
Old July 24th 18, 08:45 PM posted to rec.aviation.soaring
Good question! Yes, it certainly does.
"This option will enable you to prove records up to and including diamond badges in accordance with FAI Sporting Code. The option adds a strong cryptographic signature to IGC files as well as enables task declarations. The pressure sensor is uncalibrated, since calibration isn’t necessary for most flights."
The IGC file format does allow for airspeed info, of course, but PowerFLARM does not record Airspeed records in its IGC files, which are limited up to the three diamond badges.
  #53
Old July 24th 18, 09:56 PM posted to rec.aviation.soaring
On Tuesday, July 24, 2018 at 10:13:02 AM UTC-4, Jonathan St. Cloud wrote:
On Tuesday, July 24, 2018 at 1:23:25 AM UTC-7, wrote:
One last time... FLARM does not need, nor does it record airspeed, for a simple reason: airspeed cannot be used to calculate closure rates between your aircraft and others, or ground obstructions. It works entirely from GPS fixes. It only uses a pressure sensor to enhance altitude data, but does not strictly need it. To my knowledge, no FLARM devices have inputs for airspeed.
Read the manual, folks. It's all documented there, in great detail.
Alarm doesn't record airspeed, but some flight computers do. I know the LXNav records airspeed, flap position ...etc. perhaps this brand new glider had a modern flight computer?
Some that record lose the last few(up to 15) seconds of the file because the data has not been written to memory. If power is disconnected in the crash this data may be lost.
UH
  #54
Old July 25th 18, 05:20 AM posted to rec.aviation.soaring
Frank Whiteley
UH
That is quit correct, the 15 seconds or so of buffered data may be lost. Those who listen to satellite radio experience this buffer effect when driving through tunnels.
I looked at Renny's OLC logs and his tracker logs. He appears to have accumulated something around 7 hours in the glider. The only thing that appeared oddly interesting about the day in question was that he didn't climb out nor get very far away from Moriarty like the other pilots that day. It could have been he wasn't feeling well, had other plans later that day, or was experimenting with something. I wonder if he may have been experimenting with aft-CG, now that he had some time in the glider. If he wasn't comfortable with how it was handling, it might explain the local nature of the flight, but might also explain an inadvertent departure. I didn't go after the PowerFlarm tracks in time to get a copy, but I know who did. Having helped the FAA and NTSB with a post accident glider fatality, I have some idea of their approach and maybe the limits of what they do. I also know that they will take issue with local coroners and investigations if warranted. Yet, sometimes they don't get all of the information and that the real cause may never be officially revealed or discovered, sometimes under 20 years later, because they never interviewed all concerned.
Frank Whiteley
  #55
Old July 25th 18, 05:31 AM posted to rec.aviation.soaring
Frank Whiteley
UH
Frank Whiteley
until 20 years later
  #56
Old July 25th 18, 04:26 PM posted to rec.aviation.soaring
Tim Taylor
Was the log from his first flight available? My understanding is there was a similar issue with the first flight. It would be helpful to compare the first and fourth flight logs.
  #57
Old July 25th 18, 04:44 PM posted to rec.aviation.soaring
Frank Whiteley
Renny's OLC logbook for 2018 and his inReach flight logs are available online. However there's no upload to OLC for the fourth flight. There may be a copy in the hands of the FAA/NTSB if recovered from the glider.
  #58
Old July 27th 18, 05:38 AM posted to rec.aviation.soaring
Reminds me of losing Pat Page. Very sad news
God bless him and his family
  #59
Old August 17th 18, 04:03 AM posted to rec.aviation.soaring
On Sunday, July 15, 2018 at 4:22:03 AM UTC-6, wrote:
On Thursday, July 12, 2018 at 9:45:06 PM UTC+2, Jock Proudfoot wrote:
https://www.usnews.com/news/best-states/new-
mexico/articles/2018-07-11/albuquerque-man-dies-in-glider-crash-
near-moriarty-airport
He was so excited about his new V3.
There's a hint. Not saying this is the cause for this accident, but it's sad to see how many people in the past have gotten into trouble for being too confident flying a new aircraft they haven't yet fully figured out. I know all of you who have been around aircraft for any significant amount of time know what I am talking about. Last time I saw this happen was in Mass., where a new pilot from the UK had never flown an aircraft with flaps and got them wrong on final. He ended up in a tree at the far end of the runway, thankfully with nothing but a bruised ego, but we never saw him again.
Was that guy flying a PIK-20B by any chance?
  #60
Old August 17th 18, 09:09 AM posted to rec.aviation.soaring
I honestly don't remember, this was some years ago. I left that club because I considered it to have the worst attitude towards safety I had ever seen.
Fatal this afternoon Gene Seibel Piloting 6 March 7th 07 09:22 PM
1 Fatal ...r.a.h or r.a.p? Montblack Piloting 81 February 12th 06 08:54 AM
1 Fatal ...r.a.h or r.a.p? Montblack Home Built 99 February 12th 06 08:54 AM
1 Fatal ...r.a.h or r.a.p? Montblack Piloting 38 February 9th 06 02:00 PM
Fatal at Omarama Philip Plane Soaring 0 January 12th 05 07:52 PM
