A complicated question about LiFePO4 batteries, - and switching.
Old July 26th 18, 07:34 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Default A complicated question about LiFePO4 batteries, - and switching.
On Thursday, July 26, 2018 at 10:10:25 AM UTC-7, Dan Marotta wrote:
Right on, Mark.
As a former jet jockey, myself, I prefer simplicity and fewer
switches.Â* And, whereas one big battery would be nice (forgetting
single point failures), space quickly becomes an issue.Â* It's much
easier to locate two or more smaller batteries around the ship than
finding a place for a big one.Â* One of my friends removed the nose
ballast from his glider and replaced it with an SLA battery.Â* A much
better use of lead, don'tcha think?
...And if you want more switches, go to an air museum and take a
look in the cockpit
of a MiG-21...
On 7/25/2018 8:55 PM,
There's a lot to be said for reducing component count.
Yes, there is a definite charm to single point-of-failure systems.
But charm don't count when the failure occurs and you are out of backups and ideas.
Dan, 5J
I always thought the Migs looked best while on fire!
  #62
Old July 26th 18, 11:41 PM posted to rec.aviation.soaring
kinsell
Right on, Mark.
look in the cockpit
of a MiG-21...
I got an idea! How about you keep flying the A/C? Do you fly a glider
that crashes if you lose the panel? In 40 years of flying with a
single battery for the avionics, I've never lost the panel. Absolutely
could happen. Not catastrophic if it does.
The reality is all the solutions proposed have single points of failure.
If you can't handle an occasional failure, maybe find a different hobby?
  #63
Old July 27th 18, 01:27 AM posted to rec.aviation.soaring
2G
Right on, Mark.
look in the cockpit
of a MiG-21...
Early on when I was more careless about checking on the health of my battery, I have had electrical failures while flying. Since then I have only been inconvenienced a few times on the ground when my batteries were incapable of starting the engine. That said, having a backup is not a bad idea. Especially for my new glider where the primary flight display is electronic. Even then, I could still fly the glider by visual reference only.
Tom
  #64
Old July 27th 18, 03:06 AM posted to rec.aviation.soaring
Let's get something straight. I am NOT going to bail out if I lose the battery, OK? But IF the panel goes out when I am 100 miles away from the home 'drome, and it's getting late in the day, I don't necessarily need the added hassle of not having my moving map, electronic vario and instruments, my transponder, radio and all those helpful little devices.
We enjoy the benefits of many technologies on cross-country flights. It's not to say that we HAVE to depend on them, but we use them to our advantage much of the time.
When I am way out of simple glide ratio of the field, I like to have some information about the wind, along with things like communication and traffic avoidance.
If I was a "twirly bird," screwing around the airport no farther away than a 20:1 glide, I wouldn't care. But with the sort of flying I prefer, I will not depend on a single power source. And, yes, I had a failure earlier this year due to a poor ground connection on one battery. But I switched to number two, flew two more hours and tightened the screw on the ring terminal when I got back. My own fault for not securing the connection in the first place, BUT!...
I had a backup. And another after that.
  #65
Old July 27th 18, 03:29 AM posted to rec.aviation.soaring
Talking about backup batteries, I sometimes carry a portable USB "power bank" as a backup power source for my flight computer (Nook), in case of problems with the main glider battery, 12v-5V converter, or the associated cabling. I found one of the rare models with a real (slide) on-off switch - the far more common ones with a pushbutton seem to turn themselves off whenever the Nook isn't drawing enough current.
So, unlike the LiFePO4 batteries discussed in this thread, this is a lithium-polymer battery, a less stable chemistry, albeit a lot smaller (about 2-3AH at 5V). Is it safe enough to carry in the cockpit? Before you reflexively say "no", remember that you are (probably) carrying at least one such battery, in your cellphone. There's also one inside the Nook, and any other tablets people use in the cockpit. And inside some varios, Portable powerFlarm, who knows what else - almost anything that is rechargeable these days.
  #66
Old July 27th 18, 09:21 AM posted to rec.aviation.soaring
Charlie Quebec
I use a cheap android phone with xcsoar, kept in the side pocket, fully charged. Powered off it can be going in a minute, and using its own GPS.
I have a mechanical Winter as vario backup. You dont get to go solo here without the ability to do a circuit and land with all instruments covered.
Losing power would little to no inconvenience.
A truly independent backup that costs less than $100.
  #67
Old July 27th 18, 01:53 PM posted to rec.aviation.soaring
I have a mechanical variometer and a chart. They have gotten me home when needed for more than 40 years. I expect they would again albeit without a flight log.
That said the only power issue I've had was due to a very low primary battery and a backup that wasn't charged as I thought. I turned everything off except the ClearNav and got around OK.
FWIW
UH
  #68
Old July 27th 18, 04:24 PM posted to rec.aviation.soaring
Jonathan St. Cloud
I have a LxNav S3 with the UPS battery pack, which according to specs should give me 8 hours of vario with audio should I lose ship's main bus, and all those pretty glass instruments. Coupled with a JSW, Super Class, wiz wheel it is just like my first 300 hours of xc flying before I purchased the most modern flight computer made, at the time, the B100. I also have a real sectional(s) for the area I fly, and iGlide loaded on a phone zipped into my pants on flight mode.
  #69
Old July 28th 18, 12:45 AM posted to rec.aviation.soaring
kinsell
On 07/25/2018 08:44 PM, kinsell wrote:
On 07/24/2018 08:16 PM, Craig Funston wrote:
On Tuesday, July 24, 2018 at 2:22:09 PM UTC-7,
On Tuesday, July 24, 2018 at 12:05:18 PM UTC-4, OHM Ω
http://aviation.derosaweb.net wrote:
On Tuesday, July 24, 2018 at 9:31:44 AM UTC-5, Dan Marotta wrote:
In my last experimental glider I used two rather stout SPST toggle
switches to control my two LiFePO4 batteries.Â* At some point of the
flight I would switch the second battery on and then switch the first
battery off.Â* I don't think it was really necessary given the
longevity
of these batteries compared with the SLAs that I used previously, I
simply switched about half way through the flight so that both
batteries
would get some use.Â* I like John's idea with the MOSFETs.
On 7/23/2018 10:43 PM, Andy Blackburn wrote:
On Wednesday, June 20, 2018 at 6:27:33 AM UTC-7, OHM Ω
Andy,
I have used the ideal diodes mentioned by Shaun McLaughlin
(http://re-voltage.eu/ US$27 each) as I was given a pair to test
with.Â* They do what they say with minuscule voltage drops across
them.Â*Â* Full disclosure, I am currently using two 1N5821 Schottky
diodes in my panel right now (page 74 of my presentation) -
small, simple, cheap, plentiful, robust, and easy to mount.
That being said - the availability of inexpensive ideal diodes
has exploded in recent years mainly for use in systems like solar
panel arrays.Â* See
https://www.ebay.com/sch/i.html?_fro...es%29&_sacat=0.
I also like the increasing range of mounting styles available
allowing for placement options behind our increasingly cramped
panels.
John (OHM),
Yup, I have one of Shaun's (on your recommendation) and some of
the anti-revere-irrigation ones. I haven't installed either.
My current install uses the Schleicher rotary switch to select:
Battery 1, Battery 2, Battery 1+2 (through diodes), Battery 3
(tail). I use a bank of capacitors connected through a power
resistor to energize the circuit when the switch is between
batteries.
If I had to do it again I would use ideal diodes (though as others
have mentioned this is really not nearly a necessary with LiFePO4
batteries since they go through voltages below 11v quite quickly
on my battery tester). I would also separate the batteries to
individual switches to eliminate the switch as a single point of
failure.
Andy Blackburn
9B
Dan, 5J
Dan - Do you have diodes in this circuit to prevent cross-charging
of the batteries?
I will repeat something I said above that (without diodes) putting
the batteries in parallel can cause a large current to flow from the
"high" battery to the "low" battery.Â* Effectively one battery is
charging the other.
For dumb SLA batteries this will almost certainly blow the fuse on
your batteries (you do have a fuse right at your battery's positive
terminal, right??).
On lithium batteries, which probably have intelligent current
limiting electronics inside, this should not be an issue.Â* But
notice the words "probably" and "should".
YMMV.Â* Be careful out there.
- John OHM Ω
How much current do you project when switching from a low LiFe at
12.4 volts(pretty much done) to high at 13.7? I have been doing this
switching with SLA batteries for 25 years. Switch new one on- switch
old off a second or two later. Have not blown up anything yet.
UH
Plus one. KISS principle.
Two switches and two fuses should work fine, certainly an improvement
over some of the Rube Goldberg solutions proposed here.
But two batteries, two fuses, and two Schottky diodes would be an
improvement.Â* Perfect for everyone except jet jockeys who want more
switches to flip.
Finally, one properly sized battery with a fuse is probably the best
solution, half the number of BMS boards to blow up.Â* Can't get much
simpler than that.Â* There's a lot to be said for reducing component count.
Speaking of losing the panel, Garret Willat just posted a video on FB of
flying in the Czech Republic with no avionics power, which also took out
his engine controller. Did have a paper map and mechanical vario.
  #70
Old July 28th 18, 04:33 AM posted to rec.aviation.soaring
jfitch
I have a mechanical Winter as vario backup. You dont get to go solo here without the ability to do a circuit and land with all instruments covered..
I'm using an iPhone X with iGlide as the primary tactical display. If the avionics battery and everything connected to it fries, iGlide simply switches to internal GPS, barometer and battery. It will give a warning about the charge power going out, if you miss that it is seamless enough that you may fly the rest of the day without noticing. The main thing I notice is no more Flarm targets to leech from.
On the other hand, with a well done installation the chances of the whole panel failing should be quite remote. I'v got two independent batteries with two independent supply paths to the power bus - which is the single point of failure but being a solid piece of copper fairly reliable.
A Simple Question About LiFePO4 Batteries [email protected] Soaring 49 May 25th 18 04:27 PM
LiFePO4 Batteries on sale. [email protected] Soaring 20 December 9th 15 05:34 PM
K2 vs. StarkPower LiFePo4 batteries Fox Two[_2_] Soaring 36 April 16th 15 05:14 PM
LiFePO4 Batteries vontresc Soaring 56 June 27th 14 07:25 PM
LiFePO4 batteries JS Soaring 26 October 15th 12 02:51 PM
