Electric Winch Project
Old September 2nd 18, 10:20 PM posted to rec.aviation.soaring
AS
Default Electric Winch Project
On Sunday, September 2, 2018 at 8:43:29 AM UTC-4, gotovkotzepkoi wrote:
Germans have had an electric winch for a long time. Nothing now. Don't
hold your breath for one built in the US. Won't happen. Charge with an
internal combustion engine? What's the point? Why not just use a piston
engine for the winch then?
gotovkotzepkoi
Hi Goto,
oh my god! Let's not do something new! Lets not leave the beaten path!
That's exactly how we ended up with planes still powered by '30s technology - no progress there for decades.
As Herb said, Bill's design and development is a huge step forward and it should be supported by the US-soaring community because it will make a difference in the future!
Uli
'AS'
Old September 2nd 18, 10:32 PM posted to rec.aviation.soaring
AS
On Sunday, September 2, 2018 at 11:15:43 AM UTC-4, Dan Marotta wrote:
Didn't the German winch require being hooked up to the electrical grid?Â*
It seems the one currently under discussion would be self contained and
portable (on the back of a truck).
Dan, 5J
Hi Dan,
the Elektostart winch in Germany has 50 starter batteries on board which supplied the bulk of the current during the launch. Since the electric infrastructure is so much more densely developed in Europe, it is never too far to the next power tie-in. A relatively low Amp connection is all that's needed to recharge the batteries between launches. Some clubs operating this winch trenched a cable to either end of their field and just plug it in.
The early Elektrostart winches had some issues with the software for the controller, which - if I remember correctly - was an industrial VFD. There were some instances reported where the controller couldn't cope with line tension oscillations but that is all worked out now.
As much as I like the winch I built for my club - powered by one kick-a$$ Ford 460 BB - electric drive is the way of the future!
Uli
'AS'
Old September 2nd 18, 10:35 PM posted to rec.aviation.soaring
Dan Marotta
....and haul/pump the water.
All the electric winch designs I know about (and I assume the new US
design is similar) require three things: a power supply, a large electric
motor and a battery bank to act as a buffer between the first two items.
The German Electrowinde winch needs a 12-20 kw mains supply to feed a
220kw motor via its battery buffer, so the batteries aren't just for
decoration.
It seems to me that the winch motor and battery bank capacity will be
much the same whether the winch is configured as a towable trailer, on a
truck chassis or built into a permanent building: they all need the same
three part power train and it really doesn't matter whether the power
source is the mains, a COTS 12-12kw trailer generator parked alongside or
a truck with all three items installed on it.
A major issue for a mains-powered electric winch, in the UK anyway, is
the cost of cabling the airfield. We looked at it some years back: there
are four places were we put our winch - normally on one end of 04/22 and
less often on one end of 16/34 (obviously this is wind dependent), so
we'd need to wire up all four points on the field with buried cables, and
the winch points for 34 and 22 are both around 1km from the club house
and hence the nearest mains supply. Wiring our airfield would be quite
expensive. Consequently, we've gone with a Skylaunch running on LPG
(cheap and environmentally benign fuel). And we already had the tractor
used to move it between garage and the day's winchpoint.
What's the point? Why not just use a piston engine for the winch then?
Because a (much) smaller engine driving a generator to keep the battery
bank topped up is probably more economical to run than a socking great V8
being running intermittently at high power, particularly when you include
the cost of wear and tear from temperature-cycling the big engine.
Martin | martin at
Gregorie | gregorie dot org
I hear there's an electric winch at the gliding club at Unterwossen in
Germany. AIUI it is very fixed - in a concrete bunker. The site is in a
valley on the edge of the Alps so launching is always in the same
direction.
I've wondered if the best way to launch is by gravity, a weight falling
into a mine shaft and attached to the glider by a cable. If you have a
supply of water then the weight is by filling a tank. At the end of the
launch you dump the water, pull the much lighter tank back up, then refill
it. Given enough room you could have a circular airfield round the mine
shaft. The only energy that you need to supply is to retrieve the tank and
cable.
A few things to sort out but it's a start.
Chris
Dan, 5J
Old September 2nd 18, 10:45 PM posted to rec.aviation.soaring
Dan Marotta
I agree, Uli.
When Black Forest bought a small block Chevy winch from the Air Force
Academy.Â* I and a couple of others removed the engine and installed a
big block Chevy (454 cu. in.).Â* It was pretty healthy!
Dan, 5J
Hi Dan,
Uli
'AS'
Dan, 5J
Old September 2nd 18, 11:19 PM posted to rec.aviation.soaring
Bob Youngblood
gotovkotzepkoi
I can tell you that the current starting load for a 430 hp electric motor is substantial. Don't know if they are using a soft start or something equal it takes a lot of power to start a 430 hp electric motor. The amp requirements are huge, interesting concept, huge electric requirements. Bob
Old September 2nd 18, 11:22 PM posted to rec.aviation.soaring
Bob Youngblood
gotovkotzepkoi
Old September 2nd 18, 11:23 PM posted to rec.aviation.soaring
Bob Youngblood
gotovkotzepkoi
I think it would take almost 1 mg to start a 430 hp electric motor DOL. Huge power requirement.
Old September 2nd 18, 11:31 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
refill it. Given enough room you could have a circular airfield round
the mine shaft. The only energy that you need to supply is to retrieve
the tank and cable.
I like it!
Just get M C Escher to design the airfield and Bob's Your Uncle!
Martin | martin at
Old September 3rd 18, 12:05 AM posted to rec.aviation.soaring
AS
Bob - they are all using frequency controllers! These are not your on-off industrial motors used to power a belt conveyor or hammer-mill! Think electric cars ...
Uli
'AS'
Old September 3rd 18, 01:44 AM posted to rec.aviation.soaring
I love it!
English Electric Lightning pics 1 [03/10] - English Electric Lightning (probably F.3) landing at Filton, Bristol, England.jpg (1/1) Miloch Aviation Photos 0 July 4th 17 03:34 PM
NASA's Electric Airplane Project Moves Forward Larry Dighera Piloting 5 March 24th 15 09:59 PM
Best winch metrics - what is the best winch operationally? Bruce Soaring 19 July 19th 09 11:45 AM
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 12:33 AM
Electric winch fatality story in August Soaring Bill Daniels Soaring 0 August 14th 04 02:37 AM
