Another Ship came in yesterday with Cobra...........yep, another loose nut! The rubber pad that protects the spar is also being compressed when the jam-nut is tightened, so UH's fix would be the best way to fix this issue. Jam-nut into another jam-nut. While we're looking things over in our trailers, it's not a bad idea to check all the adjustable fittings too. I have seen wing tip (assembly bar) adjustment so far out that the wing tip jumped out as trailer went down a rough road. Also found a scar on my root rib.............fixed it and next time I assembled the ship, the damned scar reappeared! Turned out the padding on the spar saddle, had compressed to the point the root rib started hitting the mid-span wing saddle, as the wing was pulled out.
Cobra is still the best trailer out there, thanks Spindleberger! JJ |
On my last Cobra, I replaced all four with nylock nuts. It took a long time to turn them into position due to the limited space, but it solved the problem permanently.
| Cobra Trailer VIN | MSC | Soaring | 3 | July 1st 18 08:05 PM |
| 2013 Cobra trailer price list needed for TA trailer sale | [email protected] | Soaring | 0 | June 22nd 13 03:42 PM |
| Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! | flyingmr2 | Soaring | 4 | November 16th 10 03:11 AM |
| Cobra Trailer | [email protected] | Soaring | 22 | December 8th 06 12:38 AM |
| FS: Cobra Trailer | Ed Byars | Soaring | 0 | September 22nd 03 05:47 PM |
