Engine monitoring systems for towplanes
Old September 6th 18, 11:03 PM posted to rec.aviation.soaring
Default Engine monitoring systems for towplanes
Hey, gang,
Soon we will be putting an overhauled engine on our Pawnee, and I am wondering if anyone has had experience with or has comments on engine monitoring systems on towplanes.
I am thinking a basic system with all 6 cylinders CHT (and EGT?) monitored, a shock cooling warning system, and data logging. Would monitoring other parameters be useful, also? If so, what parameters (adding sensors adds up $$$)?
Is such a system useful and helpful for our type of flight duty cycle (e.g., towing)? Do the shock cooling warning systems work for our very unique type of operations (I guess they are just an alarm if the rate of CHT drop exceeds a set value?)? Is the data logging useful for monitoring/predicting engine health and life? Am I overthinking/overkilling this issue?????
Thanks,
Old September 7th 18, 05:56 PM posted to rec.aviation.soaring
Brian[_1_]
A Recording engine monitor might be best. As noted engine monitors do tend to increase the heads down time. And looking at the data after the flights might actually be much more useful.
They are quite good at identifying baffling that isn't installed or working right.
They are also very good at helping keep the engine cool, as most experts agree that keeping the CHT's under 400F will extend the life of the engine.
Brian
Old September 8th 18, 01:08 AM posted to rec.aviation.soaring
Brian
CHT is the critical measurement, with cooling rate a close second. It's good to give towpilots clear guidelines, and inform towpilots that engine monitor readings will be downloaded and checked, even if they are not....it will make them pay better attention to the engine parameters.
Old September 8th 18, 04:10 AM posted to rec.aviation.soaring
My experience bringing power back to idle after glider release in less than 30 seconds and then not adding power all the way to landing has not been a problem. Our previous engine was well over TBO when replaced, with no issues.
Having more sophisticated engine monitoring might help to run lean of peak to save gas.
Keeping your head outside the cockpit may save you more than gas.
Old September 8th 18, 11:32 AM posted to rec.aviation.soaring
We went with 6 cyl CHT only.
What I will say is that after the first year.. we don't really stare at it.
BUT.. it exposed some horrible standardization (our own fault) among the tow pilots.
I believe it was worth it's money from that standpoint alone. We didn't discover the operational error until we got comparing notes of temps amongst a few of the pilots.
JP
Old September 8th 18, 08:41 PM posted to rec.aviation.soaring
What kind of airplane?
Your experience certainly differs from my 40 years of running towplanes.
UH
Old September 8th 18, 10:40 PM posted to rec.aviation.soaring
Old September 8th 18, 10:53 PM posted to rec.aviation.soaring
UH
UH, do you think recording engine parameters and analyzing them post flight might be worth the effort?
I do wonder if our standard procedure is deficient, maybe analyzing engine parameters would reveal a bad procedure (or a tow pilot that doesn't follow a good procedure). And it would gather hard data that might show, as Dan suggests, that shock cooling is a myth....
Our procedure is to speed up to 100-110 mph put a notch of flaps down and throttle back to 2200 RPM immediately after release, descend/spiral down while reducing RPM by 100 every 10 seconds, until we get to 1500, then we are free to go to any speed/RPM. Sometimes we sideslip, but not always. Please critique!
Maybe we ought to start a new thread on cooldown techniques....
Cheers,
Old September 9th 18, 12:06 AM posted to rec.aviation.soaring
Your experience certainly differs from my 40 years of running towplanes..
UH
Cheers,
This has been studied and findings published in the past. I think it was in Soaring and was quite some time ago. It may also have been in Free Flight.
Our procedure, used in Super Cub and Pawnee, is to smoothly reduce throttle to 2300 rpm while accelerating to 110 mph. We carry this through the descent, including some of the downwind, followed by gradual reduction as speed is reduced to approach speed. We try to not be less than 2 minutes from release/throttle reduction to throttle closed. We discourage slips because this can make the flow through the cowl unbalanced which can lead to less even cooling.
I know Lycoming does not believe shock cooling is a myth. They have a recommended cooling rate, but I can't quote it from memory.
We have CHT on all 4 cylinders to watch for one getting unusually hot. This tends to be due to a damaged baffle though one time we did find signs of an intake leak that can make a cylinder go lean.
If you want to do the study, go for it and then compare with what your engine manufacturer recommends.
FWIW
UH
Tire Pressure Monitoring Systems for Trailers AS Soaring 6 July 11th 18 04:00 AM
North American Sabreliner pics [1/9] - BAE Systems Flight Systems T-39A flight test aircraft at the Mojave Airport.jpg (1/1) Miloch Aviation Photos 0 January 31st 18 03:41 PM
motorgliders as towplanes Brad[_2_] Soaring 262 March 22nd 09 02:17 PM
Trailer tire pressure remote monitoring systems Eric Greenwell Soaring 11 August 9th 08 06:03 AM
Engine monitoring system VM 1000C experience? Bandit Home Built 0 November 13th 06 01:25 PM
