HPH Glasflugel 304eS FES battery fire
Old September 13th 18, 11:50 AM posted to rec.aviation.soaring
James Thomson[_2_]
Default HPH Glasflugel 304eS FES battery fire
The AAIB report has been published:
https://assets.publishing.service.go...5274a0b344cabd
5/HPH_Glasflugel_304_eS_G-GSGS_09-18.pdf
Old September 13th 18, 07:47 PM posted to rec.aviation.soaring
Ben Hirashima
Thanks for posting. It was a very interesting read. The actions taken by the sailplane manufacturers seem likely to improve the safety of electric propulsion. We're lucky we were able to learn these lessons without anyone getting hurt.
Old January 19th 19, 07:09 PM posted to rec.aviation.soaring
Richard DalCanto
Wow, I'm really impressed with the improvements they have made to the battery packs.
Old January 20th 19, 01:23 AM posted to rec.aviation.soaring
Good read, it says the guy may have dropped the pack but it seemed ok.
"A survey of other FES batteries from the in-service fleet revealed the presence of metallic debris in a significant proportion of those batteries examined."
The solution is to improve warning and containment after a fire starts.
That seems good, but would less spare parts help with before the fire starts?
My guess is the pack builder is tightening up his process.
For now, no charge for the spare parts.
Longer term, looks like a really nice system.
Old January 20th 19, 01:26 AM posted to rec.aviation.soaring
Gary Wayland
What year did they start putting sustainer engines in 304's?
Old January 20th 19, 05:33 PM posted to rec.aviation.soaring
Sean Franke
304 is the line of HpH Sailplanes. 304eS is the 18 meter Shark.
Old January 20th 19, 08:04 PM posted to rec.aviation.soaring
Gary Wayland
I had one of the first 304's from HPH. Number seven... So this is the 18meter Shark... Thanks for the info...
Old January 21st 19, 12:21 AM posted to rec.aviation.soaring
Richard DalCanto
The fix is not just improved warning and containment after a fire starts. From the article, it looks like the cells are packaged and protected much better now:
"The new FES battery features additional nomex-mylar insulation between the cells and an increased quantity of silicone encapsulation of the battery cells to prevent foreign objects from falling between the cells. The edges of the battery cells pouches are covered in an electrically-insulating tape to prevent electrical discharge of the cell should the cell pouch seal fail.. The stainless steel battery cell connector plates have been replaced with anodized aluminium plates which have been demonstrated not to eject machining swarf from screw threads when the connector screws are inserted during assembly."
FYI related to EU/EASA FES Battery Fire AD Bob Whelan[_3_] Soaring 5 September 27th 17 10:06 PM
HPH 304eS at AERO 2015 [email protected] Soaring 6 April 16th 15 11:06 PM
AD on Glasflugel Gliders avH8tor Soaring 6 September 10th 12 06:04 AM
Glasflugel AD BruceGreeff Soaring 8 November 8th 11 01:06 AM
FS:Original Glasflugel 304 Pete Russell Soaring 0 March 6th 06 12:58 AM
