Towrope tensions....Part II
Old October 15th 18, 03:20 PM posted to rec.aviation.soaring
Retting
Default Towrope tensions....Part II
Looking for towrope tensions information applied during a typical AERO tow. Singles and twins up to 600kg/ 1500#.
Perhaps testing was done back in the 60’s before Al Gore invented the internet. Prefer some numbers over methods of achieving.
The Uganda Information Award is still in play .... this thread only .
Credible Best Wag will be considered.
Civil disagreement with counter points encourage.
Numbers boys numbers.
R
Old October 15th 18, 04:59 PM posted to rec.aviation.soaring
R
Retting, you didn't make it clear whether you want the rope forces in the air, or in ground roll, or both.
Some months ago I landed my Russia (total flying weight about 250 kg) at another airport and got an aeroretrieve. Thought I'd try the low tow position for a change (always done high tow before). Once I got stabilized below the towplane's wake, the rope shape was very different from what I expected: it went horizontally away from the towplane, then down to the nose of my glider at a steep angle. When my speed or position changed a bit, the rope sometimes looped back over the nose, trying to kiss my yaw string. I did not like that at all, so went back to high tow. Possible explanation and connection to this thread: 250 kg divided by a lift-to-drag ratio of about 25 at that speed means a rope tension, in level flight, of about 10 kg. With such a light glider the rope tension was so weak that the air drag on the rope in the propwash behind the towplane was stronger, keeping the front half of the rope horizontal.
Old October 15th 18, 05:47 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
horizontal.
Yes, that's very close to my Libelle numbers. In a 6 kt climb the tow
tension is around 39 kg, but over 28kg of that is due to the work being
done by the towplane in lifting to glider at 600fpm. This leaves about 10
kg to be accounted for by the glider's drag. When I first did the
calculation I was surprised that hauling a glider uphill would exceed the
drag load by so much.
I normally winch launch, so pretty much all the aero towing I do each
year is a high tow to 3,500 in the club's Puchacz for annual spin checks,
which are part of the club's mandatory checks at the start of the thermal
season. I have flown low tow during these flights and quite like it, but
have never tried it in my Libelle. Must do so to see how big the bow gets.
As it happens I did aero tow my Libelle once this year, but as it was
just a quick trip to 2000 for a test flight, I didn't even think of going
low.
FWIW, last year the truly amateur TE probe mount in the fin failed (no
idea who installed it, but probably the GSA since they bought the glider
from Glasflugel). However, Glasfaser weren't happy with having both TE
probe and pitot on the fin. So I ended up moving the pitot from fin to
nose to keep Glasfaser happy. They hold the H.201 type certificate and it
says the pitot must be in the nose. I re-used the excellent fin pitot
installation and plumbing as the TE probe mount and pneumatics. The aero
tow was to check that the ASI reading for known values such as stall
speed was still the same (it was) and that the TE probe was working
correctly (it was).
Martin | martin at
Gregorie | gregorie dot org
Old October 15th 18, 07:33 PM posted to rec.aviation.soaring
Retting
Well, I said ‘during tow’ thinking that would cover beginning to end. I need to determine the attachment strength for a tow hook on a towplane.
What might rope tension be from initial roll in grass (thinking start will be highest). I thought maybe testing was done years back and a chart or data existed.
Years ago back when I was teaching at Schweizer, the topic came up and less than 300#, towing the 2-32, 3 adults, behind a 180 Supercub was agreed by Paul and a couple of engineer types. I took it as gospel, but have wondered over the years how close they were.
Now I am really curious.
My previous thread got off track into formulas, winch launching, and pitch angles.
The info provided so far seems encouraging. I thought it might be higher.
R
Old October 15th 18, 07:42 PM posted to rec.aviation.soaring
john firth
R
As posted in Pt I
Steady state calculations are interesting but irrelevant.
Tow rope failure happens on a snatch, because a loop has developed
and then the rope suddenly becomes taut; then the load depends on the
separation rate, the extensibility of the rope and the mass of the glider.
John F
Old October 15th 18, 08:04 PM posted to rec.aviation.soaring
Retting
Agree, but if I can get support for a reasonable starting point, a consensus, then I can work it from there.
R
Old October 15th 18, 08:17 PM posted to rec.aviation.soaring
R
The tow rope (or weak link) are supposed to be able to withstand between 0.8 and 2 times the weight of the glider. What's the point of ensuring that if the attachment to the towplane is built for less than that, e.g., 300 pounds? Why not build that tow hook to handle 2x the flying weight of the heaviest glider you will tow?
Old October 15th 18, 08:31 PM posted to rec.aviation.soaring
I have no decent answer, you can skip from here..........
Soft tire, wet ground, deep grass vs. pavement, dragging brake (or pilot that holds divebrake part way through initial acceleration, yada, yada, yada........), many variables.
Max is usually initial acceleration of the towplane. Soft throttle is less load than "ramming it".
You can find a "range", but it can be huge.
OK, I will bite, why are you asking? The mission statement can yield closer answers to your question vs. the nebulous question you asked.
Not an engineer.
Not trying to be a PITA, although, I usually end up in that pot.
Old October 15th 18, 08:49 PM posted to rec.aviation.soaring
RR
It seems like the practical answer is the one you want is some fraction more than the rope you intend to use. We typically use a 1600 lb tow rope, you want to be sure the mount stays on the plane, and the rope will break when you need it. In our club, we had a contingent that tried to use 1200 lb rope. The result was several rope breaks, all on the ground, mostly with 2 place ships, as the rope came tight after slack takeup or initial roll out.
Rick
Old October 15th 18, 09:15 PM posted to rec.aviation.soaring
James Thomson[_2_]
At 18:33 15 October 2018, Retting wrote:
Well, I said =E2=80=98during tow=E2=80=99 thinking that would cover
beginni=
a
towplane.
Try AC43.13-2B Chapter 8 rather than do your own guessing
Towrope tension?? Retting Soaring 11 October 15th 18 06:19 PM
Aerotow towrope instructions Paul Remde Soaring 23 April 8th 16 10:39 PM
US-Israeli Tensions Escalating Quickly NOMOREWARS_FORISRAEL Naval Aviation 0 March 17th 10 04:04 PM
Tost Retract Towrope on a SuperCub John Sp Soaring 1 July 24th 05 09:09 PM
Towrope sources Paul Remde Soaring 1 January 2nd 05 02:57 AM
