Cheaper tows?
Old October 20th 18, 11:05 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Default Cheaper tows?
On Sat, 20 Oct 2018 14:27:00 -0700, AS wrote:
Towing behind a turbine would be like a cat shot.
Maybe...
Probably the same angle, but LOTS faster than a winch!
Doubtful... One can easily climb at 3-4,000fpm in a winch launch. Can
that tug do that even w/o a glider attached to it?
Uli 'AS'
Here's the fastest and highest winch launch I've ever seen: 4500 ft on a
standard Tost winch using Dyneema rope.
While you're watching the dials go round, remember that this is a metric
glider, so the altimeter is in metres (inner markings are 1000m) and the
vario is m/sec (initial stabilised climb rate is 15 m/s or 30 kts).
http://www.youtube.com/watch?v=-VlRd9-wxQI
Martin | martin at
Gregorie | gregorie dot org
  #42
Old October 20th 18, 11:28 PM posted to rec.aviation.soaring
Bruce Hoult
Maybe...
Doubtful... One can easily climb at 3-4,000fpm in a winch launch. Can that tug do that even w/o a glider attached to it?
In the latest version in skydiving configuration, that NZ ag plane takes 17 jumpers to 12000 ft in 10 minutes, throws them out, and gets back on the ground in 15 minutes, all up.
I imagine it would do 3000 FPM empty. And what do 17 parachutists weigh, with gear? Probably 1500 kg 3300 lb I guess. It wouldn't notice a single set glider much.
http://diverdriver.com/pac-750xl/
  #43
Old October 21st 18, 01:32 AM posted to rec.aviation.soaring
Pretty cool writeup on the plane. Thanks for posting.
  #44
Old October 21st 18, 04:32 PM posted to rec.aviation.soaring
AS
Maybe...
Thanks for posting that link - impressive, indeed!
Uli
'AS'
Pulse Oximeters are getting cheaper! Uncle Fuzzy Soaring 3 June 13th 09 11:30 PM
Tows at Ely [email protected] Soaring 1 April 22nd 09 12:45 PM
Aerotrekking: Why isn't it cheaper? Larry Dighera Piloting 4 January 21st 07 04:02 PM
A cheaper way to fly? Ronnie Owning 7 June 5th 06 12:54 AM
Flying just got cheaper!! [email protected] Piloting 16 April 28th 06 06:59 PM
