Electric Self Launch System
Old June 11th 18, 10:37 PM posted to rec.aviation.soaring
Dave Nadler
Default Electric Self Launch System
On Monday, June 11, 2018 at 2:55:08 PM UTC-6, wrote:
System provided to me by MGM Compro uses Sony US18650VTC6.
Rated capacity 3000mAh. 18 stacks of 28. 57 lb with enclosure and BMS.
Projected performance at 25KW draw is 12 minutes.
Thanks Hank - Do they provide any specs (feature list) for BMS?
Old June 12th 18, 12:07 AM posted to rec.aviation.soaring
Yep- there is a manual for it. Sent privately.
UH
Old June 12th 18, 12:59 AM posted to rec.aviation.soaring
Dave Nadler
UH
Thanks Hank!
Old October 24th 18, 04:12 PM posted to rec.aviation.soaring
Emir Sherbi
More updates:
https://www.instagram.com/grasshoppersystem/
https://www.facebook.com/charlysierragolf/
Old October 25th 18, 02:48 PM posted to rec.aviation.soaring
I suppose you will provide strong protection to the elevator linkage. If anything goes wrong in the pylon mountings, or parts get loose, you really don't want to risk interference with the elevator control.
The static and TE lines would also very much benefit from protection.
I admire all those who dare such complex work
Aldo Cernezzi
www.voloavela.it
Old October 26th 18, 03:50 AM posted to rec.aviation.soaring
Emir Sherbi
Aldo,
There will be a very thick floor and sidewalls to reinforce the fuselage structure and that will protect the control rod and cables.
If anything get loose it will stay in the motor bay.
Regards
Old October 26th 18, 04:51 AM posted to rec.aviation.soaring
Craig Funston[_3_]
Emir, great to see you moving forward on your project.
I expect you already know this, but at the risk of being redundant, I’ll post anyways. Just thickening the skins in the motor bay area won’t restore the torsional stiffness of the boom. When the hole is cut for the doors the boom goes from a closed tube shape to an open “C” shape. This dramatically reduces the torsional stiffness and strength of that area. You can demonstrate it to yourself with a cardboard tube..
The factories get around this by adding a pair of vertical walls in the engine bay to form two closed “D” shaped tubes, essentially restoring the lost stiffness.
Good luck with your project. I’m looking forward to hearing how it works out.
Best regards,
Craig
  #28
Old October 26th 18, 07:52 AM posted to rec.aviation.soaring
Senna Van den Bosch
Op vrijdag 26 oktober 2018 04:50:09 UTC+2 schreef Emir Sherbi:
Aldo,
Regards
This project looks amazing. Do you have any idea of a price that you would like to get for selling such a kit? Also, with any kind of fittings, is there any probability of them getting loose?
  #29
Old October 26th 18, 01:34 PM posted to rec.aviation.soaring
Emir Sherbi
Craig,
Thanks for the advice. That is the big issue on the project. Is difficult to obtain the same rigidity of a cone like the boom tail once cut. The reinforcement floor and walls will form 3 different enclosed sections with fibers at 45° from the fuselage line.
After the modifications I will test the fuselage with strain gauges to see the new strain distribution and compare them with the original.
  #30
Old October 26th 18, 02:05 PM posted to rec.aviation.soaring
Emir Sherbi
The price of the kit will be around 17.000 USD depending on controller and battery capacity choices without installation.
Now that i left my full time job to continue with this project i can travel to make the modifications by myself.
The fastening part of the fittings will be at plain sight. So if you check out them time to time there must be no problems.
Electric Self Launching System Emir Sherbi Soaring 0 June 4th 18 04:54 PM
FES&electric system batteries krasw Soaring 33 February 25th 17 04:17 PM
ASW24 - electric valve system Norbert Gulczynski Soaring 1 January 25th 15 01:13 PM
Electric Duct Fan (EDF) Self-Launch Glider? CLewis95 Soaring 26 January 20th 11 06:27 PM
Electric self-launch sailplane CH Soaring 2 September 14th 03 01:49 AM
