Discus CS wing water dump seats (seals)
Old October 29th 18, 08:50 PM posted to rec.aviation.soaring
Default Discus CS wing water dump seats (seals)
Per Schempp-Hirth, I am the owner of a Discus CS with NON-Schempp-Hirth water dump seats on the wing dump valves. Per S-H, ALL S-H, including CS's, have aluminum discs for seats. My ship has what appears to be rubber or similar material for seats. Soon, they will be leaking and though I think I have figured out how to replace them, I am open to suggestions from anyone with first-hand knowledge of replacing non-aluminum seats. Big question for that person(s) is where do you get the part? And, what is the serial number of your ship?
Related question: if you own a Discus CS, would you please look at your seats (underside of each wing, near root) and, if you find that yours are NOT aluminum, let me know the serial number so that I can bring S-H that information.
Visible on my seat is a rubber seat in the center of which is a brass hex head with a female 8 mm thread for the pull-down tool. Standard S-H is simply an aluminum disc with and 8 mm female thread.
I am listed on the SSA website and you are welcome to contact me directly there if you prefer.
Thanks for any help.
Old October 30th 18, 12:53 PM posted to rec.aviation.soaring
krasw
All old Schempp valves leak sooner or later (and probably new ones, too). If they leak only a little pilots usually grease the seats. Then the grease collects sand particles and soon you have a moderate leak. Then pilots pull the valve with hand tool and voila, you have a huge leak. The seal is done pretty much between gelcoat and aluminium. It does not take engineer to figure out how good seal can be made with that.
Your rubber seat sounds like space age tech, you might want to hold on to those for a long time.
First rule of all maintenance regarding water ballast: if it works, do not touch it. (Second rule: filter the water).
Old October 30th 18, 02:19 PM posted to rec.aviation.soaring
Dan Marotta
On my LAK-17a I lubricated the valve seats with chap stick.Â* I cleaned
them each time to avoid dirt build up.
Dan, 5J
Old August 3rd 19, 09:41 PM posted to rec.aviation.soaring
Visible on my seat is a rubber seat in the center of which is a brass hex head with a female 6mm thread for the pull-down tool. Standard S-H is simply an aluminum disc with and 6 mm female thread.
Dump Seal Solved!
Since S-H has been of no help at all, I have designed and can produce seals that are hard rubber, seal well with only a touch of wax, and can be replaced from the exterior and without cutting any holes in wings.
Also, this solution would work on virtually any S-H with aluminum dump seals still without cutting holes in wing to do so.
I am listed in the SSA member section if anyone has any interest in this solution.
Old August 4th 19, 03:34 AM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Dump Seal Solved!
How do we get in contact with you? all this thread shows is part of an email.
Richard
Old August 6th 19, 01:54 PM posted to rec.aviation.soaring
Dump Seal Solved!
Richard
Go to SSA.org.Member Resources Member Locator: last name Campbell, State SC.
ASG-29 water dump rates Jonathan St. Cloud Soaring 9 June 10th 16 04:37 PM
Chapstick In Water Dump Valves Dan Marotta Soaring 4 June 21st 12 01:16 AM
Ballast dump time Discus J. Nieuwenhuize Soaring 7 April 27th 07 05:56 AM
Schemp Hirth water ballast dump valves tango4 Soaring 14 September 2nd 04 07:13 PM
Water dump valve rotary seal Bill Daniels Soaring 6 May 10th 04 11:02 AM
