#21
On Wednesday, November 14, 2018 at 2:56:35 PM UTC-5, kinsell wrote:
On 11/14/18 9:03 AM, moshe... wrote: On Tuesday, November 13, 2018 at 11:11:52 PM UTC-5, kinsell wrote: On 11/13/18 6:08 PM, bruce... wrote: Mark, When K2 was fairly new on the market I contacted them asking if Battery Tender Jr. is okay and safe, they replied that it is perfectly okay and nearly the same as their charger. I also contacted Battery Tender Jr. with the reverse question and they said the BTJr is fine for LiFePO4. I used the BTJr for years on my K2 with no issues. They're about $25 on internet sites. Have you measured the amount of charge you're getting into the K2's? It will be considerably less than the rated amount due to using a lead-acid charger. Also, if K2 has cell balancing capability, it won't be used because your Battery Tender doesn't put out enough voltage to make it work. Many simple lead-acid chargers reach up to around 14.2-14.8 volts. That voltage would suffice to charge an LFP battery to well above 90% capacity if it stays there for a while. If it quickly shifts to "float" at 13.5V or so then it won't do well in charging LFP. So simpler is better in this case. Measure what your charger does. And disconnect it after several hours, don't leave it on "float". Hate to break this to you, but at $24, the Battery Tender Junior is one of the cheapest chargers on the market, and is fully featured with a float mode. 14.2 volts wouldn't begin to charge an LFP to "well over 90%" as you claim. If you found a charger that delivers 14.8 volts under load, then it would overcharge an SLA and would be considered defective. If you're going to spend big bucks for an LFP, you ought to get a proper charger for it. Still waiting to hear just how much charge the K2's got in them from a BTJ. -Dave That's the conventional wisdom, but see experimental results he https://www.powerstream.com/lithium-...ge-voltage.htm - well above 90% capacity even at a bit lower than 14V! A cheap dumb 14.x volt fixed-voltage source with limited current output (and perhaps aided by the battery's BMS) would charge an LFP just fine. I'm not saying that's the ideal charger, but in a pinch it would work well enough. I am not happy with the several chargers I have that push SLAs well above 14V (even above 15V), but they may be handy for LFPs. |
At 00:42 15 November 2018, Graham Drinkell wrote:
At 20:09 14 November 2018, wrote: On Wednesday, November 14, 2018 at 2:56:35 PM UTC-5, kinsell wrote: On 11/14/18 9:03 AM, moshe... wrote: On Tuesday, November 13, 2018 at 11:11:52 PM UTC-5, kinsell wrote: On 11/13/18 6:08 PM, bruce... wrote: Mark, When K2 was fairly new on the market I contacted them asking if= Battery Tender Jr. is okay and safe, they replied that it is perfectly oka= y and nearly the same as their charger. I also contacted Battery Tender Jr.= with the reverse question and they said the BTJr is fine for LiFePO4. I us= ed the BTJr for years on my K2 with no issues. They're about $25 on intern= et sites. Have you measured the amount of charge you're getting into the K2's? = It will be considerably less than the rated amount due to using lead-ac= id charger. Also, if K2 has cell balancing capability, it won't be used because yo= ur Battery Tender doesn't put out enough voltage to make it work. =20 Many simple lead-acid chargers reach up to around 14.2- 14.8 volts. Tha= t voltage would suffice to charge an LFP battery to well above 90% capacity= if it stays there for a while. If it quickly shifts to "float" at 13.5V o= r so then it won't do well in charging LFP. So simpler is better in this c= ase. Measure what your charger does. And disconnect it after several hour= s, don't leave it on "float". =20 =20 Hate to break this to you, but at $24, the Battery Tender Junior is one= =20 of the cheapest chargers on the market, and is fully featured with a=20 float mode. =20 14.2 volts wouldn't begin to charge an LFP to "well over 90%" as you=20 claim. If you found a charger that delivers 14.8 volts under load, then= =20 it would overcharge an SLA and would be considered defective. =20 If you're going to spend big bucks for an LFP, you ought to get a proper= =20 charger for it. Still waiting to hear just how much charge the K2's got= =20 in them from a BTJ. =20 -Dave That's the conventional wisdom, but see experimental results he https://www.powerstream.com/lithium-phosphate-charge- voltage.htm - well above 90% capacity even at a bit lower than 14V! A cheap dumb 14.x volt fixed-voltage source with limited current output (an= d perhaps aided by the battery's BMS) would charge an LFP just fine. I'm n= ot saying that's the ideal charger, but in a pinch it would work well enoug= h. I am not happy with the several chargers I have that push SLAs well abo= ve 14V (even above 15V), but they may be handy for LFPs. Personally, I would fly a model aircraft with a lipo battery. Full size, definitely not! They deform at high altitudes, with the possibility of fracturing cells? The best bet is to use military spec batteries that work in space? |
#24
kinsell wrote on 11/14/2018 12:55 PM:
On 11/14/18 9:03 AM, wrote: On Tuesday, November 13, 2018 at 11:11:52 PM UTC-5, kinsell wrote: On 11/13/18 6:08 PM, bruce... wrote: Mark, When K2 was fairly new on the market I contacted them asking if Battery Tender Jr. is okay and safe, they replied that it is perfectly okay and nearly the same as their charger. I also contacted Battery Tender Jr. with the reverse question and they said the BTJr is fine for LiFePO4. I used the BTJr for years on my K2* with no issues. They're about $25 on internet sites. Have you measured the amount of charge you're getting into the K2's?* It will be considerably less than the rated amount due to using a lead-acid charger. Also, if K2 has cell balancing capability, it won't be used because your Battery Tender doesn't put out enough voltage to make it work. Many simple lead-acid chargers reach up to around 14.2-14.8 volts.* That voltage would suffice to charge an LFP battery to well above 90% capacity if it stays there for a while.* If it quickly shifts to "float" at 13.5V or so then it won't do well in charging LFP.* So simpler is better in this case.* Measure what your charger does.* And disconnect it after several hours, don't leave it on "float". Hate to break this to you, but at $24, the Battery Tender Junior is one of the cheapest chargers on the market, and is fully featured with a float mode. 14.2 volts wouldn't begin to charge an LFP to "well over 90%" as you claim.* If you found a charger that delivers 14.8 volts under load, then it would overcharge an SLA and would be considered defective. If you're going to spend big bucks for an LFP, you ought to get a proper charger for it.* Still waiting to hear just how much charge the K2's got in them from a BTJ. Bienno Power has a $25, 12V/4A LiFePO4 charger. I'd trust that over a BT Jr, and it's the same price. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 - "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm http://soaringsafety.org/prevention/...anes-2014A.pdf |
#25
#26
kinsell wrote on 11/13/2018 9:18 PM:
scinating videos on YouTube. However, "safer" isn't actually the same as "safe", LFP's are quite capable of burning, despite what the scholarly articles say.* There have been a number of fires, particularly when they're used as starter batteries.* High charge rates and very high discharge rates seem to cause problems, as homebuilders of small power planes have discovered. There was also that LFP battery fire in an EB-28 in Finland this summer. -Dave Dave, if you look around youtube long enough, you will find that a AAA battery can make a fire. Certainly a 12V lead-acid has enough juice to do that if circumstances are right. The overwhelming evidence of many years of usage of LiFePo4 chemistry in glider batteries suggests that they are as safe as the old gel-cells. Give progress a chance, I'm not saying be a Progressive. Herb If you come across a YouTube video of an AAA battery filling a cockpit with toxic smoke, you be sure to post the link, OK? Meanwhile, this is the sort of progress I can live without: https://www.pilotsofamerica.com/comm...-fires.102016/ I did not see any indication the burning battery had a BMS. Some builders put in the "starter" LiFe batteries that do not have a BMS, so perhaps that is the reason the battery burned. I think LiFe batteries from the usual suppliers (Bienno, K2, Stark - for example) with a BMS, used for instrument batteries, and charged with the recommended charger are as safe as a comparable capacity SLA. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 - "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm http://soaringsafety.org/prevention/...anes-2014A.pdf |
#27
On Friday, November 16, 2018 at 7:20:53 PM UTC-8, Eric Greenwell wrote:
kinsell wrote on 11/13/2018 9:18 PM: scinating videos on YouTube. However, "safer" isn't actually the same as "safe", LFP's are quite capable of burning, despite what the scholarly articles say.Â* There have been a number of fires, particularly when they're used as starter batteries.Â* High charge rates and very high discharge rates seem to cause problems, as homebuilders of small power planes have discovered.. There was also that LFP battery fire in an EB-28 in Finland this summer. -Dave Dave, if you look around youtube long enough, you will find that a AAA battery can make a fire. Certainly a 12V lead-acid has enough juice to do that if circumstances are right. The overwhelming evidence of many years of usage of LiFePo4 chemistry in glider batteries suggests that they are as safe as the old gel-cells. Give progress a chance, I'm not saying be a Progressive. Herb If you come across a YouTube video of an AAA battery filling a cockpit with toxic smoke, you be sure to post the link, OK? Meanwhile, this is the sort of progress I can live without: https://www.pilotsofamerica.com/comm...-fires.102016/ I did not see any indication the burning battery had a BMS. Some builders put in the "starter" LiFe batteries that do not have a BMS, so perhaps that is the reason the battery burned. I think LiFe batteries from the usual suppliers (Bienno, K2, Stark - for example) with a BMS, used for instrument batteries, and charged with the recommended charger are as safe as a comparable capacity SLA. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 - "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm http://soaringsafety.org/prevention/...anes-2014A.pdf Several years ago I had a bad batch of batteries from one of the suppliers you mentioned in your post. 4 to 5 aH capacity in a 10 Ah battery. I quit selling them. I now sell LiFePO4 batteries that I personally test before shipping with a West Mountain Radio computer tester. Document is supplied with the battery. http://www.craggyaero.com/lifepo4_battery.htm Richard www.craggyaero.com |
#28
Richard Pfiffner wrote on 11/17/2018 10:22 AM:
On Friday, November 16, 2018 at 7:20:53 PM UTC-8, Eric Greenwell wrote: https://www.pilotsofamerica.com/comm...-fires.102016/ I did not see any indication the burning battery had a BMS. Some builders put in the "starter" LiFe batteries that do not have a BMS, so perhaps that is the reason the battery burned. I think LiFe batteries from the usual suppliers (Bienno, K2, Stark - for example) with a BMS, used for instrument batteries, and charged with the recommended charger are as safe as a comparable capacity SLA. Several years ago I had a bad batch of batteries from one of the suppliers you mentioned in your post. 4 to 5 aH capacity in a 10 Ah battery. I quit selling them. I now sell LiFePO4 batteries that I personally test before shipping with a West Mountain Radio computer tester. Document is supplied with the battery. http://www.craggyaero.com/lifepo4_battery.htm I test every battery before installing it, also using a West Mountain tester. Over the years, I've had three SLA batteries that had half their rated capacity, and returned them. I've only used one LiFe battery, and it had exactly the rated capacity. Couldn't believe it - tested it again, and got the same answer. |
Battery Chargers | Stan Amyett | Soaring | 2 | March 12th 04 05:27 AM |
Solar Battery Chargers | Jay Honeck | Piloting | 32 | February 22nd 04 11:17 PM |
Battery Chargers | Mike Rapoport | Owning | 11 | December 2nd 03 11:55 PM |
Rechargable AA batteries and chargers | TripFarmer | General Aviation | 2 | October 17th 03 06:34 PM |
Rechargable batteries and chargers....... | TripFarmer | Products | 2 | October 17th 03 06:31 PM |
