Planning to install Trig TT-22 transponder with ADSB -out to my experimental glider.
Trig manual saying that TA 70 GPS is a permanently mounted external antenna. Where is recommended place of installation on gliders? Does anyone installed antenna inside glider fuselage? p. |
On Sunday, December 30, 2018 at 8:12:43 AM UTC-8, wrote:
Planning to install Trig TT-22 transponder with ADSB -out to my experimental glider. Trig manual saying that TA 70 GPS is a permanently mounted external antenna. Where is recommended place of installation on gliders? Does anyone installed antenna inside glider fuselage? p. Why are you installing a TA70 in an experimental glider? See capabilities of TN72 with a smaller internal antenna and TA70 on this page http://www.craggyaero.com/transponder.htm Richard www.craggyaero.com |
Even on your website it says TA-70 recommended. But if a small $49 GPS antenna will work just fine I will try it that way. p
The GPS antenna for my TA70 was installed in the turtle deck area of my
Stemme.Â* An aluminum shelf was fabricated upon which to mount the antenna.Â* It passed inspection and flight test and I got the $500 rebate from the FAA. On 12/30/2018 9:12 AM, wrote: Planning to install Trig TT-22 transponder with ADSB -out to my experimental glider. Trig manual saying that TA 70 GPS is a permanently mounted external antenna. Where is recommended place of installation on gliders? Does anyone installed antenna inside glider fuselage? p. -- Dan, 5J |
| Thread Tools | |
| Display Modes | |
| Trig TN72 Antenna | Andrew Ainslie | Soaring | 17 | April 6th 17 05:21 AM |
| ASW 27 or 27-18 406 ELT & antenna installation | chipsoars | Soaring | 6 | October 10th 09 05:07 PM |
| Antenna installation question | [email protected] | Soaring | 6 | February 28th 08 03:14 PM |
| Antenna Installation on Longez | Glennbob | Home Built | 11 | May 21st 07 04:03 AM |
| FLARM antenna installation | Kevin Neave | Soaring | 5 | January 16th 07 07:53 PM |
