https://en.wikipedia.org/wiki/Bede_BD-10
The Bede BD-10 was Jim Bede's attempt to introduce the world's first kit-built jet-powered general aviation supersonic aircraft. After several years of testing and modifications, the project was taken over by investors in order to produce fully completed civilian and military training aircraft, but these projects were never realized. Five examples were built in total and three of these crashed. Only two examples remain, both unflyable. The genesis of the BD-10 came about after the Bede BD-5 project in the 1970s, when the Federal Trade Commission (FTC) entered Jim Bede into a consent decree, forbidding him from accepting down payments for aircraft for a period of ten years. Bede worked on numerous other projects during this period with preliminary design begun by 1983 on a small jet. Within weeks of the agreement expiring in 1989, he announced plans for the BD-10J under the aegis of Bede Jet Corporation, at the Spirit of St. Louis Airport. The BD-5's failure was due largely to the unavailability of a suitable engine; during the BD-5's history one engine company after another either exited the engine business or went bankrupt. Bede started the new design by selecting a suitable commonly available engine and then designing the aircraft around it. The selected engine was the General Electric J85, widely used in a variety of military aircraft and virtually identical to its civilian counterpart, the General Electric CJ-610, available both in new-build and second-hand markets. Perhaps the best known military applications of the J85 are the twin-engined T-38 Talon and the closely related F-5 Freedom Fighter, with the most familiar civilian application being the early Learjet models. The new BD-10J design bore a strong resemblance to the T-38/F-5, although it was much smaller and used only a single engine. The Williams FJ44 and Pratt & Whitney JT12 were also offered as options. The resulting design featured a shoulder-mounted cropped-delta wing with just over 21 feet (6.4 m) of span and a leading-edge sweep of about 30 degrees. Cropped-delta elevators were also used, although featuring a much greater 50 degree leading sweep. The large canopy extended a fair distance above the fuselage midline, in relative terms, so twin rudders were used on either side to provide clean airflow. All of the controls were strictly mechanical, using pushrods. In order to deal with the increasing control stiffness with increased speed, the design initially specified two control sticks, a small side-stick with limited leverage for low speeds, and a full-sized one mounted in front of the seat with much more leverage for high speeds. Role Recreational aircraft Manufacturer Bede Jet Corporation Fox 10 Corporation Peregrine Flight International Monitor Jet Designer Jim Bede First flight 8 July 1992 Status Experimental Number built 5 The first prototype, N2BD, was completed in 1991, the first damaged occurred before the aircraft was completed. A newly minted A&P Licensed mechanic didn't follow the specifications for the static landing gear strut. He used thin walled aluminum pipe, which failed to hold the weight of the aircraft. This caused the twin booms to twist and the vertical stabilizers to be canted at different angles. This structural damage was never fixed and wasn't noticed unless looked head-on. The aircraft started testing at Mojave in July 1992. Early in testing it suffered more minor damage when the gear failed on landing, but the damage was repaired and it returned to flying. However, this aircraft was significantly heavier than originally intended, the empty weight ballooning from the design 1,600 to the prototype's 2,250 lb (1,020 kg). In order to keep the weight and balance within limits, fuel capacity had to be cut dramatically to 263 gallons, reducing range from the original 2,000 miles (3,200 km) to 1,500, although it was never to demonstrate anything beyond about 500 miles (800 km). Speed was equally poor; even at full thrust the plane was barely able to reach the transonic, at Mach 0.83. Eventually 63 $10,000 deposits (45 in the United States) were placed for the kits. By 1994 three additional airframes were under construction, one by Mike Van Wagenen of Nevada, another by Jim Priebe in Ohio, and the last by Frank Everett in California. However, during this period Chief Test Pilot Skip Holm left the project. Work on the BD-10J project by Bede seems to have stopped at about this point. Fox's first prototype, N9WZ, was completed in 1994 and entered testing. Although it had been modified to incorporate the stronger tail of Bede's design, it broke up mid-air on 30 December 1994 when the vertical stabilizers failed due to a crossflow condition, killing Van Wagenen. The National Transportation Safety Board (NTSB) later concluded that Bede's fix was severely under-designed, and offered nowhere near the strength that had been calculated. Fox had not performed any testing to verify the redesign of the vertical stabilizer spars before continuing flight testing, instead relying upon the data provided by Bede. In 1996 Bede sold the military rights to Monitor Jet of Canada, which intended to equip it with the Pratt & Whitney Canada JT15D engine and sell it as a basic trainer as the MJ-7. Monitor also purchased the single so-far completed kit, N700JP, its pilot apparently not interested in flying it. There appears to have been some interest on the part of the Portuguese Air Force as a replacement for its fleet of Alpha Jets in the training role, but nothing ever came of this. The aircraft was even mentioned briefly during the Canadian Parliamentary Debates. When a group of investors in Bede's company threatened to foreclose, Bede declared bankruptcy in 1997. The investors formed Vortex Aircraft in San Diego intended to produce completed versions as the PhoenixJet for the military market, terminating Monitor's agreement due to a claimed failed payment. Oddly, Monitor purchased the original prototype, N2BD, at the same auction, although for reasons that are unclear it appears it was never moved. Neither company managed to find any interest in the design, and both companies disappeared, the lawsuit being dropped in 1998. This left only the second kit-built aircraft, N7FF, still flying. It broke up in midair off the southern coast of California in 2003 after pilot Frank Everett had radioed a MAYDAY call in which he stated that the aircraft was "disintegrating". Everett did not survive. Specifications (BD-10J) General characteristics Crew: one pilot Capacity: 1 passenger Length: 28 ft 10 in (8.794 m) Wingspan: 21 ft 6 in (6.55 m) Height: 8 ft 1 in (2.46 m) Wing area: 98 ft2 (9.1 m2) Empty weight: 1,600 lb (725 kg) Gross weight: 4,430 lb (2014 kg) Powerplant: 1 × General Electric CJ-610, 2,950 lbf (13.12 kN) Performance Maximum speed: Mach 1.4 Cruise speed: 593 mph (957 km/h) Range: 1,550 miles (2,499 km) Service ceiling: 45,000 ft (13,715 m) Rate of climb: 30,000 ft/min (152 m/s) * |
Bede BD-5 pics 2 - Bede BD-5 j.jpg ... | Miloch | Aviation Photos | 0 | March 2nd 18 02:57 PM |
Bede BD-5 pics [8/9] - Bede BD-5 cockpit NZpart2-2006132.jpg (1/1) | Miloch | Aviation Photos | 0 | March 2nd 18 02:56 PM |
Bede BD-5 pics [7/9] - Bede BD-5 166836.jpg (1/1) | Miloch | Aviation Photos | 0 | March 2nd 18 02:56 PM |
Bede BD-5 pics [6/9] - Bede BD-5 82273.jpg (1/1) | Miloch | Aviation Photos | 0 | March 2nd 18 02:56 PM |
Bede BD-5 pics [3/9] - BEDE 5 cockpit 2.jpg (1/1) | Miloch | Aviation Photos | 0 | March 2nd 18 02:56 PM |
