https://en.wikipedia.org/wiki/North_..._A-5_Vigilante
The North American A-5 Vigilante is an American carrier-based supersonic bomber designed and built by North American Aviation for the United States Navy. Its service in the nuclear strike role to replace the Douglas A-3 Skywarrior was very short; however, as the RA-5C, it saw extensive service during the Vietnam War in the tactical strike reconnaissance role. Prior to the unification of the Navy designation sequence with the Air Force sequence in 1962, it was designated the A3J Vigilante. At the time of its introduction, the Vigilante was one of the largest and by far the most complex aircraft to operate from a United States Navy aircraft carrier. It had a high-mounted swept wing with a boundary-layer control system (blown flaps) to improve low-speed lift. There were no ailerons. Roll control was provided by spoilers in conjunction with differential deflection of the all-moving tail surfaces. The use of aluminum-lithium alloy for wing skins and titanium for critical structures was also unusual. The A-5 had two widely spaced General Electric J79 turbojet engines (the same as used on the McDonnell Douglas F-4 Phantom II fighter), fed by intake ramps and a single large all-moving vertical stabilizer. Preliminary design studies had employed twin vertical fin/rudders. The wings, vertical stabilizer and the nose radome folded for carrier stowage. The Vigilante had a crew of two seated in tandem, a pilot and a bombardier-navigator (BN) (reconnaissance/attack navigator (RAN) on later reconnaissance versions) seated on individual North American HS-1A ejection seats. Despite being designated by the US Navy as a "heavy", the A-5 was surprisingly agile; without the drag of bombs or missiles, even escorting fighters found that the clean airframe and powerful engines made the Vigilante very fast at high and low altitudes. However, its high approach speed and high angle of attack in the landing configuration made returning to the aircraft carrier a challenge for inexperienced or unwary pilots. The Vigilante had advanced and complex electronics when it first entered service. It had one of the first "fly-by-wire" systems on an operational aircraft (with mechanical/hydraulic backup) and a computerized AN/ASB-12 nav/attack system incorporating a head-up display ("Pilot's Projected Display Indicator" (PPDI), one of the first), multi-mode radar, radar-equipped inertial navigation system (REINS, based on technologies developed for North American's Navaho missile), closed-circuit television camera under the nose, and an early digital computer known as "Versatile Digital Analyzer" (VERDAN) to run it all. Role Nuclear strike bomber or reconnaissance aircraft National origin United States Manufacturer North American Aviation First flight 31 August 1958 Introduction June 1961 Retired 20 November 1979 Status Retired Primary user United States Navy Produced 1956–1963 1968–1970 Number built 156 Under the Tri-Services Designation plan implemented under Robert McNamara in September 1962, the Vigilante was redesignated A-5, with the initial A3J-1 becoming A-5A and the updated A3J-2 becoming A-5B. The subsequent reconnaissance version, originally A3J-3P, became the RA-5C. The Vigilante's early service proved troublesome, with many teething problems for its advanced systems. Although these systems were highly sophisticated, the technology was in its infancy, and its reliability was poor. Although most of these reliability issues were eventually worked out as maintenance personnel gained greater experience with supporting these systems, the aircraft tended to remain a maintenance-intensive platform throughout its career. The A-5's service coincided with a major policy shift in the U.S. Navy's strategic role, which switched to emphasize submarine-launched ballistic missiles rather than manned bombers. As a result, in 1963, procurement of the A-5 was ended and the type was converted to the fast reconnaissance role. Despite the Vigilante's useful service, it was expensive and complex to operate and occupied significant amounts of precious flight deck and hangar deck space aboard both conventional and nuclear-powered aircraft carriers at a time when carrier air wings, with the introduction of the F-14 Tomcat and S-3 Viking, were averaging 90 aircraft, many of which were larger than their predecessors. With the end of the Vietnam War, disestablishment of RVAH squadrons began in 1974, with the last Vigilante squadron, RVAH-7, completing its final deployment to the Western Pacific aboard USS Ranger in late 1979. The final flight by an RA-5C took place on 20 November 1979 when a Vigilante departed NAS Key West, Florida. Reconnaissance Attack Wing One was subsequently disestablished at NAS Key West, Florida in January 1980. The Vigilante did not end the career of the A-3 Skywarrior, which would carry on as photo reconnaissance aircraft, electronic warfare platforms, aerial refueling tankers, and executive transport aircraft designated as RA-3A/B, EA-3A/B, ERA-3B, EKA-3B KA-3B, and VA-3B, into the 1980s and early 1990s. Specifications (A-5A Vigilante) General characteristics Crew: 2 Length: 76 ft 6 in (23.32 m) Wingspan: 53 ft 0 in (16.16 m) Height: 19 ft 5 in (5.91 m) Wing area: 701 sq ft (65.1 m2) Empty weight: 32,783 lb (14,870 kg) Gross weight: 47,631 lb (21,605 kg) Max takeoff weight: 63,085 lb (28,615 kg) Powerplant: 2 × General Electric J79-GE-8 after-burning turbojet engines, 10,900 lbf (48 kN) thrust each dry dry, 17,000 lbf (76 kN) with afterburner Performance Maximum speed: 1,149 kn (1,322 mph; 2,128 km/h) at 40,000 ft (12,000 m) Maximum speed: Mach 2 Combat range: 974 nmi (1,121 mi; 1,804 km) (to target and return) Ferry range: 1,571 nmi (1,808 mi; 2,909 km) Service ceiling: 52,100 ft (15,900 m) Rate of climb: 8,000 ft/min (41 m/s) Wing loading: 80.4 lb/sq ft (393 kg/m2) Thrust/weight: 0.72 lbf/lb (0.007 kN/kg) Armament Bombs: 1× Mark 27 nuclear bomb, B28 or B43 freefall nuclear bomb in internal weapons bay 2× B43, Mark 83, or Mark 84 bombs on two external hardpoints Avionics Systems carried by A-5 or RA-5C AN/ASB-12 Bombing & Navigation Radar (A-5, RA-5C) Westinghouse AN/APD-7 SLAR (RA-5C) Sanders AN/ALQ-100 E/F/G/H-Band Radar Jammer (RA-5C) Sanders AN/ALQ-41 X-Band Radar Jammer (A-5, RA-5C) AIL AN/ALQ-61 Radio/Radar/IR ECM Receiver (RA-5C) Litton ALR-45 "COMPASS TIE" 2-18 GHz Radar Warning Receiver (RA-5C) Magnavox AN/APR-27 SAM Radar Warning Receiver (RA-5C) Itek AN/APR-25 S/X/C-Band Radar Detection and Homing Set (RA-5C) Motorola AN/APR-18 Electronic Reconnaissance System (A-5, RA-5C) AN/AAS-21 IR Reconnaissance Camera (RA-5C) * |
| Thread Tools | |
| Display Modes | |
| North American A-5 Vigilante pics [08/19] - dn-poss-don-post-flightline-usn-north-american-a5-vigilante-02-battle-damage-landing-1965-1966.jpg (1/1) | Miloch | Aviation Photos | 1 | July 15th 16 12:15 AM |
| North American A-5 Vigilante pics [18/19] - VIGILANTE-14-960x361.png (1/1) | Bob (not my real pseudonym)[_2_] | Aviation Photos | 0 | July 14th 16 10:13 AM |
| North American A-5 Vigilante pics [13/19] - North-American-A-5-Vigilante.jpg (1/1) | Miloch | Aviation Photos | 0 | July 14th 16 02:09 AM |
| North American A-5 Vigilante pics [05/19] - A-5A Vigilante (A3J-1) 2.jpg (1/1) | Miloch | Aviation Photos | 0 | July 14th 16 02:09 AM |
| North American A-5 Vigilante | Miloch | Aviation Photos | 0 | July 14th 16 02:04 AM |
