We want to hang up our ASK13 in our hanger.
Our ASK13 has a nose wheel and glass fuselage modification, that is why a rope or a band/strap hang is not possible. We know there are 2 holes on the outside of the fuselage around the mid section of the cockpit. Maybe this can be an option for hanging? Does anyone have any suggestions or experiences with this particular case? Let me know. Lars |
On Sunday, March 10, 2019 at 7:43:47 AM UTC-6, wrote:
We want to hang up our ASK13 in our hanger. We know there are 2 holes on the outside of the fuselage around the mid section of the cockpit. Those two L & R holes are metric threaded and serve two purposes. Threaded tie down rings for securing outside. Attached points for the trailer dolly under the fuselage. (Keep the threads clean or fly with the rings inserted fully. Make sure they do not back out of the fuselage.) Used as tie down rings, they are original equipment and very substantial. Whether you want to suspend the ASK-13 from these rings is up to you. The other hang points might be the left and right handles on the fuselage. I am NOT saying that these points are designed to sustain the weight without damage to the fuselage structure. If you hang a glider ropes at the wingtips will be needed to keep one wing from dipping vertically and swinging horizontally when (not if) wind gets into the hangar. In my experience, the disadvantage to hanging a glider is that the effort to lower and raise it discourages frequent flying! |
| Thread Tools | |
| Display Modes | |
| Blanik L13 VS ASK13 handling and aerodynamics ? | Matthieu | Soaring | 1 | August 2nd 10 01:59 AM |
| Avgas Where is the ceiling? | Doug Palmer | Owning | 217 | May 8th 06 09:55 PM |
| To hang up a glider to hangar's ceiling | Paolo Ceccarelli | Soaring | 1 | March 7th 05 08:00 AM |
| service ceiling of F-22 | zxcv | Military Aviation | 7 | March 14th 04 11:31 PM |
| Class C Ceiling | Mzsoar | Soaring | 1 | August 18th 03 09:50 PM |
