Replacing a multi-probe socket
Old March 13th 19, 03:00 AM posted to rec.aviation.soaring
Default Replacing a multi-probe socket
Yup,
Great stuff. Probably one of the most important things that I learned about in college.
Also works great on water ballast valves. Has not melted on the ground at AirSailing or frozen in wave at 24,800 ft.
P9
Old March 13th 19, 02:59 PM posted to rec.aviation.soaring
Dan Marotta
Oh, Jeez...
So now skin oil is suspect?Â* I learned about that little trick for
assembling and (especially) disassembling my fishing rod when I lived in
Alaska... :-D
On 3/12/2019 3:13 PM, Tango Eight wrote:
On Monday, March 11, 2019 at 9:52:53 PM UTC-4, Roy B. wrote:
Dan:
For some reason the O-Rings on my South African glider get really dry & stiff. We use a very light coat of silicone "plumbers grease" on the probe about twice a year to fix that (petroleum based grease attacks the O-Ring). My US glider in Massachusetts doesn't have the problem.
ROY
If everyone used this, we'd have fewer problems: https://www.amazon.com/Dow-Corning-V.../dp/B001UHMNW0
What I use on the o-rings I rely on in my day job, as well as my triple probe socket.
T8
Dan, 5J
Old March 13th 19, 05:55 PM posted to rec.aviation.soaring
JS[_5_]
A previous thread suggested using ACF-50. I've used that since. $1.65 from Aircraft Spruce. It is quite a thin liquid and unlikely to clog the tiny orifices in a multi-probe. The Dow-Corning or Super-Lube stuff can clog things.
But none fix a socket that leaks.
This seems like the thing to do: Rent a tool from Wings and Wheels for $25 plus $3.00 for the 3 O-Rings.
https://wingsandwheels.com/aircraft-...ntal-tool.html
Proper Way to Insert Multi-Probe Dan Marotta Soaring 18 February 19th 18 01:31 AM
Prandtl multi probe receptacle used for TE only? Matt Herron Jr. Soaring 12 February 15th 18 08:32 PM
castellated socket Stuart & Kathryn Fields Home Built 1 June 3rd 08 12:37 PM
Replacing innertubes without replacing tires? Ben Jackson Owning 28 November 6th 06 04:54 PM
Multi - probe KP Soaring 1 March 7th 05 06:03 PM
