Question: Researching Project
Old December 11th 03, 06:59 PM
Tilt
Default Question: Researching Project
Hi,
I'm looking to get into a homebuilt project within a few years from now.
I've been doing some early research to see what's out there and look at
options.
I haven't come close to picking a final subject as my project yet, but I
have some pretty good ideas of what I want. So far the aircraft that
interests me the most is a Jabiru J450. I'm sort of looking for a high-wing
4 place type plane. I want something with a bit of performance (able to
reach around 150 knots or higher), and some VERY light aerobatics. Now I
already understand that the Jabiru doesn't quite go fast enough for my
needs, but it gives you an idea of what I'm looking for.
As far as money goes, I don't want to break the bank, but I don't want to
cheap it out. I may have others go in on this project with me. I know I
don't really want to spend much more than around $75,000 (Canadian). It's
hard to think of cost figures this early.
So can anyone point me in the direction of some good quality (proven)
aircraft projects that I can research further? As long as they (somewhat)
follow the above criteria.
Thanks,
Lyle
(Alberta, Canada)
Old December 11th 03, 08:47 PM
Bryan
Hi Lyle,
" I'm sort of looking for a high-wing 4 place type plane. I want something
with a bit of performance (able to reach around 150 knots or higher), and
some VERY light aerobatics."
A very good match for your criteria is the BD-4 designed by Jim Bede back in
the 60's. While not a true 4 place by original design, a proven
modification to extend the fuselage does make it a true 4 place. The BD-4
meets and exceeds the performance you are looking for. Mind you, it is not
a beautiful plane with sleek rounded lines, rather it has a boxy fuselage.
This plane can give about the best bang for the buck and has a proven record
with hundreds built and flying.
Check it out at http://bd-4.org/
Bryan
"Tilt" wrote in message
news:Of2Cb.663673$pl3.69462@pd7tw3no...
Hi,
options.
high-wing
Old December 12th 03, 03:20 AM
James R. Freeman
Bearhawk best bang per buck
Hi,
options.
high-wing
Thanks,
Lyle
(Alberta, Canada)
Old December 12th 03, 03:47 AM
Tilt
Well, you're right about the beauty factor!!
The four seater even looks...um...less...beautiful!!
Couldn't really find anywhere on the site that talks about costs. And I
think I'd rather build from a specific kit. However, I will keep it on the
list (for research sake). It does fit the other requirements I was looking
for.
Thanks,
Lyle
"Bryan" wrote in message
Hi Lyle,
something
in
not
record
Bryan
Hi,
options.
high-wing
Old December 12th 03, 03:51 AM
Tilt
Thanks for the info James,
I forgot to mention one thing. I'm not really keen on a tail dragger. The
bearhawk also looks a bit compact. I'm a bigger tall sort of guy and like my
elbow room. I was hoping for some more room in the back for a 4 place craft.
Lyle
"James R. Freeman" wrote in message
Hi,
options.
high-wing
to
It's
(somewhat)
Thanks,
Lyle
(Alberta, Canada)
Old December 12th 03, 04:53 AM
RobertR237
In article y2aCb.665242$6C4.242523@pd7tw1no, "Tilt"
writes:
Lyle
Then forget the BD-4 unless you have a good shoehorn.
Bob Reed
www.kisbuild.r-a-reed-assoc.com (KIS Builders Site)
KIS Cruiser in progress...Slow but steady progress....
"Ladies and Gentlemen, take my advice,
pull down your pants and Slide on the Ice!"
(M.A.S.H. Sidney Freedman)
Old December 12th 03, 08:11 AM
Holger Stephan
for.
Currently there is no kit supplier for the BD-4. TVAP who used to sell the
kits are winding down their business and supporting only existing
customers. Their quickbuilt kits went for US$25,000. TVAP did never really
probe the market and stepped back for internal reasons. That the owners
keep a money losing business alive only to support the existing builders I
find rather remarkable.
While they are phasing out a new supplier is phasing in. At first parts like
the wing spars are going to be offered (starting February '04). Gradually
complete kits will be made available again. There is also another startup
targeting a BD-4 like kit. I can't tell more about the latter but take it
as sign for enough activities around the BD-4 to keep it very alive even
after a 35 year history. No wonder, as there is still no alternative for an
easy to build, inexpensive metal semi-4-seat high wing that gives you about
a MHP for each HP up front.
- Holger (don't every design need its lobbyist?)
webmaster [at] bd-4 [dot] org.
Old December 12th 03, 03:07 PM
AlwaysLearning
Lyle
I don't think you're going to find a larger project than the Bearhawk.
It is relatively HUGE, especially in back, compared to just about
everything else.
As far as not liking a taildragger, any reason why you couldn't put
nosegear on it? Find a nosegear off a Cessna 182 and figure a way to
get it to fit, or maybe the nosegear off a Tri-Pacer, though engine
interference will be "interesting", unless you go with an O-320.
Drew
Old December 12th 03, 05:31 PM
Del Rawlins
On 12 Dec 2003 05:07 AM, AlwaysLearning posted the following:
The bearhawk also looks a bit compact. I'm a bigger tall sort of guy
and like my elbow room. I was hoping for some more room in the back
for a 4 place craft. Lyle
everything else.
People who have flown them say that as far as taildraggers go, the
Bearhawk's handling is pretty tame. As far as the cargo space goes, try
to find somebody who is building one that will let you look at their
project. The pictures just don't do it justice. Reserve your opinion
until you see the actual fuselage. I'd had my plans for 3-4 years and
it was still a real awakening when I got to see a fellow builder's
fuselage for the first time.
Del Rawlins-
Remove _kills_spammers_ to reply via email.
Unofficial Bearhawk FAQ website:
http://www.rawlinsbrothers.org/bhfaq/
Old December 12th 03, 07:08 PM
Tilt
I'm going to add a bit of info to add to the equation...
I really would prefer a composite style 'kit' along the lines of the Jabiru.
I like the trike style setup for landing gear, I've never been a fan of
tail-draggers.
I understand that most home-builts (or at least the one's I'm looking at)
are not very big. I'm 6 feet tall and weigh around 225 lbs. I like the 4
seater idea because I can see myself taking my family or friends on trips
(not sure how far I'd go...too early in my thinking). I'd like the ability
to take passengers that are around 200 lbs each. Not that it'll be that way
everytime, but I'd like to have that ability. Realistically the passenger
weight loads would probably vary a lot. So I do understand that space will
be limited, but I just don't want to be stuffed in like a sardine!!
I was checking out the New Glastar 4 seater last night (on their website),
and I was thinking it may be the one. However, I came across the height
limit for backseaters. 5 feet tall!!!! How usefull is that??!!!
Anyways, this is what I'm looking at. Maybe I'm putting too much emphysis on
the 4 seater thing. One could say that you'd probably mostly only ever fly
with one other person. And for the occational longer trips with the family
you could rent a Cessna or something. But then again, that defeats the whole
purpose of building my own aircraft.
Oh, and one other thing...I hate to say it but, easthetics does play a
little role in my choice. For my eyes, I can't see myself owning a BD-4 or a
Bearhawk. I understand everyone has a different eye for beauty. I'm partial
to something a bit more newer looking and sleek.
Cheers,
Lyle
Hi,
options.
high-wing
Thanks,
Lyle
(Alberta, Canada)
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 02:51 AM
Corky: Any new pics of your project? Ernesto Sanchez Home Built 1 October 15th 03 02:44 PM
Wanted Rans S7 project Peter C Home Built 0 September 21st 03 04:29 AM
Refinace a project John Mireley Home Built 0 September 18th 03 04:08 PM
Question - Regarding Canard Pushers... Tilt Home Built 33 August 10th 03 12:07 PM
