Borgelt Dynamis variometer
Old March 18th 19, 07:01 PM posted to rec.aviation.soaring
Default Borgelt Dynamis variometer
As Mike mentioned, horizontal gusts are usually most disturbing while cruising at higher speeds and entering thermals. The AirGlide S and the ClearNav-Vario are both using ADC derived data to calculate vertical air mass movement. From my experience, it takes some time to find the right setup for these filters. But once that is done, they do a good job in removing horizontal gusts. But they are only working in cruise mode. Perhaps Dynamis uses them in climb mode as well - although the problem of horizontal gusts is most relevant while cruising at high speeds, i.e. in cruise mode.
Mike has every reason to be proud of his new product and it certainly was a great effort to get there. But it is not the first and only vario on the market using such filters.
Cheers
Christoph
Old March 18th 19, 07:42 PM posted to rec.aviation.soaring
Cheers
Christoph
The only thing I am aware of that MB has said about how the Dynamis works is that it is not by means of filters, specifically, from his Dynamis article:
"It is not a filtering problem as the vertical and horizontal motion occurs on the same time scales and has similar magnitude, making filters useless.."
Old March 19th 19, 06:15 AM posted to rec.aviation.soaring
2G
Cheers
Christoph
"It is not a filtering problem as the vertical and horizontal motion occurs on the same time scales and has similar magnitude, making filters useless."
Don't expect Mike to give you any REAL clues on how his systems works; after all, it is his trade secret. In fact, he may give you false clues to throw you off! One thing I would like to know, however, is the price of the system (that shouldn't be a trade secret).
Tom
Old March 20th 19, 09:10 PM posted to rec.aviation.soaring
Nick[_5_]
What is ADC derived data?
Cheers
Christoph
Old March 20th 19, 10:42 PM posted to rec.aviation.soaring
Dan Marotta
Data derived from the Air Data Computer, part of the vario system which
has accelerometers, gps, pitot, static, total energy, and probably other
stuff.
Cheers
Christoph
Dan, 5J
Old March 21st 19, 08:58 PM posted to rec.aviation.soaring
Nick[_5_]
Thanks.
There are standard algorithms such as Kalman filters.
https://en.wikipedia.org/wiki/Sensor_fusion
For example you could dead reckon from ASI, accelerators and gyros. It would drift over time, because its an integration. Combine that however with GPS, altimeter, etc, and you can end up with a system that has lower errors.
Gusts in one way, are just noise, and approaches like Kalman filters work well at eliminating noise. So if you fly into a horizontal gust, you get a change in ASI, but no appreciable longitudinal acceleration.
Old March 21st 19, 10:35 PM posted to rec.aviation.soaring
On Thursday, March 21, 2019 at 8:58:32 PM UTC, Nick wrote:
Thanks.
For example you could dead reckon from ASI, accelerators and gyros. It would drift over time, because its an integration. Combine that however with GPS, altimeter, etc, and you can end up with a system that has lower errors..
Nick, that approach sounds plausible and is very different from the simple pneumatic or internal electronic signal damping "gust filters" we use now. I can only imagine that the sensor fusion hardware you give a link to would need to be a bit more sophisticated than the MEMS chips in current vario/nav systems.
Old March 21st 19, 11:02 PM posted to rec.aviation.soaring
Nick[_5_]
On the mems devices if you have played with them, are pretty standard.
Compasses have errors. The 3 axes are not always at 90 degrees. The center is not necessarily at 50%, and each axis may be scaled differently. It's quite straight forward to turn this ellipsoid into a unit sphere. That's just the calibration.
Same applies for accelerators. You can rotate and hold still to get the calibration.
Gyros are odd. They suffer the same but they drift over time, so you need to adjust for the drift. But over a short period they are good.
GPS is accurate certainly over long periods.
From what I know, TE and ASI, along with altimeters are noisy measuring devices. Noise changes pressure, and hence you get a random change in altimeter. Not sure how they are affected by temperature.
So what do you want to measure?
1. The orientation of the glider - bank, pitch and direction
2. It's velocity
3. It's acceleration
4. The vector of the air. Wind speed + vertical
5. Conceivably, slip.
6. Flaps
7. Conceivably even the control movements.
That should give you a good model, and you should be able to fit from that.
It is what the AHRS systems use anyway, for a subset. See the Madwick system
http://x-io.co.uk/open-source-imu-and-ahrs-algorithms/
Old March 24th 19, 11:27 PM posted to rec.aviation.soaring
Cheers
Christoph
Tom
Why not explain how and why it works?
This makes me a bit sceptical. Is there a patent application pending?
Looking at the videos, I can't see any difference that can't be explained by a longer integration time.
Old March 25th 19, 12:08 AM posted to rec.aviation.soaring
Charlie Quebec
Yeh why not give away the fruits of many years of research, so others can copy it, sounds like a great idea to promote your business.
Borgelt Dynamis [email protected] Soaring 0 December 30th 18 04:30 PM
Borgelt B700 variometer: Anyone with experience with this vario? [email protected] Soaring 9 September 29th 17 08:56 PM
Borgelt B50 Variometer Update No Name Soaring 1 April 24th 08 03:57 AM
f/s Borgelt B-100 John Sinclair Soaring 3 February 18th 07 03:37 AM
WTB: Borgelt B40 James Soaring 0 June 19th 04 12:02 AM
