Implausible Time Records
Old May 5th 19, 05:38 PM posted to rec.aviation.soaring
Dan Marotta
Default Implausible Time Records
For my last three flights I've been getting a message from OLC warning
of implausible time records in the igc file.ツ* Does anyone know what this
means and what I might do to correct the problem? I've asked the
question on the ClearNav forum but haven't gotten a reply yet.
Here's a link to the file if that helps:
https://www.dropbox.com/s/erm01jilim...8Q-01.IGC?dl=0
Dan, 5J
Old May 5th 19, 05:49 PM posted to rec.aviation.soaring
JS[_5_]
Dan, 5J
Noticed it was from the vario. I'll use a vario file today and see...
Old May 5th 19, 06:26 PM posted to rec.aviation.soaring
Dan Marotta
Yes, it was from the vario which just started acting up.ツ* The ClearNav
II display's USB stick did not have the flight.ツ* I may have neglected to
download that.
Lately I've been getting a boatload of GPS drop outs.ツ* Maybe that's
because I'm close to the source of the interference testing or maybe
it's because I've cut my antennae cables to length in my cockpit.ツ* I now
seem to recall reading that one should not shorten the cables. I know
about reflections due to wavelength/transmission line length, but I was
unaware that that would affect reception.ツ* Do I need to acquire new
antennae?ツ* The antenna that came with my PF portable was 10 meters
long!ツ* Who needs a big bundle of cable under the panel?
Dan, 5J
Dan, 5J
Old May 5th 19, 06:43 PM posted to rec.aviation.soaring
Tim Newport-Peace[_6_]
download that.
this
Dan, 5J
Dan, 5J
Looking at the file, there is an out-of-sequence issue:
Checking File C:\Users\Public\Documents\GPS\2019-05-04-CNI-V8Q-01.IGC
Out of Sequence Error -
B1903383458935N10559992WA0184701874001999104104113 000
B1903393458935N10600013WA0184901876001999112112116 000
B1903373458935N10600035WA0185101877001999115115119 000
B1903383458936N10600057WA0185301878001999119119122 000
Could this be the issue?
Old May 5th 19, 07:06 PM posted to rec.aviation.soaring
Dan Marotta
I don't see what you're seeing.ツ* But how could records be out of
sequence?ツ* Maybe because my position apparently reversed while
thermalling during a GPS outage and getting one or two hits and then
another drop out, etc.?
Yes, it was from the vario which just started acting up.テつ* The ClearNav
II display's USB stick did not have the flight.テつ* I may have neglected to
download that.
Lately I've been getting a boatload of GPS drop outs.テつ* Maybe that's
it's because I've cut my antennae cables to length in my cockpit.テつ* I now
unaware that that would affect reception.テつ* Do I need to acquire new
antennae?テつ* The antenna that came with my PF portable was 10 meters
long!テつ* Who needs a big bundle of cable under the panel?
of implausible time records in the igc file.テつ* Does anyone know what
this
Dan, 5J
Dan, 5J
Dan, 5J
Old May 5th 19, 09:05 PM posted to rec.aviation.soaring
Dan,
Open your file with a text editor and search for "B190338"
This will put you in the right area.
In each record, after the letter B, the next six bytes are the time.
After B190339 the time jumps back to B190337, which is odd, and leads to
there being two records with a time of 190338, and also 190339.
Odd, but I have seen this before. Maybe you can avoid it in future by
setting a longer fix interval, even 2 seconds might help, but no promises.
I am not seeing any GPS outage around that time. This would be shown by the
Letter "A" in the 25th byte changing to a "V".
Although it does not help a lot, the sequence error seems to happen as you
left the ground, so I guess you were not reversing turns?
I'm not saying this is what OLC are complaining about, just that it is odd
and it might be.
Tim.
ClearNav
neglected
to
download that.
I
now
was
warning
what
this
Dan, 5J
Dan, 5J
Dan, 5J
Old May 6th 19, 12:43 AM posted to rec.aviation.soaring
Dan Marotta
Thanks Tim
I'll increase my time interval to 2 seconds and see if that helps.
Strange that the igc file does not show GPS drop outs since my ClearNav
screen went white with the caption (something like) No GPS.ツ* Zero
satellites.ツ* And the ClearNav vario said, "Warning no GPS".ツ* The
PowerFlarm portable screen also went blank with a "Zero satellites" message.
On 5/5/2019 1:05 PM, Tim Newport-Peace wrote:
Dan,
and it might be.
Tim.
Dan, 5J
Old May 6th 19, 03:42 AM posted to rec.aviation.soaring
JS[_5_]
On Sunday, May 5, 2019 at 3:43:24 PM UTC-7, Dan Marotta wrote:
Thanks Tim
Dan,
and it might be.
Tim.
Dan, 5J
That smells of GPS jamming.
Check this page.
https://www.navcen.uscg.gov/pdf/gps/...terference.pdf
I did not have a problem with the vario file today. My antenna has a shortened cable to a MECA divider, then a short SMA-SMA link cable.
Old May 6th 19, 05:08 PM posted to rec.aviation.soaring
Dan Marotta
Yes, the GPS jamming usually centers around Alamogordo and ranges out to
about 400 nm.ツ* Moriarty is well within that area.ツ* I've asked other
local pilots and they don't report so many drop outs.
Maybe there are just too many GPS antennae in my ship.ツ* I'll take a look
at a divider for everything except the ADS-B WAAS GPS.ツ* Its antenna is
mounted aft of the engine in the Stemme.ツ* The rest are on or under the
glare shield.
Thanks Tim
Dan,
and it might be.
Tim.
Dan, 5J
Check this page.
Dan, 5J
Old May 6th 19, 05:44 PM posted to rec.aviation.soaring
kinsell
Jamming is directed skyward, they're not taking out car gps's in a 400
nm radius. If you're getting bad time stamps just at liftoff, it's not
likely caused by jamming.
I'm suspicious of your cut-down gps cables, those are tiny wires to be
working on.
glare shield.
Thanks Tim
message.
Dan,
After B190339 the time jumps back toツ* B190337, which is odd, and
leads to
promises.
by the
as you
is odd
and it might be.
Tim.
Dan, 5J
Check this page.
All US Records are Now Motor Glider Records Tango Eight Soaring 99 March 23rd 17 01:07 PM
OT 4 airport round robin - time lapsed / real time with ATC COMS -video A Lieberma[_2_] Owning 0 August 30th 09 01:26 AM
OT 4 airport round robin - time lapsed / real time with ATC COMS -video [email protected] Instrument Flight Rules 0 August 30th 09 01:26 AM
4 airport round robin - time lapsed / real time with ATC COMS - video [email protected] Piloting 0 August 30th 09 01:25 AM
they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap tim liverance Military Aviation 0 August 18th 03 01:18 AM
Copyright ゥ2004-2025 AviationBanter.
