Escaping glider on the ground with stuck canopy?
Old May 11th 19, 02:01 AM posted to rec.aviation.soaring
Default Escaping glider on the ground with stuck canopy?
https://www.amazon.com/Lifehammer-Or...00HVO0LVG?th=1
A 12ga works well too. :-)
On Friday, May 10, 2019 at 4:30:27 PM UTC-4, Steve Koerner wrote:
I'm hypothesising about a certain risk scenario that could happen: landing somewhere or crashing somewhere and canopy won't open. If it's hot especially, one might not last long enough for help to arrive if summoned by phone or radio.
My question is how to get through a canopy that's stuck or has a broken latch mechanism. Maybe someone has had relevant experience with this issue?
An obvious possibility might be to grab the window and try to tear the plexiglass apart (after donning kevlar gloves perhaps). I don't have a good intuition as to whether that is possible or not. Has anyone ever done that or does anyone maybe have access to a junk canopy to try it on? Another possibility is to carry a small saw or some other tool. Are there any specific tools that you know will work effectively on canopy plexiglass yet are compact enough to stash in a tight cockpit (there's no room to carry a hammer)?
Old May 11th 19, 01:45 PM posted to rec.aviation.soaring
I would suggest remembering that almost all canopy systems have 2 retention sections. One supports and pivots, the other retains closed.
Releasing both may well provide a degree of freedom to get the canopy off beyond just releasing the side or rear latches.
Rule of thumb- canopies only break when you don't want the too.
FWIW
UH
Old May 11th 19, 04:08 PM posted to rec.aviation.soaring
Dan Marotta
Yeah, and I'll bet that tool was a LOT cheaper than the military canopy
breaker, too!Â* And don't forget, the glider could be upside down and
attempting to pry the canopy open wouldn't help.
On 5/10/2019 5:58 PM, Steve Koerner wrote:
I should have done a better job of Googling. I just found a youtube of a pretty small escape hammer (as Dan suggests) that does a fine job on an RV7 canopy:
https://youtu.be/fRvQxGl4kt4
Dan, 5J
Old May 11th 19, 04:28 PM posted to rec.aviation.soaring
Nick Kennedy[_3_]
Dan
Over the years I flew with Glider Bob in his Stemme I asked him if we landed out if we would land gear up or gear down. Gear down in a Stemme landing off field I was always concerned about flipping forward on the nose and going over upside down.
That would suck, bad.
I witnessed Don Bell landing at Parowan years ago in a Stemme and he went off into the dirt and ended up on the nose, I often wondered what it would take for the nose to dig in and flip over on its back.
Old May 11th 19, 05:53 PM posted to rec.aviation.soaring
Dan Marotta
Nick,
The Stemme's gear is pretty stable and the weight on the tail is high
(at least on mine), something like 135 lb IIRC.Â* While I know the Stemme
can be put on its nose, it seems to me unlikely it could flip on its
back.Â* I'm still happy to have that heavy steel tool to break the
canopy.Â* It's designed to break the thick plexiglass in a fighter.
On 5/11/2019 9:28 AM, Nick Kennedy wrote:
Dan
Dan, 5J
Old May 11th 19, 06:37 PM posted to rec.aviation.soaring
The tool is cheap, the required documentation is humongous. Part of the "$200 hammer" or a "$300 toilet seat".
I know some of this from UL vs. non-UL registered/approved wire. The product is basically the same.....the testing, documentation and data retention/traceability is where the price goes up.
Old May 12th 19, 04:06 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Steve Koerner wrote on 5/10/2019 1:30 PM:
Is there anyone that has been trapped in a glider, and a canopy breaking tool
would have allowed escape? I can't remember any. The only glider I can recall
flipping over on landing was an H301. The field was a soft plowed one, the pilot
mishandled the tail parachute, causing it to land in a nose-down attitude.
- "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm
http://soaringsafety.org/prevention/...anes-2014A.pdf
Old May 12th 19, 04:23 PM posted to rec.aviation.soaring
mishandled the tail parachute, causing it to land in a nose-down attitude..
I recall at least one case of a glider being stopped by a fence and canopy being held closed by the fence(wire fence).
If the glider is inverted the latching mechanism likely is not the biggest problem.
UH
Old May 12th 19, 11:49 PM posted to rec.aviation.soaring
An Arcus M flipped over the nose a few years ago, engine out but not running. Went into a plowed field perpendicular to the undulations of the ground; the nose stuck in the soft terrain.
Much more frequent is the flip over due to hitting an obstacle with a wingtip. The subsequent and violent yaw will make the opposite wing produce lots more lift, and the glider may complete an half roll. It happened at least four times in my country during the last 15 years. Luckily nobody was hurt except bruises or a broken nose.
In all these cases, the pilots needed quick external help to abandon the cockpit.
Aldo Cernezzi
www.voloavela.it
Old May 13th 19, 01:52 AM posted to rec.aviation.soaring
AS
How about this poor guy? He was trapped in the cockpit for a long time before they used a SawZall to get him out. The replacement cost for that canopy was estimated to be in excess of $182,000.
http://www.f-16.net/f-22-news-article1768.html
Uli
'AS'
Anyone Ground-Launched a Russia Glider? [email protected] Soaring 15 September 2nd 17 12:06 AM
Where to get a glider canopy in the US Bob Kuykendall Soaring 0 September 4th 08 01:16 AM
Stuck Canopy David Hartung Aviation Photos 2 June 21st 07 05:08 AM
Glider Ground School - Eastern PA RL Soaring 0 December 29th 06 02:19 AM
Glider ground school syllabus [email protected] Soaring 8 November 17th 06 01:50 PM
