ASH25 out to kill you?
Old May 25th 19, 01:51 PM posted to rec.aviation.soaring
ripacheco1967
Default ASH25 out to kill you?
I know I’m just learning about all this but reading this about the ASH 25 really made me pause.
(I have a lot of ours on GA aircraft and moving into gliders.)
http://gliding.co.nz/wp-content/uplo...n%20Nelson.pdf
«...The consequence of moving the stick forward with force or aggressively in an Open Class glider is that you may achieve a nose down attitude from which there is no recovery...»
Even a piper meridian wouldn’t be that mean to a pilot.
Is this common place in the glider world?
Old May 25th 19, 02:22 PM posted to rec.aviation.soaring
hretting@aol.com[_2_]
I disagree, all aircrafts in the GA world have stress limitations. Excluding aerobatic types and perhaps a few others, where pilot physical limitations might be achieved first. Respect the designers limitations and live.
I seriously doubt when you fly your turboprop within 20% of its Vne you push full forward on the controls. If you do, you’ll either run out of altitude or wings.
I recommend a refresher read Wolfgang book of aeronautics. The answers you seek are all there.
R
Old May 25th 19, 03:03 PM posted to rec.aviation.soaring
Charlie Quebec
Ive had about 30 hours in a 25. It’s certainly a ponderous beast, and it lets you know very clearly that it must be flown with a great deal of caution and respect. It successor, the 30 is nicer to fly
but needs similar respect. Ive never felt that either was trying to kill me, only that if mishandled, they could.
Old May 25th 19, 03:34 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Yes, they are incredibly dangerous. Please give me your ASH-25 so that you can live a long life. :-)
Steve Leonard
Old May 25th 19, 03:44 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
http://gliding.co.nz/wp-content/uploads/2016/09/
Flying%20ASH25%20by%20Stan%20Nelson.pdf
Thanks for posting that. I only fly a (15m) Standard Libelle, but learned
stuff from the careful explanations in this piece. I've saved a copy for
future reference.
I think its a logical extension of experience flying powered aircraft,
simply because all composite gliders have much less drag, much longer
spans and higher aspect ratios. As a result, they may accelerate faster
in a dive, exhibit much stronger adverse yaw effects, and may flutter
more easily than a typical powered plane that operated in a similar speed
range.
But what do I know? I've only flown two powered plane, my club's Scheibe
SF-25 TMG and a DH Tiger Moth, since I've been a glider pilot. I found
both very easy to fly, especially the Tiger.
Martin | martin at
Gregorie | gregorie dot org
Old May 25th 19, 05:24 PM posted to rec.aviation.soaring
ripacheco1967
Clearly the article talks about unusual attitude recoveries. Not normal flying.
Totally learning a lot from this article. Learning to fly a glider makes you a way better pilot than just flying Cessnas and pipers around.
Keeping that article in my library. Lots very good information there.
Old May 25th 19, 05:35 PM posted to rec.aviation.soaring
ripacheco1967
Oh I wish that 25 was mine. Was considering but not as a first glider by any means
Leaning towards a 27
Steve Leonard
Old May 25th 19, 07:23 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Steve Leonard
I have maybe 500 hours in open ships, there is just nothing like them. They might be slower in the run on a great day than a 15 meter bird, but when you cross mountain ranges they can reach much further or arrive in the lift band. They will stay in the air when nothing else will and perhaps a bit more care is required when flying but the legs and the ability to dolphin fly for miles and miles..... I miss my N4.
Old May 25th 19, 07:29 PM posted to rec.aviation.soaring
Disagree again......the point raise has nothing to do with recoveries but was written for Lawyers that all attempt is being made to educate dumb pilots not to perform ABRUPT maneuvers or flight control movement in the high speed regime. I say dumb because any airmen worth his salt knows this.
Case in point American Airlines co-pilot full rudder deflection leads to vertical stab failure killing all on board and most recently the loss of an Amazon 767 due to
excessive elevator deflection.
Vo....Maximum Operating Maneuvering Speed...the speed at which if exceeded structural failure could occur with abrupt control movement.
Vne...Never Exceed
This is basic airmen knowledge as important as blue side up and what does the rudder do. Basic
Long wing (open class) sailplanes have additional considerations, but lets hold off on that for now.
A 27 ... enjoy....read the AOM.
R
Old May 25th 19, 10:38 PM posted to rec.aviation.soaring
ripacheco1967
Vne...Never Exceed
R
I like the fact is a two seater, So I can have a qualified instructor saving my behind ;-)
Dynamic Soaring Animation IEEE - ASH25 w/ Albatross Pilot JohnDeRosa Soaring 17 November 14th 13 03:59 PM
"Airplanes don't kill people!, people kill people!" Laonork Owning 8 May 21st 12 05:56 AM
Questions to ASH26E or ASH25 MI owners Ludovic Launer[_2_] Soaring 3 July 18th 08 08:20 PM
"Airplanes don't kill people!, people kill people!" Flyingmonk Piloting 11 May 17th 05 10:26 AM
ASW22 ASH25 or Nimbus 4 sharply needed for rent to Poland on EGC Pociunai Lenti Soaring 0 March 20th 04 08:59 AM
