hi
	i have read ad9830 dds ic datasheet, but i have steel problem how i should program it, for example i want to use pararel port for interfacing , and for example want 3.1MHZ on out put, how i should use D0 to D15 and A0,A1,A2? should i use both freq reg ( 0,1) and all 4 phase reg ? or one is enouth? any help would be most appreciated thanks payam  |
Classic.
			 As you strike out on this project, I think you might find it instructive to review Robert X. Cringley's excellent documentary "Plane Crazy." This should, I think, be required viewing for anyone about to undertake a project such as yours. And no, in case you're curious, I don't get royalties on additional copies sold. But when you go buy yours, tell him I sent you. Ben "doe snot" Sego +++++++++++++++++++++++++++++++++++++++++++ Last I knew... Robert Cringley was a self promoting huckster and flake. Zoom would probably give him three thumbs up... if Robert was a paying advertiser in AeroSnooze. Barnyard BOb - doe snot?  |
			 "Ben Sego" wrote in message ... As you strike out on this project, I think you might find it instructive to review Robert X. Cringley's excellent documentary "Plane Crazy." This should, I think, be required viewing for anyone about to undertake a project such as yours What? As an example of what not to do? Cringley is an idiot and that show gives legitimate homebuilding a black eye. Not only does he woefully fail, he comes very close to killing himself in the last episode.  |
This post is off topic but I'll answer it anyway.
	Since you only get 8-12 outputs on that port, you aren't going to be able to drive your DDS without some interface logic. Consider using a shift register, either bit, or nibble wide, to prepare your inputs before strobing the data into chip. You can ignore the phase registers, I've never had a use for them. You need both freq registers to set the phase progression with the full resolution of the part. Keep in mind you're also probably going to need an anti-alias filter on the output to get rid of all those harmonics depending on your application of course. Mini-Circuits has some canned solutions that will save you a lot of time as far as the filter is concered. Please post your electronics related questions to an electronics group. Regards wrote in message . com... hi i have read ad9830 dds ic datasheet, but i have steel problem how i should program it, for example i want to use pararel port for interfacing , and for example want 3.1MHZ on out put, how i should use D0 to D15 and A0,A1,A2? should i use both freq reg ( 0,1) and all 4 phase reg ? or one is enouth? any help would be most appreciated thanks payam  |
Ron Natalie wrote:
	"Ben Sego" wrote in message ... As you strike out on this project, I think you might find it instructive to review Robert X. Cringley's excellent documentary "Plane Crazy." This should, I think, be required viewing for anyone about to undertake a project such as yours What? As an example of what not to do? Uh, well, yeah. This is definitely one of the best videos I have ever watched about hubris and project mismanagement. Cringley is an idiot and that show gives legitimate homebuilding a black eye. You left off "pompous" and "arrogant" and "doesn't play well with others." Not only does he woefully fail, he comes very close to killing himself in the last episode. And he makes fun of some hardworking people who help him along the way. And he belittles his long suffering girlfriend. But that wasn't my point. Ben "watching with wonder" Sego  |
RR Urban wrote:
	As you strike out on this project, I think you might find it instructive to review Robert X. Cringley's excellent documentary "Plane Crazy." This should, I think, be required viewing for anyone about to undertake a project such as yours. And no, in case you're curious, I don't get royalties on additional copies sold. But when you go buy yours, tell him I sent you. Ben "doe snot" Sego +++++++++++++++++++++++++++++++++++++++++++ Last I knew... Robert Cringley was a self promoting huckster and flake. Actually, I rather like his "I, Cringley" column. That he was a flake in his plane building adventure, is, I think, without dispute. Can't argue with "self promoting" either; you're dead on there. I don't, though, think he's a huckster. Zoom would probably give him three thumbs up... if Robert was a paying advertiser in AeroSnooze. Yeah, that seems to be the magic to achieving an endorsement, doesn't it. But let me say this: Cringley is a much, much better journalist than other unmentionables shall ever be. He opens his columns up for debate, he offers corrections, and freely admits it when the readers call him a boob. That doesn't make him great, and it doesn't guarantee he's honest, but it greatly increases the likelihood. And it's not the sort of behaviour you're likely to see out of his eminence anytime soon. Barnyard BOb - doe snot? Have a look he http://www.google.com/groups?q=doe+s...x.com& rnum=2 or this equivalent link: http://tinyurl.com/yypr  |
Ben Sego wrote:
	RR Urban wrote: Ben "doe snot" Sego Barnyard BOb - doe snot? Have a look he http://www.google.com/groups?q=doe+s...x.com& rnum=2 or this equivalent link: http://tinyurl.com/yypr better link: http://www.google.com/groups?q=doe+s...amu.edu&rnum=9 or this equivalent http://tinyurl.com/yyse Though, admitadly, what I did was more the inverse of that described above. B.S.  |
			 Last I knew... Robert Cringley was a self promoting huckster and flake. Actually, I rather like his "I, Cringley" column. That he was a flake in his plane building adventure, is, I think, without dispute. Can't argue with "self promoting" either; you're dead on there. I don't, though, think he's a huckster. huck·stered, huck·ster·ing, huck·sters 1. To sell; peddle. 2. To promote or attempt to sell (a commercial product, for example) in an overaggressive or showy manner. Zoom would probably give him three thumbs up... if Robert was a paying advertiser in AeroSnooze. Yeah, that seems to be the magic to achieving an endorsement, doesn't it. But let me say this: Cringley is a much, much better journalist than other unmentionables shall ever be. He opens his columns up for debate, he offers corrections, and freely admits it when the readers call him a boob. That doesn't make him great, and it doesn't guarantee he's honest, but it greatly increases the likelihood. And it's not the sort of behaviour you're likely to see out of his eminence anytime soon. I've wondered who's Cringley's core audience was. Now I know. g Barnyard BOb - doe snot? Have a look he http://www.google.com/groups?q=doe+s...x.com& rnum=2 or this equivalent link: http://tinyurl.com/yypr Hmmm. Maybe, I should snot have axed. Barnyard BOb --  |
