Douglas Skyray
Old August 27th 04, 04:11 AM
Guy Alcala
Arved Sandstrom wrote:
"Kevin Brooks" wrote in message
[ SNIP ]
"It was also very maneuverable, featuring an incredible rate of roll, and
one Navy test pilot who flew the Skyray said that Air Force chase-plane
pilots were desperate to find a USAF machine that could out-turn it. Air
Force pilots flew the F4D, no doubt with an eye to assessing its strengths
and weaknesses. It did have weaknesses, significant ones. Along with its
agility came a degree of instability, particularly in the critical
transonic
speed range. This does not seem too surprising given the aircraft's aspect
in the top view, which suggests some of the aerodynamic features of a
pancake; it also had a steep glide ratio, being described as a "lead
sled".
One pilot said the Ford's handling "bordered on the bizarre." In fact,
there
were some test pilots who despised the F4D and felt it should have never
been accepted into operational service. This appears to have been a
minority
opinion, but even its admirers admitted the Ford's instability made it a
handful for a relatively inexperienced pilot. Skilled pilots who liked the
machine also found it tiring to fly for long distances: keeping it on the
level was a continuous balancing act."
Presumably it was as well-loved as the F-101 Lawn Dart....ummmm, Voodoo.
The Navy brass certainly appreciated it, and the unit that flew it as part of
NORAD/ADC. VF(AW)-3 was the squadron, and they were based at NAS North Island,
commanded by WW2 USN Hellcat ace Eugene Valencia. They won NORAD's best
squadron competition two years running, a source of great joy to the navy brass
and considerable heartburn to the USAF brass. The biggest problem with the
'Ford' appears to have been its honeycomb wing skin structure, which just wasn't
up to the rigors of day-in/day-out operations. Ed Heinemann put an entirely
different, thicker wing skin on the follow-on supersonic F5D, but it was decided
not to put it into production, probably partly because the navy wanted to spread
the wealth around a bit and not have an all-Douglas fleet. So they cancelled
the production order for the F5D and went with the F8U exclusively.
Guy
Old August 27th 04, 04:54 AM
Kevin Brooks
"Guy Alcala" wrote in message
[ SNIP ]
and
chase-plane
Air
strengths
its
transonic
aspect
sled".
there
never
minority
a
of
Island,
brass
wasn't
entirely
decided
spread
cancelled
From what I have read, the wing structure was not the "biggest problem". The
biggest problem it faced was probably its sometime squirrely handling
characteristics; sounds like it was bordering on instability (not a bad
thing for a fighter, if you use today's models as the reference, but the
late fifties was a bit before the advent of stability augmentation via
computer controlled surfaces). This made it very agile, but it also
apparently made it kind of dangerous. Your wing structure may have been
related to another of its problems, which was its unsuitability for
offensive strike/CAS use.
Brooks
Guy
Old August 27th 04, 06:16 AM
WaltBJ
FWIW I engaged Fords twice flying the Deuce out of R-G AFB, KC MO. The
Navy/USMC Reserves (2 sqdns each) at NAS Olathe (15 w of RG) shared
our flying area. They flew F9F8 Cougars first and quickly learned to
leave the 102 alone. Then they got Fords and started hunting. I was in
my MC4 p-suit flying a 54000 foot M 1.1 target for 4 of my friends to
execute front snaps on. We were about 75 SE of KC - I was dragging a
contrail - and my buds were doing the half roll and dive back down
recovery from their attacks when 4 Fords showed up. Some of our guys
had had no rpt no ACM training - they were ADC school products and ACM
was bad - it could hurt the radar and the high performance maneuvering
was dangerous! But I had come out of Nellis and F86 Sabres and the 25
FIS via Dogs to the Deuce and ADC and so psuit or no psuit I joined
the fun. I was hanging off one Ford's wing as he chased one of the
no-ACM guys up and down and around - the Ford driver never did see me
desopite being about 60 back and a hundred yards away. Pretty quick I
had to break off for fuel and split for home. But the Ford was easy to
hang onto. Later on I was finishing a test hop for engine change when
2 Fords ahowed up at about 35000. I let them come on in to where they
were in long gun range and as they started to pull lead I lit the
burner and began low-speed yo-yoing, keeping up the turn while pulling
up, trading IAS for altitude and then easing back down to regain IAS
while tightening the turn slightly each time. ISTR I was oscillating
between 175 and 135 KIAS. In about three cycles I was sliding back
above them - the poor old Ford couldn't equal the Deuce's capability
in that maneuver, and coudn't raise the nose enough to ever point at
me. About 150 seemed their minimum. But then the Deuce had about 740
sq ft of wing area and I was light, down to about 1500 pounds of fuel,
so the airframe weight must have been below 21000. Anyway the Deuce
had no evil quirks at any reasonable airspeed. The Flight Manual says
'picking up a wing with rudder below 95 KIAS may result in a spin' but
hey, spin recovery was simple - let go of the stick. Of course 95 KIAS
is well below level flight minimum airspeed and the VVI is pegged down
- but the beast still handled nicely, as long as you had some sky left
below you to accelerate in, cause it sure wasn't going to do it in
level 1-G flight.
Cheers - Walt BJ
Old August 28th 04, 10:33 PM
Andy Dingley
On Thu, 26 Aug 2004 20:54:01 +1000, "The Raven"
Just to add another question, how did it compare to the EE Lightning which
was known as a pretty good interceptor performance wise?
No comparison. Their engines are a generation apart.
Aircraft of the Skyray's period, if not the Lightning, were airframes
way ahead of engine technology. Although some did have quite high
performance, they couldn't maintain it owing to their high fuel
consumption. Engines had to become more powerful and more fuel
efficient (and better reliability helped too) before they stopped
being by far the weakest link.
Old August 29th 04, 12:52 AM
John Carrier
"Andy Dingley" wrote in message
The J-57 was pretty advanced actually. Not so sure the Avon represented any
significant improvements in T/W or SFC. It didn't match the last J-57s
(P-420, 12,400 basic, 19,500 A/B) in maximum thrust.
R / John
Old August 29th 04, 02:54 AM
Guy Alcala
Indeed, IIRC the original Avon's design predated that of the J57, although the
-300 series in the Lightning was a considerable improvement. I think the J57
was the first twin-spool turbojet to enter mass production, and probably the
first 10,000 lb. dry thrust engine, with excellent sfc for its day -- its
development made it possible for the B-52 to be a turbojet with intercontinental
range. Otherwise, they would have had to use a turboprop, as the Russians
themselves did with the Bear (the Bison's Achilles heel was its original
engines, which limited its range).
It was the Lightning's _airframe_ which was of another generation to the
Skyray's. The more closely comparable airframe would have been the F5D
Skylancer, area-ruled and capable of just short of 1,000 mph, although the F5D
fell in-between the F-102 and F-106 in development timescale and performance.
Guy
Old August 29th 04, 07:48 PM
Peter Stickney
Andy Dingley writes:
Yeah - the Skyray used a Pratt & Whitney JT3B (J57) 2-spool high
pressure turbojet with reliable variable-area nozzles and a reliably
lighting afterburner.
The Lightning used a single-spool, low pressure ratio Rolls Avon, and
whenever one would take off or climb, there were always bets on wheter
both, one, or no afterburners (reheat, it's a Brit after all) would
light.
The J57 provided much better fuel economy, and it, and the JT3D
turbofan flavor that followed it, are still pushing airplanes around
all over the world.
(Now, if you were to talk about the XF4D prototype's original
Westinghouse J40 - well, an engine design might be screwed up if it
were a GE, but you can be sure if it's a Westinghouse.)
Uhm, if you look at the consumption numbers for more modern engines,
you'll see that they are only more efficient when they aren't using
reheat. The greater ram drag of a turbofan means that they don't
deliver the non-afterburning thrust at high speeds that a straight
turbojet does. The extra unburned mass flow from the fan section
allow for higher afterburning thrust, but at a serious cost in fuel
flow. Consider, if you will, the example of the TOrnado, which can be
routinely outrun by a Tu-95 when it's not using reheat.
The solution to long supersonic endurance has been to make it
big enough and clean enough to fly supersonically on a relatively
small ampunt of thrust while carrying a lot of gas (SR-71, B-58,
F-111, A-5, Mirage IV), or make it able to cruise without
reheat. (Concorde, F-22 - although the Concorde needs reheat for
acceleration and climb)
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
Douglas Pitcairn, Luftwaffe Pilot JDupre5762 Military Aviation 14 July 7th 05 04:03 PM
FS: 1992 "McDonnell Douglas F-15 Eagle" Hardcover Edition Book J.R. Sinclair Aviation Marketplace 0 August 25th 04 06:12 AM
Historic aviation and aeronautics books for sale Martin Bayer Aviation Marketplace 0 April 24th 04 09:30 PM
Douglas Bader-Colditz RON Military Aviation 7 February 19th 04 09:58 PM
